Question about Heavy Machinery
Shredder smoking still runs but smokes, is the bushes, if so how do you replace them?
  • gdub1 Nov 12, 2009
    I thought I had put that information in, but looks like it does not include it all in the description. Anyway it is an ALKO GARDEN SHREDDER 2400 Watt looks like this onehttp://www.mitre10.co.nz/shop/power_gard...
    what happened was I stuck a stick in which was too tough as it turns out, machine kept going but the blades got stuck, switch machine off (usually switches off itself but this time didn't), removed stick, started up machine, then it started smoking and smellling. I assume I have burnt something out or something is rubbing or I have damaged something electrical?? Could it be the bushes??
2 Suggested Answers
  • 150 Answers
SOURCE: chipper shredder seams to be
Hi astens, sounds like your high speed adjustment is out of adjustment. You didn't say what engine is on the machine. The high speed is usually on the bottom of carb bowl. Turn it in(clockwise) 1 half turn and see how that works for ya. You will probably need to adjust it a little eigther way to smooth it out. Hope that helps.
Posted on Dec 09, 2010
My electric mower is smoking. Is there something that needs to be oiled?
smoke showing -may be a little late for oiling --look and check for where smoke coming from --if bearing try oiling /lubing if motor smoking possible internal winding --bush damage
Apr 24, 2018 | Electric Garden
My bush tumble drier is smoking when drying clothes can u please give me advice on how to solve this please?
if its electrical smoke turn off dont use till fixed possible motor --element or switch can cause smoke/fire from short --if its steam your seals may need to be replaced
Aug 20, 2016 | Dryers
Why does my shredder get really hot and start smoking?
These shredders are not made to run for continuous or long periods straight. Check your manual and it should tell you the maximum continuous run time. And most importantly are you oiling the shredder? Without oil you are going to burn it out and cause all sorts of problems.
Mar 03, 2015 | Fellowes Manufacturing Powershred SB-87Cs...
Started shredding paper 4 sheets at a time. Auto function continued to run blades/motor even when paper was not being fed. Stopped using it and turned it to off position after several feeds (total of...
You should open the top up so you can see whats going on inside. take a good look at the pcb and see if its going "black" in any places(not a good sign) Remove any paper lying inside the unit...check and see if its paper, the pcb, or the motor that is "smoking"...have you ever lubricated the cutting blades.???
Once you determine where the problem is you can call Royal at 1-800-524-0799 for parts and prices if needed.
Sep 05, 2010 | Royal VF1012mx Shredder
How to fix a vacume that is smoking
any electrical unit that smokes,is ,not worth repairing
Jul 01, 2010 | Eureka 2961AVZ Bagless Upright Vacuum
I was shredding 3 papers at a time and the shredder seemed like it was running out of gas and dying. The red overload button came on. I checked the basket and it was not full at all. The motor seemed to...
Return it to the place you purchased it for the motor has a problem and can be a fire hazzard. You should be able to run 6 sheets through at a time without it slowing down.
Jun 23, 2010 | Royal SC180MX Shredder
Engine starts and runs fine until i run about 5 pieces of branch
what color is the fire at the sparkplug? if it is blue it is good, if it's red that means that your spark is weak probably your coil is weak replace your coil
Jun 05, 2010 | Yard Machines 24A452G700 205cc Briggs ...
Clattering sound, then smoke
the clattering sound was probably a stone or something that was being bounced around by the rotating bush. It jammed which caused the belt to slip and cause the smoke you saw. You can probably get away with finding and clearing the jam but I would inspect the belt just to make sure.
Nov 27, 2007 | Bissell 1697-7 Powersteamer Pro Deluxe...
Heavy Machinery Logo
75 people viewed this question
Top Heavy Machinery Experts
Bill Boyd
Daryl Gleaton
Tom Chichester
Are you a Heavy Machinery Expert? Answer questions, earn points and help others
