The fault i have with my technika tv is every time i turn the volume up on the handset it changes channel
    President:
  • 1,779 Answers
Change your batteries first. If it still does it then I would have a service company look at it.
Posted on Nov 12, 2009
I have a tv that turns off if I try to change the volume.,it restarts by itself 5 minutes later. It happens from either of 2 remotes and the volume button on the tv. Any idea what I should replace?
power fault the drain on changing channel which is around 3 volts is draining the tv a weak capacitor is probably the problem. to add to if you turn the volume up it will probably jump up and down on sound.
Jun 30, 2017 | Televison & Video
Technika tv
You might need to set up the channels in the menus. Try auto scanning the channels. Read you operating manual on setting up the TV.
Oct 23, 2013 | Televison & Video
Sanyo DS31590 no remotes will work, will not turn on power or volume but changes channels
If you can control the TV by using its front panel controls, and only remote control is not working, the fault may be either to its remote control handset or to the remote sensor inside. The remote sensor is a small component, having only three solder terminals and will look like this. 7_12_2012_12_53_47_pm.jpg7_12_2012_12_54_01_pm.jpg
This is the component inside the TV which senses the infrared rays emitted by the remote control, and convert it to digital signals, and send to the microcomputer section circuit to process. This component can be located just behind the infrared remote window at the front panel of the TV. You have to open the TV to access it, and to replace it. Just check your remote for its infrared emission, before going further. Just get more details about how to check a remote control from this site named 'Electro-help'. Pull up older posts there. Just check this link, and locate the site named above.
Jul 12, 2012 | Sanyo DS25390 TV
User guide for a technika sc 500172
hi i have a technika tv but when i tune it in i dont know how to lock them in
Dec 28, 2010 | Televison & Video
Faulty technika tv
A good way to test if a remote is working is to get a normal phone that has a camera on it.
put the camera option on the phone and point your remote at the camera phone. Press the button you believe to be faulty. whilest looking through the phone. if you see a little white light the button is working fine if not try a few of the other buttons to see if its the hole remote that is at fault.
the way this works is camera phone's dont like IR (infrared) so this will show as a little white light on your camera phone.
if it is the remote you could always buy a sky digibox remote. as the Default code will work your Technika tv. ie volume, channels, power, also the help button will change your source/av on your telly.
Hope this helps
Cheers
Little Dish Fitter
Sep 02, 2009 | Televison & Video
TV powers on and then cannot change channel or change volume???
The fault may be the control panel, or it may be in the uPC itself.
Most of the time, it is some of the switches on the control panel.
The most common cause of this type of failure is that many times when people clean the TV set, they spray cleaner directly on the screen or the set. The liquid runs down in to the set and causes damage. Sometimes the damage can be very expensive!
If the fault is just the control panel board, this can be easily replaced. You can order one from the manufacture's parts department or from one of their parts distributors.
You will need the service manual, a scope, and a DVM to troubleshoot the problem if it is more involved than just changing the panel. The only way to know is to try the panel unless you have a way to test it.
Jerry G.
Jun 30, 2008 | JVC AV-27D302 27" TV
Instructions on how to change channels on TECHNIKA MODEL TA-13
Basic Instructions for Technika Model TA-13
On this model there are 7 buttons:
Left to Right these are:
PTT, Push to talk on lh side as screen faces you.
Power/Menu
Scan
Call
Down
Up
Torch Light (on rh side)
Assuming you have used the power button to turn on the radio, the default channel after installing the batteries is 1 or else the last channel to be used.
Press the power/menu button once-briefly, (the current channel will flash for about 10 seconds.) Then use the Up and Down arrows to change channel. Wait for the remaining few seconds and the radio will return to normal operation.
Press the menu button twice, the letter H or L will appear and can be altered by the Up and Down keys to change the power level of the radio. I think this is transmit power which may help you avoid infuriating local taxi companies. Switch back to High power when you're about to go out for the night and need a ride.
Press the menu button three times. This will turn off Squelch control and make a terrible din. Not terribly useful unless you want to pick up a really weak signal (or find out where the taxi driver has taken your neighbour.)
An easy way of finding a channel is to press and hold the Scan button and then the device will rotate through the available channels looking for a signal. When someone transmits, the scan will pause and you can capture it by pressing the PTT button for a second or two. I have found this helpful in pairing my radios with other sets, or picking out channels that work with friend's radios.
Finally, Volume control is really simple, just up and down when not in any other mode.
I had the instructions, which I think included a mention of all available channels I'll scan and post them if ever I find them. hope this part helps though.
Jan 29, 2008 | Radio Communications
Televison & Video Logo
118 people viewed this question
Top Televison & Video Experts
