Question about Poulan Pro 42CC 2 Cycle Chainsaw, 18"
When i prime the bulb try to start it will run for abot 2 seconds and will not run.you pull and pull and it will not start.we have cleaned the carb and gas lines.the saw is just one year old.i bought it at lowes in livingston,tx
    President:
  • 2,220 Answers
Inspect your hose routing. it should be similar to this:
  • The hose in the tank with the filter on the free end connects directly to the carburetor input connection.
  • If the saw is equipped with a primer bulb, the output line from the carburetor connects to the suction side of the primer (once the bulb is collapsed it draws fuel from the tank through the carburetor to refill as it inflates).
  • The pressure side of the primer returns displaced fuel to the tank as it is depressed. HTH
Lou
Posted on Nov 12, 2009
  • dontbother10
    dontbother10 Nov 12, 2009
    Exactly what you describe happens if the filter leg feeds the primer bulb instead of the carburetor.
    President:
  • 2,702 Answers
There is very little wrong with it if it starts up and runs, its down to the fule lines as it is clearly not getting fule,,, have a look at the filter on the end of the fule line inside the thank if its fell off the fule line will be floping about in the tank but not picking up fule,,, also strip the carb again the little rubber pump may need changing or you may still have a blocked jet in there,
Trimmer won't prime to start
Look inside the tank. Some units have a stone inside that blocks the fuel line when it is tipped a certain way. Might be what's happening here.
Aug 13, 2016 | Garden
Hs45 does not prime properly and won't run at full revs
Replace the carbeurator and all fuel hoses. The circuits in the carb are stopped up and they are so small they can't be properly cleaned out.
Jun 23, 2014 | Stihl Garden
Trimmer will not start when primed and string pulled. When put starter fluid in carb. it hits and runs for a couple of seconds. Prime it and it will not start. Does hit sometimes but does not run like it...
There is dirt blocking the fuel supply to the engine. You need to strip and clean the carb, preferably fitting a new carb kit at the same time. Clean out all the passages and orifices by blowing them out, but be careful of loosing small parts like filter screens and screws.
May 13, 2011 | Craftsman 27cc 2 Cycle Crank Straight...
I can start my 4.75 HP Briggs & Stratton Lawnmower but it dies after a few minutes. I replaced the armature but the same thing happens. I can keep it running if I press the prime bulb a couple of times...
Try replacing the float and needle. The float (floats) and pulls the needle up to let gas through to the carb. It will stay running as long as you press the prime bulb because this sends gas straight to the carb without going through the gas bowl. It's best to remove the carb and clean it then replace the float and needle
Sep 05, 2010 | Craftsman Garden
Primer will not pull gas to carb and will not run. gasket replaced
You can check the priming circuit manually by pulling the plug off the spark plug and then with our hand over the air inlet to the carb have someone give the mower 3-5 pull starts. Then, put the plug boot back on and try to start it. Did it work? Is it still running? If it started and ran your primer bulb probably has a leak and needs replacement. If it started and ran for a few seconds and died clean out the main jet and the bowl inlet.
You can look at the breakdown of the carb in your manual to see where these parts are. Or just go online and find a familiar carb diagram and work from there.
Good luck and be careful!
May 24, 2010 | Poulan "Poulan" Push Mower
Engine starts when I hand prime it,but not when I use prime bulb.
There are two screws on the carb. 1 is Lo rpm air/fuel ratio and the other is hi rpm. Try adjusting the lo rpm screw counter-clockwize a 1/2 turn at first, more if needed. After each adjustment try to start. The other thing you could check is if the float is sticking in the bottom of the carb. which shuts off gas flow if full. There is a screw on the bottom of the carb to drain that float. You can try that also! Good luck man!
Sep 21, 2009 | Craftsman 25cc Gas Line Trimmer
Primer bulb on weedeater won't prime
when you prime the bulb it sucks gas from the tank with the small tube, any excess gassed pumped will be fed back to the carb via the big tube leading to the tank. If you prime it and the bulb stays pushed down, then you have a clog or kink. To fix , pull the small tube out of the tank through the fill hole. Pull off the filter on the end and put the tube back in the tank. If it primes, your fuel filter was clogged. If it still wont prime check the hose going to the carb and make sure isnt clogged or kinked.(take of carb and blow in it). If that doesnt fix it take off the bulb from the carb with two screws. The bulb assembly will come off too(rectange metal thing) Take off the two black gaskets, be carefull with them. Take off hoses from carb and bulb asembly. Blow carb cleaner in all holes and over surface. Put back together.
If the carb wont prime and the bulb isnt staying depressed. then you might have a bad bulb or carb gaskets. Make sure hoses are not cracked, cloged, or pinched.
Jun 17, 2009 | Troy Bilt Tb70ss Gas Trimmer
Toro personal pace mower 5 yrs old only runs 10-15 seconds.
Was gasoline left in the tank during off season? Sometimes gas will break down and clog the jets in the carb. The priming bypasses the carb so when you put fuel in by pumping the bulb it runs, but dies becasue no additional fuel is coming through the carb after the primed fuel is burned off. Sounds like you need to clean the jets in the carb and in the future, use Stabil in gasoline to keep it from breaking down.
May 04, 2009 | Toro Lawn Mower With Toro Power Tools
Engine runs 2-3 seconds then stops
Drain float bowel
check for water .
Mar 19, 2009 | Garden
Poulan Pro 42CC 2 Cycle Chainsaw, 18" Logo
430 people viewed this question
Top Poulan Garden Experts
Roland W VanLue
Roland W VanLue
Phil Walker
Phil Walker
Are you a Poulan Garden Expert? Answer questions, earn points and help others
