How can i connect my toshiba laptop to toshiba tv with vga to rca
How can i connect my toshiba satellite a305-s6872 to my toshiba 57h84 tv with a vga to rca cable.
    Master:
  • 956 Answers
Go to Toshiba site or send email to UK office help.
Requesting the info.
Or type in toshiba to google and surk for the info, it is there.
Posted on Nov 12, 2009
What do I need to connect a laptop toshiba Satellite L675D-S7052 to a high definition tv
Assuming what you are trying to do is make your HDTV a giant monitor, your HDTV will need analog video input capability --either a standard d-type VGA connector or RGB composite RCA plugs. The laptop has a d-type VGA output. You will need a cable that has matching end for your laptop and TV....either VGA-to-VGA (d-type) or VGA-to-composite. This will handle the vcideo. You will also need a min stereo-to-mini-stereo cable to connect the audio from the headphone output of the laptop to the HDTV.
Sep 06, 2014 | Toshiba Computers & Internet
How do we connect our Toshiba Satellite laptop P105-s6104 to a Panasonic tv
It depends on what sort of television you have and the connections that it has available. The easiest way is to get a VGA cable like the one in the image below if your TV has a VGA input connection.
mariolands_13.jpg If your TV doesn't have a VGA connection, you need to get a VGA to RCA adapter like in the image below. Majority of the TVs have a RCA input connection, so if your has one you need to get this adapter and an RCA cable.
Dec 12, 2010 | Toshiba Satellite P105-S6104 Notebook
Toshiba A305-S6834, video controler (VGA compatible) not installed appered when I installed, in a new hard drive, Window XP I need where I can find those drivers.
Your VGA card is a GMA X3100, in the GM965 chipset. You can go to http://www.intel.com/support/chipsets/sb/CS-025753.htm to download the drivers and software utility.
Mar 27, 2010 | Toshiba Satellite A305-S6834 Notebook
How can I connect my Toshiba Satellite A305-S6872 laptop to my TV?
Check your notebook for "S-Video / TV out" port that has a 7-pin jack instead of a standard 4-pin S-Video jack. Check your laptop before ordering this adapter.
The newer your computer is, the better chance that it comes with either a RCA Composite or SVIDEO connection. Some notebook computers also have video outputs on them. When buying a new computer always look for the words "TV out" or "video out" in the computer description.
If you only have a VGA connector and don't have an HDTV then your best choice is to buy a newer video card with an S-Video connector. There are other third party solutions out there but the quality is very poor and we do not recommend it.
The VGA port is the connector that's connected to your PC monitor (the TV like device that came with your computer). This connector is usually only usable for VGA Monitors or HDTV setups. If you have an HDTV this will give you the best image possible.
If you have an RCA Composite connector on the back of your computer, then you can use that. You may also need to power down your computer and reboot to be able to get the signal. You need an RCA Composite cable that will be long enough to reach from your computer to your PC. Connect the cable to the back of the computer to the back of your TV SET.
S-Video is superior to that of RCA Composite and will give you a clearer picture. If you have a fairly new TV you should have this connector in the back. You will need to buy an S-VIDEO cable, which you can buy just about anywhere you buy home video products. Connect the cable to your S-Video on the back of your computer and then connect it on the back of your TV
Jan 01, 2010 | Toshiba Satellite Laptop
My toshiba a75 cant connect to my lcd hdtv through s-video port or vga. i used an s-video to rca cable and a vga to rca cable but neither worked
Use the Fn key plus F5, F8 or F9 to change display to external
also you may have to change laptop's screen resolution to lower for lcd tv to display
Dec 22, 2009 | Toshiba Satellite A75-S211 Notebook
I have a vga to rca cable to connect my laptop to tv...why won't it work?
The VGA cable/connector has 15 pins and the RCA only 2 --- how would you know which to connect where, I know I wouldn't want to guess! Without knowing what it is hooked up to, no way to make it work.
Oct 03, 2009 | Toshiba Satellite A305-S6859 Notebook
Connectiing toshiba satellite 2210 to a tv set
The cord you need will either be VGA to S-Video or VGA to RCA depending on which port is on the tv.Once you have the cord hooked up to both,You will need to switch into presentation mode on the laptop using the FN + F7 keys.
Please take time to rate this fixya
May 14, 2009 | Toshiba Satellite A205-S4617 Notebook
Can i connect toshiba satellite a205 to tv?
Yes VGA carries RGBHV--RGB and Horizontal and Vertical Sync information along with DDC info where available.
Now is that port on your TV a d-sub 15 pin standard VGA connector?
http://en.wikipedia.org/wiki/VGA_connector
If it is, then yeah you should be able to output VGA from a PC to the TV with a proper cable.
However if the TV has DVI or HDMI connections on it, it's better for you to connect it that way. DVI/HDMI is a digital signal and if it's a digital-based display tech TV, then you're better off using that. Also if the TV does resolution above 1360x768 (i.e. if it does 1080p) you can get higher resolution by going via DVI/HDMI...
Dec 01, 2008 | Toshiba Satellite A205-S4617 Notebook
Computers & Internet Logo
344 people viewed this question
David Payne
David Payne
