Question about Brother MFC 420CN All-In-One InkJet Printer
How do I get the copier to do a legal-sized copy?
    Master:
  • Brother Master
  • 956 Answers
Its all contained with in your setup printer menu.
Posted on Nov 12, 2009
Copying legal size on a Brother MFC 7420
This is for a temporary, as needed solution: Press "Menu/Set" button. Select "General Setup". Scroll down and select "Paper Size", find and select "Legal" size. Press Menu/Set button again. Press "Stop/Exit" button.
Insert legal size paper to be copied on the feeder tray and put a legal size paper in the Manual slot. Hit "Print"
You need to do these same steps again to return the settings to Letter size again.
May 09, 2012 | Brother MFC 7420 All-In-One Laser Printer
How should i do photo copy of legal size
oh legal size you mean 8 1/2 x 14 in?
if that's what you mean, first we have to identify if your machine is set US standard. there you will be able to copy legal size. Otherwise if JP/EU standard, you can only copy 8 1/2 x 13 as the nearest size.
please check it first
if the sizes on the scree you see are A4, A5, A3, FLS, then your machine is set to JP/ EU standard. If you see LTR, INV, LGL, LDR, then your machine is set to US standard, and just select LGL for you to copy legal size.
that's it
May 20, 2010 | Panasonic DP-8016P Copier
Legal size copies
Your printer doesn't support Legal size to Scan and Copy, you can scan/copy it by reducing the size of the paper from the menu. 10% will fit since the actual paper size supported by your printer is 8.5X11.7inch while the legal size is 8.5X14inch. Good luck. For more info check out here : http://h10010.www1.hp.com/wwpc/us/en/sm/WF06b/18972-18972-238444-12019-3328086-2511708-3643610-3643611.html
May 15, 2010 | HP Officejet Pro L7590 All-in-One InkJet...
I cant copy legal size
Be sure to set Paper Size to LGL (14 inches long)/FLSP (13 inches long).
Additional Function > Common Settings > Reg Paper Size > Drawer 1 > Select right paper size
Jan 25, 2010 | Canon imageRUNNER 1023iF Black and White...
Sharp 5516 n legal duplex copying is not coming
Duplex unite only use a4 size not other size.You can try other size before configure.
Dec 14, 2009 | Sharp AR-5316 Advanced Digital Imager...
Coping Copies of Legal Size
For either a Printer or Copier, the 1st thing is you have to use full-size LEGAL paper. If your copier won't accept this, then you cannot do it. It has to fit in the paper tray.
Second, use the setup menu of your copier and set paper to 8.5 by 14 or LEGAL size, for a Printer
goto Start, Settings, Printers and Networks and find your printer/copier, Right click it, select Properties, select General or Paper tab and look for Advanced Settings. There you will find Paper Size pull down. Change it to Legal, Click Apply, Click Close
Done!
Mar 26, 2009 | Office Equipment & Supplies
CANON IR2000 CANT PRINT MORE THAN 1 COPY
You just stated the problem yourself!!!!!!!!!!!!!!!!!!!!!
Are you using Letter or Legal?? then the tray need to be set to that particular size.
If using Legal set to Legal, otherwise the machine will automatically know you are using the wrong size.
Aug 14, 2008 | Office Equipment & Supplies
How do i get my printer to print a legal size copy
In your printer settings as you hit print
select the printer setting prefferences
select paper size( change from letter to legal) and your problem is solved
When you copy through the software program from brother you can change this in there. Just redo the prefferences.
Apr 28, 2008 | Brother MFC 8500 All-In-One Laser Printer
Legal Sized 2-sided Copies through Automatic Feed
Does the copier print correctly when copying off the glass? I suspect that the document feeder has been set up to feed other paper sizes eg A4, A4R. Because of the conflict between sizes the copier adjust the image.
Oct 05, 2007 | Canon imageRUNNER 5000 Copier
Brother MFC 420CN All-In-One InkJet Printer Logo
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
