Question about Panasonic KX-T7453 Corded Phone
Contolling the volume
How do I put one specific phone handset on silent, so it doesn't ring but the other phones on the same line do. Please help
    Problem Solver:
  • 14 Answers
2 ways.
First way is a “User rated” method. That is: To turn off the ringer for that phone. Note that you will also have no ringing for internal calls as well.
Press:
[Shift key] until the RING displays above the [S2] key, press it and use the jog dial to turn off the ringer. Do the reverse to turn it on again.
Some users will turn on [Auto Answer] so they can still receive internal calls.
The 2nd way is in “Installer Programming” and will require a certified dealer/technician turn off ringing to that phone on that (or any) line/s.
Posted on Jun 27, 2008
Turning the ringer on my phone. uniden 6.0
Without the model number of your Uniden phone, I don't know which silencing feature you are dealing with.
Some Uniden handsets have a Silent Mode. To toggle this on and off, press and hold the # key (below 9) for 5+ seconds when the phone isn't in use. When the silent mode is enabled, the handset will ask for a length of time for the 'no-ring' option. If no key is pressed, then the Silent Mode will continue until the # key is held again.
Other Uniden phones have Do Not Disturb. The button to enable/disable this will be on the cordless phone base. The answering system will automatically turn on and none of the handsets will ring when this feature is enabled.
You can also set the ringer volume to zero. Depending on the phone, you can reset this by pressing the volume up/down buttons or going through the menu. Look for the Ringer Volume in the same section of the menu as the Ring Tone options.
If you need additional information, please add a comment with the model of your phone. I hope this helps.
Jun 13, 2016 | Uniden DECT 6.0 Cordless Telephone...
How do I turn off the silent mode on a Uniden 6.0 dect phone, so it will ring?
For the Uniden model D1680 & similar...
You ENTER "Silent Mode" by pressing and
holding the [ # ] key on the handset for a few
seconds until the display reads "Please Wait".
It will (chirp) and display "Silent Mode ON".
You can EXIT "Silent Mode" by pressing and
It will (chirp) and display "Handset #".
Another easy way to end "Silent Mode" is to go
to the BASE and press the [ANS ON/OFF]
button to turn off the answering machine system.
(Push the [ans] button, do not unplug the power)
"Silent Mode" will clear a moment later while the
control voice tells you "Answering System is OFF"
Now you can again turn on the answering machine
system as desired.
How do I turn off the silent mode so the phone will ring?
system as desired.
How do i turn off the silent mode
To turn the Silent Mode OFF for your handset to ring, press and hold the # key on your handset for about 10 seconds. Your handset will beep and this will indicate that the Silent Mode has been turned OFF.
Jun 21, 2015 | Uniden DECT 6.0 Cordless Telephone...
How do you get rid of silent mode on
Which specific Uniden phone do you have? For most of their phones, press and hold the # key (below the 9). If the phone is in Silent Mode, it will exit that mode. If you aren't in Silent Mode, you will see a prompt asking how long to maintain the Silent Mode. Pressing a number will set the number of hours without the phone ringing. If no buttons are pressed, the phone will enter the Always On Silent mode after about 5 seconds.
I hope this helps.
Apr 09, 2015 | Uniden DECT 6.0 Cordless Telephone...
Why is my phone on silent ?
Has happened before at many of our locations, always after being dropped. Usually the phone is not on silent, the ringer is broken. The only solution we have found is top replace the handset.
Aug 22, 2014 | EnGenius DURAFON1X DuraFon 1X System Phone
Panasonic phone says check tel line
Check cable conections from phone box on wall to base unit, make sure that the conectors are fully inserted. If possible plug a different phone into box to make sure that line is working. Hope this helps
Jun 08, 2017 | Lands Phones
How to turned off silent mode
With the phone in standby, try pressing and holding the # key on the handset for 5+ seconds. This toggles the silent mode for the D1660 between "always on" and off. If this doesn't help, check the Ringer volume. (This can be set by pressing the volume + button with the phone in standby on some models.)
If this doesn't work, please add a comment with the specific model Uniden DECT 6.0 phone that you have? There are several. Manuals for many Uniden DECT phones are available from their customer support site: http://www.uniden.com/bin/venda?ex=co_disp-view&bsref=uniden&scat=dectphones_mnl . The manuals are in alphabetical and numerical order.
I hope this helps.
Nov 22, 2011 | Uniden DECT 6.0 Cordless Telephone...
How do i turn off the silent mode on a uniden phone, ive held down the # sign and nothings happening
Silent Mode
You can silence the ringers on the base and all handsets for a specific period of time; the answering system answers any incoming calls without playing anything through the speaker.
With the phone in standby, press and hold # on any handset. The phone prompts you to select the number of hours (1 - 9 or Always On) that you want it to stay in silent mode.
To confirm, press # or just wait about 5 seconds. The phone turns on the answering system and displays Silent Mode On on each handset.After the selected number of hours, the phone automatically exits silent mode. To exit silent mode manually, press and hold # again.
If the phone is in silent mode and you turn off the answering system, the phone exits silent mode.
Multihandset Features To use the features in this section, you need at least 2 handsets.
Your base supports a total of 12 cordless handsets: the one that came with the base and up to 11 DCX160 accessory handsets.You must register accessory handsets to the base before using them. (Handsets that came packaged with the base are already registered.)Handsets that aren't registered display a Not Registered message. For registration instructions, see p. 18, or see the accessory handset manual.If a handset was ever registered to a base, you must reset it before it can register to a new base; see p. 18, or see the accessory handset manual.Conference Calling
When an outside call comes in, two handsets can join in a conference call with the outside caller.
To join a call that's already in progress, just press Talk/flash or SpeSpeSpeaker.To leave the conference call, hang up normally; the other handset remains connected to the call.
Aug 18, 2011 | Uniden DECT 2080-5 Quint Phone
I need help getting my phone off of silent mode. One of my kids put it on silent somehow and now I cannot get it to ring again.
I to am stuck in silent mode, voicemail won't work, the whole entire phone is jacked up, just because i had my phone number changed, are you kidding me?? Not ringing, not doing anything @ all, can someone tell me what to do? please thnx :)
Jun 02, 2011 | Uniden DECT 6.0 Cordless Telephone...
Panasonic KX-T7453 Corded Phone Logo
154 people viewed this question
Top Panasonic Lands Phones Experts
guyvstewart
john milligan
Are you a Panasonic Lands Phone Expert? Answer questions, earn points and help others
