Question about Kinyo PS-107 Computer Speakers
My computer crashed and now my speakers wont work cause it says i dont have the drives
    President:
  • 1,149 Answers
Hi:
You need to go to your computer manufacturer's website and download the drivers for your soundcard.
An example would be if you have a Dell computer, go to www.dell.com,
click on their support/drivers link, type in the model of your computer, and download the proper file.
Posted on Nov 12, 2009
    Master:
  • 956 Answers
Yes, that does happens. you need to reinstall, if you have on, your sound card setup.
You may have onboard reinstall progs, depending on your sys?
Before all that, if not already done so, Restore point before crash date? It may just work, but don't hold your breath.
Otherwise access your providers website, to see if you can download the missing sound card and updates.
  • 460 Answers
If you have the restore disc for your pc. use it, beware you will lose all your information on the hard drive. or you can go to thekinyo web site and download the drivers.. goob luck..
What can i do if my kinyo speakers dont work since my computer crash and the coumputer cant fine enoght data to instal that hardwer
you might have to uninstall then reinstall either the driver or the sound devices
control panel sounds and audio,volume,advanced,speakers select appropriate speakers or audio you will find 3 drop down lists make the necessary adjustments there or control panel,administrive tools,computer management,device manager,sound,could be a yellow question mark? right click to re-install drivers or right click select properties to either troubleshoot,uninstall,rollback driver
hope this helps
Oct 25, 2010 | Kinyo PS-107 Computer Speakers
No sound
You have to install the drivers for the speakers. If you dont have them , then go to the manufacture website and download the drivers selecting the right operating system
May 18, 2010 | Insignia 2.0 Speaker System (2-Piece)
My computer keeps shutting down randomly. Also when i try to use F10 it will not respond if i try and run error checking the system will crash/shut down or give me a black screen. Basicly it randomly...
Possibilities:
1. overheating, and automatic shutdown.
Check that the fans are working.
2. bad RAM, causing "random" crashing.
On a "good" computer, download the free 'MEMTEST86+' software, and run it, to test your RAM.
3. Leaking capacitors on motherboard, causing "voltage-spikes", leading to "random" errors.
4. Bad disk-drive. Remove the disk-drive.
Connect it as a "slave" drive in another computer,
and run 'CHKDSK' ("Check Disk") to look for problems.
Apr 16, 2010 | HP Pavilion a450n PC Desktop
Using the jump drive device
no it shouldn't crash. you can just pull it out but i guess the "proper" way is to go to MyPC right click it and click eject
Feb 25, 2010 | Kingston (DTIU3/2GB) 2 GB USB Hard Drive
My 4GB microvault wont start, it says"USB device not recognized"
This is strange as usualy these are quite reliable. It may have crashed.
If your computer is the problem then it will show in the below areas
If you are using Windows go to "control panel/ aministrative tasks/ computer management/ disc management. This will show if the disc is recognised on the system.
if not try :-
the same (control panel / administrative tasks/ computer management / device manager/ universal serial bus controller.
This will see if the card is working.
if not then the card may have been pulled out of your friends computer whilst still working. This may have caused a error on the card rendering in unusable.
Hopefuly your 4gb has not crashed.
Hope this helps
Jul 28, 2009 | Sony Micro Vault Pro USD-2G (SONYUSD2G) 2...
Hard drive was working good then just crashed now computer wont
I had a similar issue with a SATA drive i put into an older p4. I suggest you unhook the drive from the cables and reattach it, just to make sure the connections have not worked loose. If they are tight, then you may want to try a different port on the system board. Since I dont know if it is a SATA or EIDE, I can only assume that, based on size, it is SATA. SATA drives have great performance but cheap data cables. Try a different data cable, or a different sata port. If it is EIDE (40 pins) then make sure the cables are all tight, and please make sure that ANYTIME you work on the computer, you have the power OFF and its UNPLUGGED, so that you dont fry your mainboard. In my own case, the data cable was kinda loose, so it would work loose and drop the drive off the system, forcing me to crash and have to fix the cable and restart. I got a better sata cable and have no trouble.
Jul 20, 2009 | LaCie Design by F. A. Porsche 160 GB Hard...
My computer is still crashing/freezing
It may be because of an y virus or trogans in your pc. Just format your c drive and reload the operating system. And before accessing other drives and internet install any antivirus softwares and update it immediately when connected to net.
Apr 04, 2009 | HP Pavilion a450n PC Desktop
They Crashed
seem static electricty issue.
unplug computer from the wall socket and hold down the power botton for 10 sec. do the same with speakers. pluge back it should work.
hope it will help..
May 30, 2008 | Logitech X-240 Computer Speakers
Kinyo PS-107 Computer Speakers Logo
389 people viewed this question
Top Kinyo Audio Players & Recorders Experts
Colin Stickland
Colin Stickland
Jerry Umali
Larry Chandler
Are you a Kinyo Audio Player and Recorder Expert? Answer questions, earn points and help others
