Question about GE Ovens
Ge gas oven goes to f2 and beeps when we set the oven over 375f. 400f guaranteed to go off. We replace the glow coil last year and it stopped but its back. We use the oven at 375f for the top temp. We want to repair it permanently or it is normal to replace the glow coil frequently.
  • 6,784 Answers
HI, You will need to check the oven sensor wires that link the actual sensor to the main control board. Make sure that the contacts are connected properly, and not loose, or corroded. If all the wiring checks out, test the sensor for the correct resistance readings.(you will need a multimeter for this test)
The most common oven sensor should be approximately, 1100 ohms when at room temperature. The others may be close to as follows:
100°F - 1143 ohms
200°F - 1350 ohms
300°F - 1553 ohms
350°F - 1654 ohms
400°F - 1753 ohms
500°F - 1949 ohms
If the sensor test is adequate, and the wiring is Ok at the control, this will lead to a failed control board. replace the control in this case.
F2- Failed Oven temp sensor, or control board.
Concerning the glow ignitior.
When the bake igniter becomes weak or burns out, your oven will not bake. The bake igniter is usually mounted on the oven burner. It's about 1 inch by 4-8 inches (depending on the model), and comes in round or flat styles. If you don't see the igniter glow at all, it's probably burned out. Replace the igniter if found defective. Note: one of the exceptions could be that your oven is set to automatic mode instead of manual. If this is the case, set your oven to manual mode and check again.
If the bake igniter glows red and not bright yellow or white, it is probably because it is too weak. When this happens, the safety valve will not let the gas out into the oven burner. A weak igniter must be replaced.
Posted on Nov 12, 2009
Fisher double oven OD302. Periodically it will start beeping, shut off with no default code
Oven keeps beeping:
As there is no reprogramming of most control boards try this, disconnect the power and wait 30 seconds and then reconnecting the power.
If it's an "F1" fault code this generally implies an electronic oven control (EOC) failure. Disconnect the power, wait 30 seconds or longer and then reapply power. If "F1" returns upon power-up, replace the electronic oven control.
The oven control can be accessed and replaced from the rear of the control panel.
NOTE:Disconnect the power cord from the power source before removing the panel from behind the console.
If its an F2 ERROR CODE, The F2 error indicates an open circuit in the oven temperature probe.
Your range has a resettable thermostat in series with the oven temperature probe. If this thermostat opens the clock will display F2 and the oven won't heat.
You can reset the thermostat by pushing in the reset button on top of the thermostat.
Some ovens have an alarm that will beep continuously every six seconds to alert you that the oven is still on. Usually, a kitchen timer that you have set will cause the beeping, but occasionally it can be an error with the oven's settings. If it is the kitchen timer, you can simply push the "Kitchen Timer On/Off" button to end the continuous beeping. If that does not stop the beeping, it is probably beeping due to an error. You can turn the continuous beeping off but you may still need to troubleshoot the issue that is causing the beeping noise.
Read more :
http://www.ehow.com/how_12086370_ge-oven-stop-beeping.html
How to Get GE Oven to Stop Beeping eHow
Jan 09, 2017 | Fisher Ovens
Turned oven to bake it keeps beeping with message "door"
Oven keeps beeping:
Read more :http://www.ehow.com/how_12086370_ge-oven-stop-beeping.html
Apr 21, 2014 | Whirlpool Ovens
F3e2 error
Oven keeps beeping:
Read more :http://www.ehow.com/how_12086370_ge-oven-stop-beeping.html How to Get GE Oven to Stop Beeping eHow
Jan 03, 2014 | Whirlpool Ovens
JRP 15 oven showed 350F and gave preheat beeps. Frozen lasagna "cooked" 45 mins and was still almost frozen. Oven was warm inside, not hot. Bottom element glowed orange when I increased the temp setting...
The oven was obviously not heated to 350 even though this was the setting. There is a very simple proceedure to calibrate the oven. It is different on different makes of ovens. Your owners manual will give you the detail of how to reset yours. If the manual is not available, click on the following link. Hope this is helpful.
http://www.applianceaid.com/temp-change.html
Oct 05, 2009 | GE JRP15 Electric Single Oven
We replaced the starter on our GE oven in November last year and now the oven will not work again. What do you think may be the problem?
Starter, meaning ignitor, for your gas oven? If so, is the ignitor glowing at all? If it isn't, and there is voltage going to it, it is defective. Although, even if it is glowing, it may still be defective. When it glows, it creates resistance through the gas valve and when the valve senses the correct resistance, it opens, allowing gas to flow to the burner, but if the resistance is not correct, it will not open.
Aug 19, 2009 | Ovens
Ge stove flashes f2 and beeps
F2 is a oven sensor error . remove and or replace the oven sensor if doesn't stop replace oven control
Mar 31, 2009 | GE Profile JTP18 Electric Single Oven
Oven won't heat up
hi atdowhower,for your oven to heat the[ignitor]must heat up enough to open the oven safty valve.this happens by the ignitor drawing enough amprage thru the safty valve.just because it glows it may not be strong enough.or if you see no glow it may have a broke coil in that ignitor and wont glow at all.you wll need an volt meter to check if no glow.if soft glow,replace ignitor.shoul be very brite.God bless,tom
Jan 02, 2009 | GE JGRS14 Gas Single Oven
Err on display when I try to set the bake temperature
Usually, when an oven won't bake, it's because the bake element is burned out. The bake element is the black, pencil- thick tube at the bottom of the oven. When the oven heats, the element glows red. This element has an expected life-span of several years. It may last for only one; it may last for many more. When the element burns out, you need to replace it.
or try doing this
1. Turn the clock selector knob to OFF
2. “Tweak” the oven control by turning the clock selector knob slightly to the left (counter clockwise). This may stop the flashing message/beeping and clear the display window.
Nov 12, 2008 | GE Profile JTP18 Electric Single Oven
F2 error code
Similar problem. When baking over 400 degrees we get the F2 code that can only be reset by cycling the power at the breaker. Replaced the electonics to no avail. I'm thinking its the cooling fan located between the oven and microwave (upper unit) it never comes on which may cause a separate temp switch to generate the F2... but I'm not a pro. :)
Nov 18, 2006 | GE JGRP17 Gas Single Oven
Ovens Logo
75 people viewed this question
Top GE Ovens Experts
William Miller
William Miller
Dan Webster
Dan Webster
Are you a GE Oven Expert? Answer questions, earn points and help others
