Question about Element ELC-HS321 32 in. LCD TV
HDMI IMPUT NOT WORKING...NO SIGNAL.I HAVE A 32'' ELEMENT LCD I BOUGHT FROM CIRCUIT CITY IN 2007 AND HAS BEEN WORKING FINE UNTIL YESTERDAY WHEN A BLUE SCREEN SAID NO SIGNAL.HAVE YOU HAD SIMILAR PROBLEMS WITH THIS MODEL? COULD IT BE THE CABLE OR IS IT THE IMPUT?
    President:
  • 2,187 Answers
The only was to be sure is to try a different device connected and cable. Try the device you has issues with your TV on another TV if you do not have other devices. Try also a different port to check if the physical port has gone bad. If all would not make a difference, your digital board may have gone bad.
Posted on Nov 12, 2009
I have aelement tv that I only bought no more than two years ago and I am having problems connecting my PS3 to the tv. I change the source to all of the hdmi channels and the screen stays blue.
Sounds like u have the wrong hdmi lead or try turning off the computer n go to setting on tv and make sure its setup for hdmi hopefully that should work
Aug 30, 2016 | Element ELC-HS321 32 in. LCD TV
How to fix issues whith component outputs on haier hlh26atbb 26 in. lcd ?
When you make the connection with HDMI are you changing the source or input key on the television to activate HDMI port? If you don't activate the corresponding source you connect to and leave the TV in the TV mode, you won't actually see the device you are connecting. It's possible the TV does not support the 1080P from your PS3.
Apr 17, 2015 | Haier HLH26ATBB 26 in. LCD Television
How do I fix my Element 55" LCD TV?
Fault with the main power supply regulator board. Check and replace damaged component/s at its main power regulator [SMPS] section circuit. Contact any service technician. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts.
It will be best to replace the power supply regulator board as card basis rather than making "Surgery" to it; which usually will make loss for both money and time. Even though you can make it right, it will cost around an amount equal to the cost of a new board; including the cost of (spare parts + service charge) More to say, most of the spare parts to it will be difficult to get from open electronic spare part market. This is true to most of the flat panel TV power supply boards; irrespective of its brand and screen size.
Jan 23, 2015 | Element Televison & Video
On pic no sound blue srceen when turned on
NORMAL OPERATION. Blue screen is a volume cutoff feature when there is no signal. Turn blue screen off in the menu if you want sound when there is no signal. Another option cycle through the input sources until one is found if there are some attached and working.
Apr 13, 2010 | Element ELC-HS321 32 in. LCD TV
Problem with remote control for my new Element brand tv
look for a button thats says tv/vcr, input, or a/v and it should switch your input.
Dec 25, 2008 | Olevia LT32HVM 32 in. LCD Television
Lcd to pc
YOU MUST GO INTO YOUR COMPUTER CONTROL PANEL TO SET THE DISPLAY SETTINGS FOR YOUR LCD.
Sep 28, 2008 | Sharp Aquos LC-46D62U 46 in. LCD HDTV
No Signal HDMI
Had the problem. Turned out to be a defective hdmi port circuit board.
Aug 04, 2008 | Insignia 42" LCD Flat-Panel HDTV
Lc-42d62u 42in.
This is a common issue with HDMI. Try unplugging the TV for 2 monutes and also reset the cable box as well by inplugging.
Feb 10, 2008 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
Element ELC-HS321 32 in. LCD TV Logo
529 people viewed this question
Top Element Televison & Video Experts
Joseph Hoffmann
Are you an Element Televison and Video Expert? Answer questions, earn points and help others
