Question about Kenmore Oasis HE 27082 Top Load Washer
Kenmore elite oasis he top loader
During washing cycle error code f comes on and cycle stops why? plz help
  • 7 more comments
  • dlove010104 Jun 30, 2008
    Mine gives me the error code F-1 when it is filling. It appears to have something to do with the lid locking mechanism. Because the light for that doesn't come on for a few seconds after I hear the click. It will also stop and give the same error when it is beginning to fill for the rinse cycle.
  • wendyfry5481 Jul 29, 2008
    My machine seems to flash the F-1 and beep as well. I stop the cycle and then restart. It seems to work after that. I don't think this is a longterm solution, but until I can figure out what is wrong with it, this is what has to work. I've called 1-800-4-MY-HOME to get the washer fixed since I am still under warranty. I will post to let everyone know what the problem was and the solution.
  • coolintx Aug 05, 2008
    I too get the F1 error code everytime I start the washer. So in answer to dlove's question, no mine is not followed by a 51. Several times during the filling cycle and when the rinse cycle starts, the machine will stop and flash the F1 code and I'll go and rearrange the items in the washing machine because it seems to be a balance issue... maybe that's my imagination. When I get it balanced it seems to work okay, but we literally have to babysit this machine. The repairman is coming out tomorrow, so I'll let you know what he says. I have read on other posts that many others have the same problem and that the entire computer module had to be replaced. I have the extended warranty, but others have had to pay $350 (approx) to fix. One said the repairman told them to stay away from appliances that have a computer and to stay with the good old stand-by appliances with dials. I am VERY frustrated with this machine and will never buy a "high tech" machine again!
  • Anonymous Mar 20, 2014
    starts to fill then stops and flashes F4 code
  • Anonymous Mar 23, 2014
    Running oasis he through cleaning cycle
    Kenmore elite oasis HE error code S2
    model 110.82042700 error code F82
    F82 error code
    stops during washing cycle
  • 125 Answers
Is it an f code followed by a 51?
Posted on Jan 21, 2008
  • Barbara George Apr 07, 2013
    don't know what the f code is. but latch lock is broken off now as we had to force it open because it wouldn't unlock at all. also had code dL
Please help me: I get the F-1 message and need to know what is the problemMODEL: 110.27032600thanksMs. Arango
Posted on Jun 04, 2012
I'm sorry. I meant in response to benham's question, no mine is not followed by a 51.
Posted on Aug 05, 2008
Kenmore oasis HE Top load Washer stopped in the middle of a cycle. No power and will not unlock
error code? totally unresponsive? try reseting power then if unresp. replace main control. verify 120v into board. 3 screws on rear of console and lift.
Sep 16, 2012 | Kenmore Elite Oasis 27052 Top Load Washer
My Kenmore Elite Oasis washing machine has error code "UL" while in rising cycle and stop. Can you tell me what is the problem and how to solve it.
My Kenmore Elite Oasis washing machine will drain but not spin and it keeps jumping back and forth to different time cycles. It continually reads "UL" and I keep trying to adjust and balance the load but it does not help.
Jun 25, 2011 | Kenmore Elite Oasis 27052 Top Load Washer
My Kenmore Elite Oasis washer unbalanced signal seems to be very sensitive. Only after several tries of readjusting the load to get it really even that the washer will spin without stopping. I made sure...
If the washer throws an UL error code with out any clothes in the washer then the issue must be concerned with the mechanical alignment inside the machine or a bad CCU.
The most common problem which can cause this is some sort of mechanical hinderance which does not allow the basket to move freely.
The suspension system which holds the basket in its place might be faulty and causing the unbalancing. In this model i think there are plastic ring at the bottom of the basket . Even if they are worn out or moved out of position it may cause the UL error code you are facing
Nov 09, 2010 | Kenmore Elite Oasis 27052 Top Load Washer
F51 error
Hello, the F51 code is a motor rotor position sensor failure. It's best to call in the warranty service as there is a bunch of tests that need to be run to determine if it's the sensor or control board. If the tech wasn't any help, contact the store for a replacement.
Thanks
May 20, 2010 | Kenmore Elite Oasis 27052 Top Load Washer
Why is my kenmore elite (top loader) oasis washer HE is displaying a code of HC
The water inlet hoses are probably removed and reconnected in reverse, and then trigger the HC error code to flash indicating the hot and cold water inlet hoses are reversed. Reconnect the water inlet hoses properly and start a cycle then let us know what happens next.
Apr 18, 2010 | Kenmore Elite Oasis 27052 Top Load Washer
Top load direct drive will not spinn, but pump
oasis checks are complex if this is what it is, most likely you will have an error code, what is it? If its not an oasis, but a reg top loader, replace the motor/transmission isolation coupler.
Jun 25, 2009 | Kenmore Elite Oasis 27052 Top Load Washer
F1 error code on Kenmore Oasis He
Per Sears. To fix the problem. Unplug the washer for at least 10 min then push pause or stop 2 times and this will fix the problem.
Mar 25, 2009 | Kenmore Elite Oasis 27052 Top Load Washer
Kenmore Elite Oasis Washer Error Code F1
per sears unplug the washer for at least 10 min then plug back in and push pause or stop 2 time.
Moister can get in between the contacts,is it in a high moister environment? Try using a hair dryer on the panel to dry it out.Also unplug it to reset.
Hope this helped.Let me know by rating me
For more help go to live chat.
lenwest
Jan 31, 2009 | Kenmore Elite Oasis 27052 Top Load Washer
Kenmore Oasis HE 27082 Top Load Washer Logo
547 people viewed this question
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
