Question about HHP IT5800 SR (5800sr050-0a0b) Handheld
Need to reprogram handheld SR IT5800 (5800sr050) to take out carriage returnat end of barcode scan.
My scanner doesnt press enter after each scan
what is is the model of the scanner? What you need to do is program a suffix carriage return.
Oct 21, 2013 | HP Wired Handheld Barcode Scanner
I have a royal alpha 9500 ml cash register and also a royal PS700-USB hand held barcode scanner. Everything worked great yesterday getting my barcodes in the cash and stuff, but I unplug it by accident...
the scanner comes with a programming card, just scan the barcode to start programming, then scan the barcode that says usb and then scan the barcode that says end programming, and it will start working again
Aug 11, 2010 | Royal PS700-USB Handheld Barcode Scanner
When scanning green light goes on beeps and nothing else happens.
Here's a link to the page where you can download all the manuals, software, etc for that unit. You might need to cut and paste it into your browser's address bar. Godd luck!
http://www.scanning.datalogic.com/sitefiles/gryphonlgd4300.aspx
May 20, 2010 | Datalogic Gryphon L GD4300 Barcode Scanner...
How do I get my scanner to go to the next line/box when using Excel?
In your programming manual there is a barcode scan that needs to be scanned in that adds the carriage return function. To do this you will first need to scan the barcode to put the unit into program mode, then scan the carriage return barcode, then scan the end programming code. Now when you scan a barcode the scanner will add the return to the sequence it sends to the computer. If you can't find your programming book you can download the sheets from the Symbol web site.
I hope this helps, if so please rate our solution.
Buddy
Corporate Computer
www.ccl-la.com
Apr 14, 2010 | Symbol LS2208 Handheld
{TAB} after I scan barcodes??
I just had to do this today... took me a while, but I figured it out. Download the manual from here:
http://www.modul-bio.com/media/Symbol_LS2208_Manual.pdf
Scan the following barcodes in order and it will add a tab to the end of the barcode you scan.
Scan "Scan Options" Pg 13-6
Scan "<Data><Suffix>" Pg 13-7
Scan "Scan Suffix>" Pg 13-5
Scan "7" Pg Appendix D-3
Scan "0" Pg Appendix D-1
Scan "9" Pg Appendix D-4
Scan "Enter" Pg 13-8
You should now have a tab at the end of any barcodes you scan. Hope this helps!
Mar 03, 2010 | Symbol LS2208 Handheld
Need carriage return sent after data
Download the product reference guide forr this scanner from www.symbol.com
Find the following barcodes, print them annd then scan then in this order:
scan options.
data > suffix
Enter.
This should resolve your problem.
Jun 12, 2009 | Symbol LS2208 Handheld
Carriage return before barcode
The barcodes you need are the following from the product reference guide.
Scan options.
<DATA><SUFFIX>
Enter.
If you can't find them, feel free to email me and i can provide them for you.
Mar 09, 2009 | Symbol LS2208 Handheld
HHP IT5800 SR (5800sr050-0a0b) Handheld Logo
81 people viewed this question
Top HHP Computers & Internet Experts
David Payne
David Payne
Are you a HHP Computer and Internet Expert? Answer questions, earn points and help others
