go to the screen where you would set the clock. touch the area for hours then below press the number which dictates what hour it is. do the same process for minutes.then you hold the check mark button for a couple of seconds. actually it wouldn't hurt to do that after setting the hour and minute..Also make sure you have all your wiring connected right. Cause the wire that operates the clock has voltage all the time this is what keeps the clock running you may want to check to make sure yours does not shut off with the key, Thank You Hope this helps
Just touch the clock. It's actually your screen saver and you can then it off in your settings. But I'd you just want a different clock, simply touch the clock and it'll display another style.
Hello there.
You can do it this way:
1 Select (Clock Settings) from (Settings) on the HOME screen.
2 Touch [Clock Settings].
3 Touch the desired date display format, then touch [t].
The clock settings screen appears.
4 Touch each item, then set its numeric value by touching v/V.
5 Touch [OK].
To cancel the clock setting
Touch [Cancel] or [BACK] in step 5.
Sincerely,
Steve TM
To set the clock turn the unit on and hit the big blue nav/menu button on the tv , then touch settings on the screen , and then touch the time button . You should be able to figure it out from there . When done touch the back button
Touch the map area of the screen, touch preferences, touch the right arrow to scroll to the page that shows clock, then click the option to set clock, your choice of set manually or sync to GPS receiver. Click done when you're ready.
Just in case you didn't manage to set the time / date on your tocuh screen thermo clock, I'll try to help you from my experience (no available manual at the moment!).
1. To set the time, touch the clock icon on the upper left corner;
2. Keep touching the screen for longer than 5 seconds, on the hour area;
3. Touch the hour area until you get what you want (if you prefer the 24 hour display style, touch repeatedly until you get the right hour without the AM / PM indicator next to it);
4. Touch the clock icon again to start the clock;
5. Repeat steps 1 to 4 to set up the minutes (the hour area will be replaced by the minutes area);
6. To set the date, tocuh the calendar icon on the left hand side;
7. Keep touching the screen for longer than 5 seconds, on the year area;
8. Touch the year area until you get what you want;
9. Touch the month area until you get what you want;
10. Touch the day area until you get what you want;
11. The screen will reverse to the time display after 5 seconds if no touch.
12. The TEMP (temperature) area, if touched, is toggling between C and Fahrenheit degrees.
P.S. I don't know if it is possible to set an earlier time / date, except touching. I mean, if 2009 is on the screen and you want 2007, you'll keep touching up to 2030 and then from 1901 up to 2007.
Did you notice that this is TOUCH SCREEN? This is why you have just one resetting button. All the settings must be done using TOUCH SCREEN. So, Tap on appropriate icons on the screen and play with them till you find the right settings. Unfortunately there is no instruction downloads available on the net, so, you have to find the way around yourself.
