Question about Sony DSR-11 DV / Mini DV VCR
I have a Sony DSR-11 DV. I have had it for 4 years. I have had no problems with it until this evening. It turned on okay and powered up okay and I loaded a Sony PDVM-40N tape to begin digitising. The tape loaded fine. All of a sudden the deck appeared to 'short out'. Now, the deck remains on and I cannot turn it off via the on/off button on the front panel. I can only turn it off by disconnecting it from the electricity power supply. The DVCam tape is also stuck in the drive mechanism and cannot be ejected. The eject button is not working. When the deck is powered up it seems to be stuck in a kind of loop, where it powers up - the fan 'whirrs' - before it shorts - the fan stops - before it powers up again - the fan whirrs - before it shorts again. This 'loops' carries on until it is powered down by disconnecting the electricity supply. I repeat, I cannot turn the deck off via the on/off button on the front panel. Any ideas? Many thanks
  • 21 Answers
The first step is to turn of from the electricity ,then to remove covers upper and down, and front mask. After that you will be shown under mehanic one board, who is covering mehanic. You must relase that board, but before yu relase that ,you must disconnect cable from right said. After relasing board you will see mehanic. Then you must take out all of mehanic with case of mehanic ( if  I remember corectly I think that there is 4 scruf ). You musr relase mehanic of all of flat cables, on the way that mehanic complete get out. On the right said you have motor which are working loading and unloading tape from the case of tape. You must disconnect cable from that motor, and with help of batery ( ex. 9 V ) you must unloading mehanic in position of begining. After that you have second motor which is on right said on `elevator` or chanel of tape ( where the tape are going in ), you must follow the wire and disconnect from board. After that you can with help of batery or dc power ,changing + or - , going in or out tape ( eject ). Put everything on place and try this solution. All this is possible, if you have knowledge in this area. This is not easy, but it is only solution to eject the tape. Complicated question have complicated answer, but I hope that this will help you. Greetings!
Posted on Nov 21, 2009
When i turn on the dsr 11 all the LEDs are blinking , the fan in back is also still and no button is reacting when pressed. how can i solve this problem
It` probbably problem in DC to DC converter unit, you don`t have one of power supply on it,and also can be that power supply have been disteract with something ( IC cirkle,drivers for motor etc....) Problem is very hard,you must have profesional help. Good luck!
Sep 20, 2009 | Sony DSR-11 DV / Mini DV VCR
Mini DV Tapes Won't Play
Please give the model and the make
Apr 16, 2008 | Sony DSR-11 DV / Mini DV VCR
DSR-11 will not record in DV SP mode.
dear, u need to change the memory cell of ur dsr-11 ,
Jul 29, 2009 | Sony DSR-11 DV / Mini DV VCR
Playback problem DSR 11
if you plug & unplug cable after turning off ,perhaps you can the conector firewire on the vcr inside there are 4 yellow cables if not the conector defect.try to push the cable firewire litle up down side just to make sure
Apr 29, 2009 | Sony DSR-11 DV / Mini DV VCR
DSR 11 won't record DV tape to its end
You need to use longer tapes. The DER-11 is a DVCAM deck which when recording, uses a faster tape speed then mini DV. Think of your older VCR's. They had SP, two hours, and EP or SLP, which would be six hours. The SP speed would give a better picture. DVCAM is more like an SP recording except digital and a lot better. More information is laid down on the tape.
You'll have to jump up to the full size DVCAM tapes in order to record the full hour.
Apr 10, 2009 | Sony DSR-11 DV / Mini DV VCR
Lost remote to dsr-11
Sorry but there is no way to get that info other than through the menues. The remote is still available from Sony for $78.95 as part number 1-476-403-11
Dan
Feb 05, 2009 | Sony DSR-11 DV / Mini DV VCR
DSR 11 MONITORING AUDIO ON SEPERATE PLAYBACK SCREEN
you are correct
you can display data codes only on this unit
the manual can be found here
http://www.sony.ca/dvcam/manuals/DSR-11.pdf
Dec 02, 2008 | Sony DSR-11 DV / Mini DV VCR
Sony DSR-11 Will Not Recognize Timecode
I think you may have misconfigured something because the problem is not in your DSR-11 try connecting it to a monitor and you will see the time stamp and picture as proof of what I am saying. The problem I think is that your Mac is not processing the time stamp correctly. Try this link first it helped me: Remember follow the instructions ezactly: http://forums.creativecow.net/readpost/35/856108
Sep 11, 2007 | Sony DSR-11 DV / Mini DV VCR
DSR-11 not recognized by FCP
Hello tommy_bee, Try the advice offered on this link. http://forums.creativecow.net/readpost/35/856108 It has helped me
Aug 15, 2007 | Sony DSR-11 DV / Mini DV VCR
Fast Forward and Rewind turn off machine
Your drive roller maybe slipping, this is the rubber-tire or it may be plastic driven gear type. If rubber you can clean that rubber with some type of cleaning fluid and dry and try again
Aug 04, 2007 | Sony DSR-11 DV / Mini DV VCR
Sony DSR-11 DV / Mini DV VCR Logo
464 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
