Question about Sony VAIO PCV-W20 PC Desktop
Computer keeps shutting down
My daughter gave me her VAIO-W2O and I've only had it a month or so.
Anyway, the problem is that at any given moment it will shut off on its own. In other words I might be doing some stuff on it and it will suddenly click off as if I had shut it down manually. I then can't turn it back on unless I disconnect the power cord from the back of the computer and simply reconnect it or I take the plug out of the wall socket and simply plug it back in. In those cases I can switch it back on and it will stay on for a while until it does the same thing an hour or so later. I don't know if the following is a clue or not, but the computer only does this when I'm working on it and not when it's turned on but not in use.
I'm at a loss to figure out what's wrong. If the power cord or power unit is faulty then why does the computer turn right back if I disconnect and reconnect it? Anybody have any thoughts?
  • delrayslim Feb 29, 2008
    I have the same problem with my Sony VAIO PCV-W700G, only it does not stay on for any length of time it shuts down after only a couple minutes, I've reseated the memory, didn't change a thing, the unit is so compact it's hard to get to the internal parts, I would like to reseat the ATX plug but I haven't been able to get to it, I want to check the power supply but once again tight quarters, any help is greatly appreciated
  • 1,226 Answers
If this happen when your working on to the computer it means that there some error on the programs you're working on(Please try uninstall the program that causes the errors and reinstall it again).
But if all application programs will do the same errors it means that system is failure.
sometimes errors on memory , and low voltage power supply.
try to clean memory, remove the memory and clean it with soft material.
If this not work;
maybe if your are sure that no hardware failure then operating system did error. If you don't mind i will suggest you to reinstall the windows so that all error will be fixed by it self.(note: you should backup important files)
Posted on Jan 08, 2008
  • 2,427 Answers
Yeah your system is overheating, cheack the fan in the power supply to ensure it is working propperly.
If you have a case fan ensure it is working as well..
If your processor is overheating it can give the same problem
What you can do is take the side panel off the system and put a fan there..(house hold fan like the one you sue to blow cool air across the living room) face the fan in the system and see what happens..
Let me know if it sint working so we can try something else and if it is working then all you need to do is chang your power supply fan, change or add a case fan and change the fan on your processor heatsink
Computer keeps 98 cherokee limited from any function.
What OBD Faults Codes show up?
Shutting Down-- is basically a Fail-Safe condition
You only have a couple of them, on any given vehicle,
so you pretty know where to start your testing
How can you make a statement about the vehicles
computer, without test results of the inputs & outputs,
to it?
The problem may have nothing to do with the computer
at all.
Is the battery no good?
Shuts down-- when,where, under what conditions
Do you have no fuel pressure,no spark,have to know that
-----IF----- you have the data stream avail, you can see the Freeze
Frame Data, at the moment it shuts off & even the actual time of day
Aug 12, 2014 | Cars & Trucks
What's your problem?My Sony VAIO VPCF132FX/H keeps shutting down due to heat
- Yes Jim. The Problem is Dust. You have to open the laptop case and Removed the Dust Present in FAN. If its under warranty, you can Visit the SONy Servie Center, They will do it.
Jul 24, 2012 | Sony VAIO F Series Grey Notebook Computer...
Hi I split milk tea on my vaio, when i was cleaning it the system close all program the shut down. when i try to run again the power led keep flashing but the system does not come up. Currently I put my...
Send it for servicing. The liquid may have seeped into the motherboard and spoilt something.
If you still want to try, but it near a warm, not hot heat source. It may speed up the evaporating of the persisting liquid in the laptop.
Jun 21, 2011 | Computers & Internet
May go for 6 months ok then does random reboots
I would suggest shutting down at least once a month for general maintenance such as dusting the fans off and cleaning the computer case.
If you are running for 6 months straight with out a single shut down that is negligence on your behalf to your computer & to the hardware inside. A lot of dust that accumulates may not seem like much to you but the amount that does accumulate will damage the hardware given enough time.
I hate to think of how much dust is accumulated inside it I like to give my PC a light cleaning each month. Generally a few quick hits with a compressed air canister is enough to keep the PC dust free.
Sep 16, 2010 | ASUS MB P5KPL-CM C2D LGA775 INTELG31 ICH7...
No mouse, can't navigate in windows
keep pressing ALT+F4 until the shutdown dialog appears.
Windows has the shortcut ALT+(other key) to most of it's functions.
when you press ALT you should see the letter underlined. that's the key you need to press + ALT to make the button work.
Anyway... it does have a touchpad, why don't u use it?! is it uninstalled?
Sep 16, 2009 | Sony VAIO PCG-K35 Notebook
3 month old Sony Vaio notebook keeps turning off by itself, won't even last more then a couple seconds to a couple minutes, tried system restore and defragmenting, and disk cleaning...still nothing!! could...
Try on the BIOS/System Setup and check if its turning off there as well. To entere there, start your computer up, and when you see the Vaio logo press [Delete] several times. You will see a blue screen or black with information of your computer, leave it there for as long as it takes to shut down, if it doesn't then please let us know.
May 04, 2009 | Sony VAIO PCG-K35 Notebook
Sony Vaio PCV-W500GN1 shuts down moments after startup
Hi Patrick,
How did you get on with those tests ? Any joy ?
Nov 18, 2008 | Sony VAIO PCV-W500GN1 PC Desktop
Sony VAIO PCV-RX500 Cant get recovery cds to work
since she formatted the hard drive there is no drivers for your cd rom to work
san diago rrc
16550 via esterillo
building 5
door two
san diego california 92127
Nov 05, 2008 | Sony VAIO PCV-RX500 PC Desktop
No power to the vaio
perhaps you cracked the board? I know I woulda broke it in half. A lil more info would help
Mar 08, 2008 | Computers & Internet
Phone keeps shutting off
I have had the same issue. Verizon is replacing my phone.
Dec 08, 2007 | Cell Phones
Sony VAIO PCV-W20 PC Desktop Logo
177 people viewed this question
Top Sony Computers & Internet Experts
Alun Cox
Are you a Sony Computer and Internet Expert? Answer questions, earn points and help others
