I have inserted the #2 ink cartridge. what number cartridge goes into the second slot. I have a lexmark 2500 series printer.
    Problem Solver:
  • 10 Answers
Normally the left side is the black and basic cartridge and the right which i'm guessing it's your 2nd slot is for colour or photo carts.
Posted on Nov 12, 2009
No print with new cartridge on z1300
Try to remove and re-insert the cartridges into the printer carrier and make sure they are firmly inserted into the slot. Try to print again.
Print quality issues can be due to dirty or clogged cartridge nozzles. Try to open the Lexmark Solution Center on your computer to clean the cartridges.
On your computer, go to Start menu > Programs > Lexmark 1300 Series folder > Lexmark Solution Center. From the Maintenance tab, select Clean to fix horizontal streaks. Your printer will then print a test page forcing ink through the cartridge nozzles and clean them.
Try to print a document again to verify that the problem is fixed.
Oct 28, 2011 | Lexmark Z1300 InkJet Photo Printer
Tip
Lexmark 2500 series ink cartridge problems
ok, i called lexmark and finally figured out the problem so many people are having with the unsupported cartridge error. it seems there are a few different varieties of 2500 series printers. mine for example is a 2500, came with a 2500 series user manual, but is actually considered a 2580! this is huge for the ink cartridge- as a 2580 is the only version that takes number 2 and number 3 cartridges. i switched from the 28 and 29 cartridges that the manual said to use and the box said was compatible for and put the 2 and 3 cartridges in, and it worked fine. i complained to lexmark that the manual is deciving and costing people money. she offered to send me the right cartridges free of charge. i hope this helps some of you!<br />
on Jan 04, 2011 | Lexmark X2500 All-In-One Printer
I changed the black and color ink cartridges on my Lexmark 2500 printer but both of the ink lights continue to blink off and on. I'm unable to get the printer to reset by disconnecting the printer and...
Make sure you are inserting the correct versions of cartridges for your model. Try to re-seat the cartridges by removing and re-inserting the cartridges in the carrier. The black cartridge goes in the left carrier while the color goes in the right. Also, make sure you are using genuine Lexmark cartridges.
Jun 27, 2011 | Lexmark X2500 All-In-One Printer
How do i replace my ink cartages
Removing a used print cartridge:
  1. Make sure the printer is on.
  2. Lift the scanner unit. The print cartridge carrier moves and stops at the loading position, unless the printer is busy.
  3. Press down on the lever to raise the cartridge lid.
  4. Remove the used print cartridge.
To install a new cartridge, remove the sticker from the back and bottom of cartridge. Insert the new cartridge in the slot. Close the lid. Lift the scanner unit, press the scanner support back until it slides into the slot, and close the scanner unit.
Source: Lexmark X2400 Series User's Guide
May 18, 2011 | Lexmark X2470 All-In-One InkJet Printer
How do I change the ink cartridge in a Lexmark x2330
  • Turn the Lexmark printer on by pressing the power button. Usually, the power button is located on top of the Lexmark printer. If the Lexmark printer does not power on immediately, then hold the button down for a few seconds before releasing it. Once the Lexmark printer has powered on, the installed cartridges will begin to move back and forth for a few minutes.
  • 2
    Raise the Lexmark printer cover up towards you. Doing this will give you instant access to the inside components of the Lexmark printer. Lift the cartridge release lever and remove any installed ink cartridges. Be careful when doing this because the ink may leak out. It's best to have a disposable bag or paper towel near you when performing these steps.
  • 3
    Remove the plastic from the brand new cartridges by carefully cutting them open with scissors or tearing along the perforated edges. Once you have removed the plastic, there's a yellow tag located near the bottom of the ink cartridge. Take this tag off only when you're ready to insert the ink cartridges into the slots.
  • 4
    Tear the yellow tag from the ink cartridges and place them into their corresponding slots. Each one will be easily identified by its color. The cartridge release lever will have the same color as the ink cartridge. If you mistakenly place the cartridges in the wrong slot, then you'll risk having your Lexmark printer stop working properly.
