Question about Ricoh 3310LE Copier
Need a part number for a 3310Le 110 vac power supply
Need a part number for a 110 vac power supply for a 3310Le. user plugged fax into an unlabeled 220vac power outlet.
  • 192 Answers
Oops!
Generally the unit should have a part number attached to or printed on it somewhere. This is for the board with the power switch attached, it's called the power supply unit, so hopefully this is what you are looking for.
There seems to be two possible options, so you will need to determine which is the correct unit you need.
AZ23 0204 - Power Supply Unit: 100V (RoHs)
H555 5010 - Power Supply Unit - 120V
Posted on Nov 13, 2009
Can the epson projector 8700ub be used in Australia with our power suppy being 230 volts? Thanks. Mr Tay thengtay@hotmail.com
Rated frequency 50/60 Hz AC Power supply 100 to 120 VAC:
3.1 A (Home Cinema 8350) 3.3 A (Home Cinema 8700 UB) 200 to 240 VAC:
1.3 A (Home Cinema 8350) 1.5 A (Home Cinema 8700 UB) Power consumption 100 to 120 VAC: Operating: 272 W (Home Cinema 8350) 297 W (Home Cinema 8700 UB) Standby: 0.2 W 220 to 240 VAC:
download the manual for this model
Techbelkin
thanks for rate me.
Jan 08, 2011 | Epson Power Supply 110/200 VAC Switchable...
Time chance pcu
here you will find the manual read to resolve this issue, thank you,
http://pdfdatabase.com/ricoh-3310le-manual-repair.html
it counts to vote, have a wonderful day
Mar 25, 2010 | Ricoh 3310Le Fax Machine, FAX3310Le...
Hi.when i m switch on the Ricoh 3310L Fax,the message is coming as shown below "time to change PCU"
Order a new PCU from Ricoh. Power off the machine and replace the pcu.
If you try and cheat it it will run for a short while and then lock-up breaking some gears. Cheeper just to order a pcu. Check Ebay, i see alot of Ricoh supplies there.
Jan 23, 2010 | Ricoh 3310Le Fax Machine, FAX3310Le...
Time on the clock is incorrect
Press [User Tools] key. Press < or > until "2.Fax Features" is displayed. Press [OK] key. Press < or > until "3.Setup" is displayed. Press [OK] key.
Press < or > until "3.Date/Time" is displayed. Press [OK] key several times to step through to time setting. Set correct time with number keys. Press [OK] key. Press [User Tools] key to return to standby mode. Reference page 60 in the Advanced Features manual.
Nov 20, 2009 | Ricoh 3310LE Plain Paper Laser Fax
Hi, we have a ricoh 3310Le fax machine that is amking a "knocking noise" anytime we recieve.
A knocking noise is typically a bad bearing, probably in the fuser. You can try lubricating the bearings (once the fuser has cooled down) and see if the noise goes away. If not, the bearings might need to be replaced in order to get rid of the noise.
Nov 10, 2009 | Ricoh 3310LE Plain Paper Laser Fax
REMOVE ACCESS CODE
Enter in the user tools and select the password cancel or machine settings and set the machine.
Sep 24, 2009 | Ricoh 3310LE Plain Paper Laser Fax
Fax not received
No, just the fax phone number.
Mar 09, 2009 | Ricoh 3310Le Fax Machine, FAX3310Le...
Date and time stamp
Here's the instructions for the date/time stamp.... I'll check on no. of pages and post that too.
Press the 'User Tools' key.
Use the right/left arrows until '2. Fax Features' is displayed.
Press the 'OK' key.
Press right/left until '4. Key Op. Tools' is displayed
Press 'OK'
Press '2222'
Press 'OK'
Press right/left until '7. User Parameters' is displayed
Press 'OK'
'1. Change' should be displayed - Press 'OK'
Now 'Refer Op. Manual: Switch 00 :xxxx xxxx' should be displayed; use the right/left arrow until 'Switch 02 :xxxx xxxx' is displayed (xxxx being a bunch of 1's and 0's).
When 'Switch 02' is displayed, the third digit from the RIGHT should be a 0. Press the '2' key, and that digit should change to a 1.
Press the 'OK'' key.
You should be back at the 'User Parameters' menu - just press the 'User Tools' key to return to the standby display.
Presto, try it out!
Please rate if this helps :)
Mar 26, 2008 | Ricoh 3310LE Plain Paper Laser Fax
Ricoh 3310LE Copier Logo
62 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
OfficeServiceAjnc
OfficeServiceAjnc
fares
Level 1 Expert
SOURAV KAPOOR
Level 1 Expert
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
