Question about Electrolux 21.0 Cu. Ft. Upright Freezer - Stainless-Steel
Freezer model LFFH2067DW2 - shut the door on an extension cord that left the door cracked open overnight. The alarm was on and has not cleared after four hours. How do I clear the alarm?
  • keije Nov 12, 2009
    The manual is somewhere. There is no button to push - only the on/off switch for the alarm.
    Thanks.
  • keije Nov 14, 2009
    The alarm cleared overnight.
  • Electrolux Master
  • 2,605 Answers
Hi, It likely will tell you in your owners manual, but if you push & hold the alarm button it should stop after several moments ( I think it may actually be 30-60 sec.) That should reset the alarm. However, if the thermistor senses the temp. to be too warm the alarm will return. Hope that helps, let me know. Good luck.
Posted on Nov 12, 2009
  • Mark MacDonald
    Mark MacDonald Nov 14, 2009
    Sorry I couldn`t get back to you sooner, I was working late today.
    OK, I was able to pull up your model of freezer. It should have a rocker switch at the bottom right hand corner by the grill. Along with the switch will be a red/orange light and green light. You should be able to toggle it off until the unit is cold enough to satisfy the alarm if it hasn`t already.
    Hope that helps, good luck.
    macmarkus :)
I need a manual for Frigidaire LFFH2067DW2
Good Afternoon Friend,
I understand that you are in need of a manual for your Frigidaire freezer, model# LFFH2067DW2. I also see it is barely cold inside your appliance and the door is easy to open. I would suggest contacting the manufacturer for a copy of the owner's manual. In regards to your freezer being barely cool and the door opening easily, it sounds like the seal might possibly be compromised. I suggest checking the seal of the door, making sure that it is not damaged in any way. I ask that you please follow up with a comment on the post, at your convenience, to advise if further troubleshooting is needed or if your appliances status has changed successfully. Hope this is helpful.
-Best Regards-
WP
Jun 17, 2014 | Frigidaire 20.3 Cu. Ft. Frost-Free Upright...
Ridare freezer alarm goes off and it wont freeze ice c ream
Hello grega1959 - If the temperature of food rises to an unsafe level, the buzzer will sound and the red light, if equipped, will also glow. First, deactivate the alarm to the unit. This can be done by either by unplugging it or flipping the household circuit breaker. Wait approximately ten minutes and then turn on the freezer. After deactivating the alarm and the unit has run approximately four hours, the red light/alarm should go off on its own. If the red light/alarm continues to stay on, the freezer may possibly have a communication problem with the temperature control, control board, or a wiring harness. If this is the case, I would recommend connecting with a professional appliance tech for a clear-cut diagnosis.
Apr 14, 2013 | Frigidaire 20.3 Cu. Ft. Frost-Free Upright...
My kenmore frostless 16 upright freezer alarms
kenmore elite, alarm kept going on and b flashed on and off. I finaly figured out on bottom of freezer there is a battery door open it and change 9v. thats it,
Jun 05, 2010 | Kenmore 16.7 cu. ft. / 473 liter Upright...
20.3 cu. ft. Upright Freezer GLFU2067F: We have an upright frigidaire 20 cu feet that is a...
Sounds like frost bulidup from door being left open warm air gets in making frost and ice. Need to turn off for 24hrs or so to let all the ice melt compleatey then turn back on keep door closed run for 24hrs check Temp. shoud be about 0 to -5 Deg. if good start using.
May 17, 2010 | Frigidaire 20.3 cu. ft. Upright Freezer...
Upright Frigidaire Freezer, Model#: MFU14F3GW9 It's approximately a 7-9 year old upright freezer. I believe the door may have been left cracked for an extended period of time, but I'm not positive....
if the doors shut okay,and there is no frost,and it is maintaining a steady internal temp(-18C to -20C) why worry.......anything else is going to cost money.......
Apr 05, 2010 | Freezers
I left the Freezer door open and now it seems like the freezer is not cold enough to freeze things. It has been 5-6 hours since it has been closed. Is it just taking a long time to completely cold or...
Place a glass of lukewarm water on one of the freezer shelves. Leave the freezer door closed overnight. Check the water in the morning to see if the freezer has brought the temperature down. It takes quite awhile for refrigeration units to recover from heat loads such as door open for extended periods of time.
Jan 06, 2010 | Freezers
Can't get alarm to turn off while temperature stabilizes
My wife solved it for me :-) You turn the alarm off with a switch at the bottom. The alarm turns off, but the light stays red for another 4 hours. After that the red light goes off too, and you can turn the switch back on without the alarm going off, if the freezer is back to operating temp.
Aug 06, 2009 | Frigidaire Upright Freezer FFU12F2H
The door was left open and now the alarm will not reset.
May have to wait a couple of days until the defrost cycle goes thru a few times so the moisture (frost ) will clear from the coils and freezer starts cooling normally . Should be fine after that .
Jul 18, 2009 | Frigidaire 14.1 cu. ft. Upright Freezer...
Freezer door left open
if the alarm is sounding its probably trelling you the freezer is at too high a temperature. plug it in and leave it plugged in, it can take several hours to re freeze
Sep 16, 2008 | Kenmore 20.3 cu. ft. / 575 liter Upright...
Electrolux 21.0 Cu. Ft. Upright Freezer - Stainless-Steel Logo
858 people viewed this question
Top Electrolux Freezers Experts
AJMAL KHAN
Dennis Boxerman
Are you an Electrolux Freezer Expert? Answer questions, earn points and help others