  • 5
    Press the ink cartridges into the slots and listen for a clicking noise after the insertion. Although you will need to firmly place the ink cartridges into the available slots, it still needs to be done gently. Close the Lexmark printer cover when you've completed the previous steps. Wait a few minutes for the Lexmark printer to recognize that you have inserted brand new ink cartridges. After a few seconds, it will go through some diagnostic steps to make sure the ink cartridges were correctly inserted.
  • 6
    Print a test page on your Lexmark printer. This will help you to determine if the ink cartridges are properly working. You can view the newly printed images and text after the Lexmark printer has finished printing. Get rid of your used ink cartridges by throwing them away or sending them to an online store that accepts empty ink cartridges.
  • Jan 17, 2011 | Lexmark X2330 Printer
    Need to change the ink cartridge on lexmark model #x2350
    1- Turn the printer on by pressing the power button. Usually, the power button is located on top of the Lexmark printer. If the Lexmark printer does not power on immediately, then hold the button down for a few seconds before releasing it. Once the Lexmark printer has powered on, the installed cartridges will begin to move back and forth for a few minutes.
    2- Raise the Lexmark printer cover up towards you. Doing this will give you instant access to the inside components of the Lexmark printer. Lift the cartridge release lever and remove any installed ink cartridges. Be careful when doing this because the ink may leak out. It's best to have a disposable bag or paper towel near you when performing these steps 3- Remove the plastic from the brand new cartridges by carefully cutting them open with scissors or tearing along the perforated edges. Once you have removed the plastic, there's a yellow tag located near the bottom of the ink cartridge. Take this tag off only when you're ready to insert the ink cartridges into the slots.
    4- Tear the yellow tag from the ink cartridges and place them into their corresponding slots. Each one will be easily identified by its color. The cartridge release lever will have the same color as the ink cartridge. If you mistakenly place the cartridges in the wrong slot, then you'll risk having your Lexmark printer stop working properly.
    5- Press the ink cartridges into the slots and listen for a clicking noise after the insertion. Although you will need to firmly place the ink cartridges into the available slots, it still needs to be done gently. Close the Lexmark printer cover when you’ve completed the previous steps. Wait a few minutes for the Lexmark printer to recognize that you have inserted brand new ink cartridges. After a few seconds, it will go through some diagnostic steps to make sure the ink cartridges were correctly inserted.
    6- Print a test page on your Lexmark printer. This will help you to determine if the ink cartridges are properly working. You can view the newly printed images and text after the Lexmark printer has finished printing. Get rid of your used ink cartridges by throwing them away or sending them to an online store that accepts empty ink cartridges.
    Nov 27, 2008 | Lexmark Office Equipment & Supplies
    Lexmark x3430 need ink cartriage
    This is the only information I could find. Didn't your printer come with a black and color ink cartridge? If it did, all you need to do is take the ink cartridge out and write down the numbers written on the cartridge. The only ink cartridge I could positively confirm was the #24 color ink cartridge. The Lexmark website does not list any black ink cartridges for this model. This information was obtained from Officemax.com.
    Lexmark - 24 Ink Cartridge - Color
    Compatible with Lexmark Z1400 series, X3500 series and X4500 series printers;
    Lexmark - 23 Ink Cartridge - Black
    Compatible with Z1400 series, X3500 series and X4500 series printers;
    Sep 15, 2008 | Computers & Internet
    Dell 942 Error 1203
    Error 1203 occurs either when a cartridge is bad or the printer cartridge Slot is bad... I would suggest you to try cleaning the copper contacts of the both carts and cart slot in the printer and try again..
    If that doesn't work just call up their support number and check for replacement..
    Apr 08, 2008 | Lexmark P315 InkJet Photo Printer
    Lexmark 3470, new ink dosn't work.
    In this case as u said u used this Catridges in 2 printers then check if u have removed the Transparent Strip from the catridges mand if it is removed and still u face this problem make sure u have inserted the Catridges in the right slot........ U need to insert the colour catridge on the right side and the black catridge should go on the left side.... If no go get the catridges replaced....... Good Luck.......
    Apr 06, 2008 | Lexmark X7350 All-In-One InkJet Printer
    Computers & Internet Logo
    88 people viewed this question
    David Payne
    David Payne
