Question about Whirlpool 21.0 cu. ft. Top Freezer Refrigerator with IceMagic Plus Ice Maker
Doesn't cool as much as it should -- freezer, on
Refrigerator doesn't cool as much as it should -- freezer, on top, will maintain 40-45 degrees; bottom only about 65. This is an old Whirlpool 19.9 ET20DKXVNO5 -- motor used to go off with a loud shudder, and an occasional 'knock' sound, coils on the bottom were not excessively dusty, but I vacuumed them off anyway; no visible leaking or frost, but I only removed the bottom cover and looked at the lower part -- can't afford a new one right now, can this be fixed?
    Scholar:
  • 79 Answers
Does this model have a condenser fan that blows air over the condenser coil(coil on the bottom of the unit)? If it does then does the fan run?The fan has to circulate air over the coil to remove the heat from it. If the fan doesn't run then the compressor will overheat and cycle off then on on the internal thermal limit inside the compressor and the system will never come close to cooling as it should.
Posted on Nov 12, 2009
Refrigerator wont cool but freezer does
The problem is the Ice Dam inside your Freezer. You have to defrost the Freezer (making sure to completely dry the Bottom of the Freezer and more importantly the DRAIN TUBE)...
Jul 20, 2014 | Frigidaire FRS6R4E Side by Side...
Ffbm 920w won't cool
It appears that your auto defrosting system (if you have one) is not working. So your evaporator coil is frozen up - all that ice serves as an insulator and not enough cold air is getting down into frig section. Until you replace either the freezer defrost element or the defrost timer all you need to do is unplug for a few hours till it fully defrosts then plug back in - will work fine for a few days at normal internal temps till the ice builds up again.
If your timer and defrost element are both working properly, THEN, you might want to check if you have enough refrigerant in the system - you may have a leak.
Mar 31, 2014 | Avanti FFBM921PS 9.2 cu. ft. Bottom...
Top part of refrigertater not cooling. bottom freezer is ok. only about three years old.
Check out these tips...they can help you figure out what is going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Jan 28, 2011 | Whirlpool GX5FHTXVA Bottom Freezer French...
The top freezer is working, but the bottom refrigerator is warm, around 58 degrees?
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
Check out these tips...they can help you figure out whats going wrong with your refrigerator and why it is not cooling
heatman101
Aug 31, 2010 | Whirlpool 21.0 cu. ft. Top Freezer...
Cooling problems with OLD Whirlpool ET20MK refrigerator.
top up the freon gas charge you have a low charge
Jul 19, 2010 | Whirlpool Refrigerators
Older (20 to 25 years old) non-frost free Whirlpool refrigerator is not cooling below 60 degrees. I defrosted it and left it off with doors open in garage for 10 hours. Turned the cooler knob to 4...
Good day,
If it is a conventional refrigerator, there should be a cooling plate on the top back of the wall in the food section.
Assuming the door fits and closes properly, and the light goes out when the door closes, the plate described above should have a frost pattern on it. That is what cools the bottom fresh food section.
If left on for plus 12 hours normal cooling should exist.
If the plate is not frosted, and the machine runs constantly, you have a freon leak with no real practical repair possible.
You could recharge it, but it would be pricey, and just repeat the problem shortly.
Jun 16, 2010 | Whirlpool 21.0 cu. ft. Top Freezer...
My refrigerator cant maintain cold and freezer temperatures
check and see if the doors are closed good
Mar 31, 2009 | GE Refrigerators
Kemore Refrigerator MODEL# 2535808789A is not cooling.
Thank You for having your model number ready, Could you remove the grate on front and bottom of refrigerator to expose the defrost timer. In the opening on front turn the timer slowly turn clockwise until you hear a click or change in operation of refrigerator. Let me know, Sea Breeze
Mar 21, 2009 | Kenmore Refrigerators
Whirlpool 21.0 cu. ft. Top Freezer Refrigerator with IceMagic Plus Ice Maker Logo
158 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
