Question about HP Compaq 6710b Notebook PCw/ OfficeJet Pro L7590 All in One Printer$317 instant bundle savings (RM404UT)
When HP 6710b laptop is undocked issues arise unless it's
When laptop is undocked issues arise unless it's rebooted. the connection acts like it's lost or extremely slow. the same thing happens when using wireless. redocking the laptop does NOT resolve the issue. sometimes blue screen of death appears when i try to redock it. sometimes a single reboot is not enough, sometimes requires two to get a normal connection back. ONLY if the machine is completely shutdown when docking or undocking does the problem NOT occur. validated that the latest NIC/wireless drivers are loaded. the wireless will run fine for only 30 minutes or so undocked and then it goes flaky.
  • HP Master
  • 1,352 Answers
What OS?
this laptop came with
XP
VISTA
or W7
during its production run.... so... we start there.
up grade to 7, the other 2 have no support,
However, the HP site still has it , while the clock ticks, (the 10 year clock is about to delete support.
so get the software while still there{hint})
see below, ive guessed XP-32b ( worst case)
see this, then see the item, software solutions (21)
then see SOFTPAQ? "HP Softpaq, down load manager"
using the correct OS< get this HP software , install it. then
run it and it will load all the correct drivers to you PC like magic. (HP is best, and this is one prime example of best)
SOFTPAQ,
then play docking?
BSOD means.
XP , full of viruses, as all are now, avoid XP like plague. (OS corruption can BSOD super easy...)
Memory bad, try running it on 1 stick, at at time.
DMM sticks.(aka, RAM)
XP with wrong drivers loaded. BSOD.
same with VISTA it too is DEAD OS, now.
in the same box above. (online)
see that docking station driver?HP USB 2.0 Docking Station Driversystem software Manager Icon
Posted on Apr 20, 2017
  • Anonymous Apr 20, 2017
    posts lacking OS, are near impossible to help.
    why do that>?
    click control panel
    click system
    read. and report. please what you have.
    there is a docking driver there if you look.
    in fact all HP drivers for that old box is there still, at hp.com
    but not FOR LONG.
2 Suggested Answers
  • 24 Answers
SOURCE: IBM Thinkpad T41 docking station USB ports
Try removing all the USB devices in Windows Device Manager with the laptop docked. To do this: Right-click My Computer, left click Manage. On the right side of the window, click Device Manager. On the right side, click the + sign next to USB Devices. Highlight each device under this heading and hit Delete on your keybaord to remove all the devices in order. Then right-click Computer at the top of the list and click Scan for Hardware Changes.
Hopefully Windows will re-detect your USB devices and get them back operational.
Hope this helps!
Posted on Jan 31, 2008
Upgrade from USB 1.0 to USB 2.0 on a HP 6710b laptop with XP
I'm not convinced on this error, because I used to get the same even though I was 100% sure they were USB 2. Unless the OS or hardware manufacturer were lying.
If this matches your specs, your good. I did see several that differ, but this one is HP.
http://h18000.www1.hp.com/products/quickspecs/12685_div/12685_div.html
Nov 25, 2012 | HP Compaq 6710b Notebook
How can i connect my HP Compaq 6710b laptop to a Trinitron tv? My Tv has the three red/white coloured holes on the side
This is a good article that explains how to do it. Your going to need an s-video cable that splits into the red/white/yellow colors then hook those cable up to the TV and then make sure your TV is set to the proper input so you can get a picture. Article is courtesy of Geek with Laptop.
http://www.geekwithlaptop.com/how-to-connect-laptop-to-tv
Apr 23, 2010 | HP Compaq 6710b Notebook
My HP Compaq 6710b was fine and then just died, what happened?
First,you should check wether the connected power or Compaq business notebooke 6710b battery is OK.If There are no problem ,then there maybe some strange matter !
Sep 23, 2009 | HP Hewlett Packard Compaq 6710b Notebook...
HP 6710b , wifi activate button not work...no light on
click the link here, and confirm it helped you solve the wi-fi problem on your laptop, if not then i'll provide another workaround.
Sep 21, 2008 | HP Smart Buy Notebook
I have just purchased a hp compaq 6710b laptop from a school. it was connected to their network. i want to put a fresh install of windows xp but it keeps saying that it cannot find the hard drive. it has a...
is the hardrive a sata drive? if it is you will need to install sata drivers when you start your installation of xp
http://xphelpandsupport.mvps.org/how_do_i_install_windows_xp_on_a.htm
Aug 12, 2008 | HP Computers & Internet
Docking Station problem
You can try to update any system utilities drivers and docking station drivers. However, I found that with IBM and Gateway, when you remove a running machine from the docking station they tend to glitch just a bit and when you redock them they have issues. Your issue is the docking station attachments, I've also seen issues with the monitor only, mouse only and keyboard on the laptop, all not working. I've had a couple that if I used the "safely remove hardware" then they would work when removed then redocked, but not all machines give the safely remove hardware option with the docking station. If yours does, try that. If it doesn't and there are no driver updates or the updates don't work, then, unfortunately, I'm afraid you'll just have to live with restarting after every redock. One other thing you might try is, after redocking, do a hardware search. It may find the attachments. I know this is also a pain, but it may be easier than rebooting every time.
Jul 09, 2008 | IBM ThinkPad X61 PC Notebook
HP Compaq 6710b
It should be the third button to the right from the top byt the power button. Here is a link to a pdf that shows where everything is on your model.
http://h20195.www2.hp.com/V2/GetDocument.aspx?docid=0900a5a5821030aa&cc=bg&lc=bg
May 23, 2008 | HP Compaq 6710b Notebook
HP Compaq 6710b is hanging up in the boot up.
start in safe mode and do a system restore
Dec 22, 2007 | HP Smart Buy Notebook
HP Compaq 6710b Notebook PCw/ OfficeJet Pro L7590 All in One Printer$317 instant bundle savings (RM404UT) Logo
359 people viewed this question
Top HP Computers & Internet Experts
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
