Question about Frigidaire Dishwashers
Bought a new dishwasher and cant figure out why it wont drain
  • Frigidaire Master
  • 2,605 Answers
Hi, Curious, does this unit have a drain hose connected to a garberator/food disposer ? If so, make sure the drain "knock out" has been removed from the garb/disposer. If that isn't the problem, make sure the neccessary "hi loop" has not been removed from the tub of the dishwasher. A lot of times during installation people remove the "hi loop" to gain an extra foot or two of drain line, but it's a no-no. You can also check for wires off at the drain pump. Hope that helps, let me know. Good luck. macmarkus :)
Posted on Nov 12, 2009
The dishwasher will not drain properly
Hi
Dishwasher not draining issue usually occurs due to kinked drain pipe, clogged drain filter or drain pump. Check the drain hose for any visible clogging, remove if present. If no visible lint is present then remove then turn off the dishwasher and remove the drain hose and check for any visible clogging. If still not visible then the drain filter or drain pump is clogged and you'll need to clean the drain filter and drain pump. Also, check for any food pieces stuck near the pump impeller.
Please note that dishwashers don't drain out the complete water such that heating element doesn't overheat.
Hope this helps... Please post back for any further assistance.
Daniel
Mar 24, 2011 | Dishwashers
Wont drain water out, have replaced filter. machine beeps and wont empty out old water. Whirlpool dishwasher, model adg7440
New garbage disposal? It's happened many times in my career- customer installs a new disposal then the dishwasher won't drain so they buy a new dishwasher to find the disposal didn't have the knock out knocked out. Check the easy stuff first.
Ken
Jan 08, 2010 | Whirlpool 24 in. ADG7540 Built-in...
Dirty dishes coming out of dishwasher dirty
check your drain line it should go up from bottom of d/w and then go down to drain that is so water from sink wont back up into d/w
Oct 27, 2009 | Dishwashers
Why wont dishwasher drain?
The 'drain hose' must placed into the sink and be free of kinks and obstruction. There is a pump that is supposed to pump the water out through the drain hose into the sink. If that pump does not activate, no water will be pumped out. I suggest yo have a repair technician trouble shoot and fit it.
Oct 03, 2009 | Dishwashers
It wont drain
Your dishwasher may have food or lime/calcium buildup trapped inside it that may prevent it from draining properly, it could have a kink in its hose, or it may need a new part.
Here is a bit of about how the dishwasher types actually work, to give you a better idea of what you're dealing with and how to go about finding a solution to the problem:
The first thing you must do is figure out what style of D/W you have and a little of how it works so you can have a better understanding of what to look for. There are two basic designs, the direct drive dishwasher and the forward-reversing dishwashers. Direct drive dishwashers do not have to stop to drain the water will forward-reversing dishwashers The first thing you must do is figure out what style of d/w you have and a little of how it works so you can have a better understanding of what to look for. There are two basic designs, the direct drive dishwasher and the forward-reversing dishwashers. Direct drives dishwashers do not have to stop to drain the water will forward-reversing dishwashers have to stop the motor and start it up in the other direction to drain the water.
Thank you for contacting www.Fixya.com
Jul 27, 2009 | Kenmore Dishwashers
Wont run a cycle
Watervalve open?
If yes?
Has this unit an integrated waterstop with the hose interlocked with a flow detection device? Mine failed on that. Bought a new machine after 10 year of service the flow device was 300 dollars.
Apr 04, 2009 | Whirlpool GU2400XTPS Built-in Dishwasher
Jackson jp-24b
it needs a new drain relay box 120 volt the drain is stuck open the jp 24 were not very good machines the red lines are drain lines if you plug up the drian lines at fillup the machine will wash but now it will never drain a new drain box is not cheap i can sell you one at cost
Mar 12, 2008 | Jackson JP-24B Built-in Dishwasher
Hotpoint dishwasher
Did you have a dishwasher before? If so, you must have had a sink tail piece with a dishwasher drain coming off the side. For the connection, you may have to get an adapter to fit the end of the dishwasher drain hose to the sink tail piece. Take all pieces to hardware store if necessary to get an adapter which fits. After you connect the drain hose, make sure that the drain hose has a "high loop", meaning that the hose curls up at least 6 inches above the connection point before it goes down again. This is important to keep sink waste from getting back into the diswasher hose if the sink drain backs up.
Feb 14, 2008 | Dishwashers
Drain
Don't buy this brand anymore, and be sure all your friends know not to also. I have a GE, GSD4000J, it is less than 2 years old, I have used it maybe at most 6 times. Now it will not drain, washes with the same water, does a terrible job of washing. I own a remodeling service, I will never buy GE products for any of my jobs from this day forward. Have not been able to get any help from GE, they don't seem to stand behind their products at all, or care about their customers once you have bought their products.
Oct 30, 2007 | Dishwashers
Keeps flashing clean Kenmore dishwasher 665.17019401 need a new owners manual
i was trying to install my kenmore elite 665 dishwasher but i cant find the plug do they come with one? or were do i hook it up?
Sep 22, 2007 | Dishwashers
Dishwashers Logo
91 people viewed this question
Top Frigidaire Dishwashers Experts
Mike
Garth Jackson
Are you a Frigidaire Dishwasher Expert? Answer questions, earn points and help others
