Question about HP Pavilion 533c (P9939AR#ABA) PC Desktop
How do I know if the HD is damaged? I suspected HD failure due to the following? computer won't start. It says, "invalid Boot.INF file." And then, it say "press Ctrl+Alt+Del to restart". What could it be? it was working perfectly yesterday.
  • HP Master
  • 4,806 Answers
I doubt that the HDD is damaged but rather that Windows boot loader files are corrupt.
Boot the machine into safe mode by restarting the computer and repeatedly tapping F8 until you see a sub menu with safe mode at the top. Select safe mode and let the system boot.
If it boots into safe mode perform a system restore and take the computer back a week to 10 days before today.
When the system restarts it should hopefully boot in normal mode.
If you are experiencing any difficulties please post back and I'll help you further.
Good luck.
Posted on Nov 12, 2009
    Sergeant:
    Champion:
  • 225 Answers
It is probably BOOT.INI. However, might be anything from a virus to manual mistake, altho this file should be hidden.
HDD Regenerator: http://www.softpedia.com/get/System/Hard-Disk-Utils/HDD-Regenerator.shtml free trial will help you check the HDD.
Computer won,t startup due to corupted file or system failure
if it hapends after a power out, and is windows xp on in u will need the original xp cd and press repair, after u will need to write down some comands :
fixboot
fixmbr
after that all will be ok if only files are damage , other wise..u will need to reinstall windows on computer
best regards
Sep 22, 2011 | Gateway Computers & Internet
My pc says"boot failure,insert boot diskette in A"
If XP was not installed on the HD from your computer then the computer won't boot from it. Reinstall it.
The system may not see your HD. As you boot, go to the boot menu and see if the HD is listed. - If it's not, see if the HD is well connected to the motherboard. - If it is then re install XP.
Sep 16, 2011 | Microsoft Windows XP Home Edition
Won't boot from dvd or hard drive, changed hard drives and still won't boot
Depends on what you mean by won't boot from DVD or Hard Drive,
it sounds like your boot order is what you're looking for help for.
To do this you need to get into your computers BIOS (or "Setup")
You can do this by rebooting the computer and the very very very first screen you see tells you how,
usually by pressing DEL or F2 or F10.
Without knowing the specific computer you're looking for help on I can only point you in the right direction however keep in mind the BIOS is for advanced users only and you can damage your computer by randomly changing settings.
What you're looking for though is usually called the Boot Order or Boot Sequence
You'll need to set whatever device you want to boot from higher on the list (usually with the up arrow or PgUp)
If you don't see your device on the boot list then it may not be detected due to failure.
May 31, 2011 | Computers & Internet
Dell Studio 15 runs slow... My Dell studio 1558 takes long time to boot & processing is also slow,i have tried disk cleanup and defragment hard disk but nothing worked,it has the following...
Check the boot processes in the from your systems control panel and look for unnecessary boot time services. Such as an anti virus boot scan and similar processes. Sometimes it is caused by the network card driver. Start your computer in safe mode and select the selective start up option and disable each service one by one (non windows) to find out which one is slowing down your boot process. It usually due to a boot scan, a faulty driver, or an invalid or corrupt registry entry. I highly doubt that you are infected with a virus and it is due one of the issues listed above.
Apr 14, 2011 | Computers & Internet
Invalid header
You are seeing the "Invalid Header" message on the LCD display on the T2250 because the pritner is in "boot" mode, which is the firmware download mode and is detecting data being recived is not a correct firmware file.
The most likely cause for this problem is the pritner has defaulted to 'Firmware Download Mode" due to a problem with either corruption to the firmware or damaged / faulty EEPROMS. When print jobs are sent to the pritner the pritner is expecting firmware and recognises the data it is reciving is not correct for a firmware file.
The solutions to this problem are;
  1. Power the printer OFF, disconnect the printer from the computer system, and any external print server (eg JetDirect etc). Power the printer back on, if the error is resolved check the method of connecting the printer to the computer system to ensure there is no damage to cables etc.
    If the printer displays "BOOT" on the display this indicates the printer is in firmware download mode.
  2. If the display reads BOOT first try reloading the firmware you may find details and firmware on the following web site,
    http://support.dascomeurope.com/index.php?option=com_docman&task=cat_view&gid=123&Itemid=48&lang=en
  3. If loading the firmware fails this indicates a logic board fault, the main logic board would need to be replaced to resolve the issue
Feb 18, 2011 | Tally T2250 Matrix Printer
Tecra m8 boot up problem
The true test here is, can it boot into the BIOS every time. If it can, then I suspect your getting ready to have a hard drive failure. Intermittent boot failures and non-start-ups are usually caused by a faulty hard drive. If it was your boot menu or boot loader, then it would never boot period. I would suspect the hard drive overheated and is damaged, or there are damaged sectors on the drive that contain some of your windows files.
Sep 25, 2009 | Toshiba N97842 13.3 TECRA M8-S8011 INTEL...
Boot Problems
PXE means it will only boot while connected to the network,
You need to change the bois From network boot to Hard drive boot.
The system doesn't see a hard drive inside,
it thinks it is booting from the network only,
it boots to a server like this.
It is called a dumb terminal
Richard.
Apr 26, 2009 | Computers & Internet
When i load the gateway system recovery disc i get line 20101 of the inf file \minit\boot is invalid setup cannot continue
Sounds like you have a damaged restore disk. Look at it under a bright light, and see if there are any scratches in the disk. You might be able to clean the disk (always clean from the inside out, never in a circle).
Jul 28, 2008 | Gateway Computers & Internet
TAPE detection
Tape detection is probably a result of having installed MSBackup. When you installed MSBackup it installs three virtual device drivers one or more of which is causing you your start-up problems. I would suggest removing or renaming the following files to stop tape detection at startup.
drvwq117.vxd
drvwppqt.vxd
drvwcdb.vxd
You might also want to remove/rename:
pnpwfdc.inf
pnpwide.inf
pnpwtape.inf
pnpwppt.inf
Boot Log Analyzer should tell you which of the above vxds is causing you your problems; I seem to recall that the usual culprit is drvwq117.vxd.
May 09, 2008 | Computers & Internet
Service installation section in this INF is invalid
If the player is showing up in your Windows' Device Manager under "portable devices" with a yellow "!":
1.) Right-click the yellow "!" and choose "update driver".
2.) When given the option to connect to Windows Update, choose "no, not this time" and click next.
3.) Choose "Install from a specific location (advanced)" and click next.
4.) Choose "Don't search. I will choose the driver to install" and click next.
5.) Click the "Have Disk" button. Browse to C:\Windows\inf and choose the file marked "wpdmtp.inf"
I can't believe the generic players have such crappy support when so many people have this problem! I think the Windows file problem might be caused by "compressing old files" when you do a disk cleanup.
Mar 17, 2008 | Audio Players & Recorders
HP Pavilion 533c (P9939AR#ABA) PC Desktop Logo
111 people viewed this question
Top HP Computers & Internet Experts
Tony
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
