Question about Kodak ESP 5 Printer
Cannot install Kodak AiO ESP 5 printer in Windows 7
I have an HP desktop running Windows 7 and I am trying to install a Kodak AiO printer (ESP 5). The software will not install.....crashes at the same point every time I try. When it says it is installing the driver, it fails. I have been in touch with Kodak tech people, both by phone and email, and there repeated attempts and solutions have not been able to resolve this issue. I have the latest Windows 7 version of the software, so I don't know what to try next. The printer worked perfectly in WIndows Vista, but now I can't even get it installed.........
  • deejay390 Dec 30, 2009
    same problem. Did you find a solution?
  • 295 Answers
Kindly call 1800 421 6699 and ask for a supervisor straight away.The representatives can connect you to supervisor after taking your informations.The supervisors can remotely access your computer and get the software installed on your computer.
Posted on Jan 01, 2010
I have a Kodak esp 7250 printer that will only scan a picture from my laptop runing Windows 7 using older AIO Home center software (5.4.vs my desktop computer running Windows Vista that rescently had the...
Mabee the hard drive has failed . try entering bios and see if the hard drive is recognised .If not try turning the computer off unplug it then reconnect the drive data cable and power cable
then re- start the computer and see if it is recognised. some models of older hard drives needed a driver installed during set up -- you usually have to put the driver on a floppy disc and hit the f6 button when prompted by windows set up to install third party drivers . I hope this helps
Apr 08, 2011 | Kodak ESP 7250 All-in-One InkJet Printer
Am I correct in thinking Kodak ESP 3 AIO is not compatible with Windows 7 XP x64? I can print and copy but cannot scan either directly from the button on the printer button or via Kodak Home Center
Hi There,
If you've installed the software at the link below already...
http://support.en.kodak.com/app/answers/list/p/5/session/L3RpbWUvMTMwMTM1NjI3NC9zaWQveldEWnY1cWs%3D%2Fselected%2Ftrue/selected/true#s=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..
then the answer would be yes. If you haven't install the software and see how things go.
Regards,
Selk
Mar 28, 2011 | Kodak ESP 3 Multifunction Printer/ Copier/...
The disk to install my Kodak ESP 3 is broken. How can I install it without one?
You can get the latest software for your machine, direct from Kodak here.
Just enter your model and search.
Mar 12, 2011 | Kodak ESP 3 Multifunction Printer/ Copier/...
I just bought A Kodak esp 3250 series AIO printer. I can print from computer, copy and all that but whenever I try to scan to computer or even preview scan I get a error saying :An error occurred while...
Try a new USB cable. Scanners require bidirectional communication with the computer and thus can fail when printer itself works. (If you use a print server or USB hub, try a direct connection.) Also try changing USB ports.
Another thing to try is to remove the TWAIN driver and reinstall it. This requires the original software CD from Kodak.
1. From your computer desktop, click Start > Run. (In Windows 7, type run in the search box then click on Run.)
2. Type %windir%, then click OK.
3. Double-click twain_32.
4. Right-click Kodak, then select Delete.
5. Insert the KODAK All-in-One Printer Software CD into the appropriate drive, then go to D: > printer > scanner.
NOTE: The CD is indicated by D: above. The CD drive may be a different letter on your computer.
6. Double-click aioscannr.msi, then follow the instructions to remove it.
7. Go to D: > printer > scanner, then double-click aioscannr.msi, and follow the instructions to install the file.
8. Open Home Center Software:
a. Select Scan Documents and Pictures.
b. Scan a document.
Unfortunately, if the error persists, the scanner may need service. Contact Kodak: http://www.kodak.com/go/contact .
I hope this helps.
Jan 06, 2011 | Kodak ESP 3 Multifunction Printer/ Copier/...
I have a Kodak AIO 5 printer and Windows 7. I
This is easily accomplished using Kodak AIO Home Center v5.3:
Scanning documents from Home Center
1 On the main screen, click Scan Documents and Pictures.
2 Place your original document face down on the scanner glass.
3 Select Document.
4 Select the type of document you are scanning.
5 Select a Resolution for your scan from the drop-down list.
6 Select Perfect Page Technology to automatically correct imperfections in the scan.
7 Select Next.
8 On the Edit screen, edit each image as needed.
9 Click Next.
10 Select Save to File, then select Save As (pdf or rtf), Then Save.
11 Select Done to return to the main menu.
Jul 21, 2010 | Kodak ESP 3 Multifunction Printer/ Copier/...
Installation software failure Kodak ESP5 failure to install AiO
I have bought a kodak esp 5 printer but it did not come with the installation disc can you help?
May 09, 2009 | Kodak ESP 5 Printer
Kodak esp 5 won't scan to computer
Here is the solution I found on the Kodak ESP 5 Support Center web page. Hope it helps or else maybe just visit the web page and browse it to see if you can find the solution to your specific problem.
Question : How do I scan from my all-in-one printer using MICROSOFT WINDOWS Imaging Acquisition (WIA) Drivers on a computer running WINDOWS VISTA Operating System? Answer : For computers running WINDOWS VISTA Operating System:
  1. Click Start > Programs/All Programs, and select Windows Photo Gallery.
  2. Click Scan at the bottom of the Windows Photo Gallery window, then click New Scan at the top of the window.
  3. Select KODAK ???? AiO (where ???? is the model number) from the Select Device window, then click OK.
  4. Click Preview and make whatever adjustments needed to achieve the desired scan.
  5. When you have made the desired adjustments, click Scan.
    During scanning, the progress is displayed.
    When the scan is complete, the file is displayed in the Windows Fax and Scan window, along with a preview of the file.
  6. Click Save as... to save the file, or click the Print icon to print the file from the Windows Fax and Scan application.
Feb 28, 2009 | Kodak ESP 5 Printer
Kodak ESP 5 Printer Logo
493 people viewed this question
Top Kodak Office Equipment & Supplies Experts
Are you a Kodak Office Equipment and Supply Expert? Answer questions, earn points and help others
