Question about Linksys Wireless-G WRT54G Router
Linksys WRT54G connects but is homicidally slow, and won't renew DHCP if signal falters!
    Guru:
  • 1,738 Answers
Linksys wireless firmware is know for it slow connection issue. I have one and my lan speed was double then my wireless speed. I put the third pary firmware from www.dd-wrt.com website and now my wireless and lan speeds are the same.
Posted on Nov 19, 2009
Linksys Wireless-G WRT54G Router wifi working but local connection to my computer doesn't work. configuration is working on my computer but it doesnt receive any connectio.
1. check the Ethernet cable
2. check the DNS/DHCP setting ( should be set to Obtain IP automatically) on both.
3. Do an ipconfig / release then renew in the command line in the DOS window
4. if cable is good move it to another port in the router.
5. check the release/renew of the ip in the router con fig window> usually 192.168.0.1 > inputted in the browser<
6. check the light status of the port where the Ethernet ( if yellow then ip needs to be released / renewed.
Oct 05, 2011 | Linksys Wireless-G WRT54G Router
I am not able to connect to the internet using my Linksys WRT54G V8. When I connect the cable directly to my laptop, I am able to access the internet, so it is definitely a problem with the wireless...
Title: Setting-Up a Wired Computer to Obtain an IP Address Automatically Article ID: 4033
Configuring a wired computer to get an IP address automatically will enable it to get an IP address from a DHCP server. Instead of manually entering the IP settings which will consume much time, performing this procedure will ensure that the computer will get the correct TCP/IP settings.
Configuring a computer to get an IP address automatically is useful when:
  • Connecting a computer to a network with a DHCP server. Ensuring that the computer is getting the correct TCP/IP settings.
To configure a computer to automatically get an IP address, you have to check the TCP/IP properties of the Ethernet Adapter installed on the computer. Follow the steps below for instructions.
NOTE: Make sure the wired computer is properly connected to a network with a DHCP server.
Checking if the Computer is Set to DHCP
NOTE: The instructions provided below only apply to Windows 98, ME, XP and Mac operating systems. If you are using Windows Vista, click here for instructions. For Windows 7 users, click here for instructions.
Windows 2000/XP
Windows 98/ME
Mac OS
Sep 29, 2010 | Linksys Wireless-G WRT54G Router
Im tryig to piggyback my wrt54g router to another part of the house. I have a cable coming from my linksys e1000 n router which is my main router. When i plug the cable into the 54g i can access the router...
What is the IP address of the E1000 router ?
If the IP address of E1000 router is 192.168.1.1, Then change the IP address of WRT54G router to 192.168.1.2. Connect the Ethernet cable from the Ethernet port of E1000 router to the Ethernet port of WRT54G router ( port 1 of E1000 to port 1 of WRT54g). Disable the DHCP server.
You can do it in a different way also.
If the IP address of E1000 is 192.168.1.1. then change the IP address of the WRT54g to 192.168.2.1. Do not disable the DHCP server of the WRT54G. Connect the E1000 to the Internet port of WRT54G.
Click Here to know more about router and network
Sep 03, 2010 | Linksys Wireless-G WRT54G Router
I have a WRT54G router and want to daisy chain a Linksys BEFSR41 switch off it, but I seem to be doing it wrong...
Not sure if you just want to expand the amont of computer you can connect to it or the wireless range but I would setup the BEFSR41:
  • Disable DHCP
  • Set an address out of the DHCP scope of the WRT54G
  • Connect them LAN to LAN if not use xover to connect them
Aug 27, 2010 | Linksys Wireless-G WRT54G Router
How to connecting Aztech modem DSL600E with Router linksys WRT54G
1.connect port 1 from the Aztech to the Linksys WRT54G Wan"
Login to the linksys and release/ renew ip
2. once IP is obtained then you should be able to connect.
Apr 25, 2010 | Linksys Wireless-G WRT54G Router
How to cennecting Aztech modem DSL600E with Router linksys WRT54G
First!
Do you have a connection in your modem?
if you do, you need to set up the linksys router in DHCP internet set up.
To have access to the linksys you need to go to:
http://192.168.1.1
The password it's admin
and the username in blank (no password)
change the internet setup to DHCP
Make sure you don't have the Same address for 192.168.1.1 or you modem cause if you do you'll need to change the ip address on the linksys router...
Linksys Wireless-G WRT54G doesn't send a wireless signal out anymore. I did the driver update and still doesnt work.
1. check the RJ 45 cable see if you are getting a signal through a hard connection if not go in to the router and check the status. You may have to reset the router and to release/ renew the IP in the router. Call Linksys for there support they will be happy to do check-sums to see if the router is defective. you can also check their site for troubleshooting to check the router to see if there is a malfunction.
Jan 29, 2010 | Linksys Wireless-G WRT54G Router
Using Linksys WRT54G as router connected to ActionTec with FIOS
You must keep everything on the same subnet. Only allow the router to be DHCP and keep everything on 192.168.1.x subnet. You are going to have alot of problems talking across subnets
Jan 15, 2009 | Linksys Wireless-G WRT54G Router
Linksys router vs. hp computer
First of all u should ensure that DHCP server is configured for your required number of computers. this problem seems that you have less clients configured in your DHCP server, existing in router configuration.
Dec 28, 2008 | Linksys Wireless-G WRT54G Router
2 linksys Routers communication problem
Change the Router2 IP address to: 192.168.1.2,
Connect the ethernet cable to the Routers like this:
Router1: Any numbered port ( Port 1, or Port 2, etc)
Router2: WAN Port.
That should do it... Good Luck!
Nov 08, 2007 | Linksys Wireless-G WRT54G Router
Linksys Wireless-G WRT54G Router Logo
353 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
