Question about Mitsubishi WD-73734 73" Television
Xbox 360 component cable resolution problems with tv
When I plug my 360 cable into the component imput in the front of the tv and set the cable to HD, nothing happened when i turned the console on. It only works if I set the cable to standard definition. How can I play it in 1080p like the tv was ment to play
  • fredstuck Jan 18, 2009
    CANNOT GET DISH NETWORK ON THE TV HAVE NO MANUAL, PLEASE HELP
    Problem Solver:
  • 16 Answers
You can only play hd when you have all six plugs in not just the normal 3... i had this problem too
Posted on Apr 03, 2009
How do I hook up Xbox 360 to this TV? I have no clue where all the plugs go in the back
component leads from xbox to component in on tv
Xbox 360 Component HD AV Cable
http://support.xbox.com/en-AU/xbox-360/system/connect-xbox-360-console-tv
https://www.youtube.com/watch?v=JlE2zHSoQmE
Nov 20, 2015 | Sanyo DS31590 31" TV
I can not get my component video to work for my xbox 360 with my with my Toshiba 36A43 Television
Do you get picture at all? What is your resolution setting on the Xbox? That TV is Standard Def. Plus on the plug that goes into the Xbox there is a switch for HD and non. Check and see if its swtiched over to HD. If the Xbox is trying to run in high def on a standard tv you will get no picture. Especially using the the little switch on those component cables. Hope this helps!!
PS...If this does help you please rate my level of help...Have a good day and good luck =)
Apr 23, 2011 | Televison & Video
How do i hook up my sharp 27f543e to my Xbox 360 using component cables every time i turn the HD switch on it jumps to a static mis-colored screen.i try to change it back from 720 to 480. is it just not...
U using a stantard tube tv,that why.It is an analog tv.It can't scan in high resolutions as ur Xbox require.That,why it reverse back to the resolution it can and able to scan the lower resolutions.
Dec 04, 2010 | Sharp 27F543 TV
Im plugging in all my xbox 360 cables but the game wont show up
If you have the cable that is both component and a regular a/v cable, make sure that the switch is on regular tv and not hd, then ste the hd settings to what your tv can handle and then turn it back if you need to.
Oct 24, 2009 | Microsoft Xbox 360 Console
HDMI problem with Xbox 360 to Dell TV
check that the wire coming from the xbox 360 elite to the tv is switched to hd, and the other end of the wire has the red and white for the sound pluged into the tv and that the red green and blue wires are pluged into the tv. also check to see if the hdmi cable to conected to the tv and xbox 360 elite.
Jan 06, 2009 | Microsoft Xbox 360 Elite Console
Plays dvds on xbox 360 fine, but no picture for games/dashboard
already solved it. thanks. i couldn't see the xbox settings blade because of the blank screen so switched my component cable to the tv setting instead of the hdtv setting, then i could see the dashboard in non-hd and switched the resolution to 720p while simultaneously switching the component cable back to the hdtv setting. that worked.
Jan 02, 2009 | Sharp Televison & Video
RCA D52130 52 in. Won't Display High Def
Hi!
I doubt you'll look at this 2 years later, or even have the T.V.
I have the same TV and was able to view ps3 and xbox 360 games in 1080i, but it's a little tricky. First, let me say that the ps3 is probably not the best system to try using 1080i in unless you have a 360 to help trick the tv into working.
Xbox 360
You need to first set the video to 1080i. This will make the screen display in a bunch of horizontal lines most of the time, but if you keep toggling it on and off, it eventually works. To avoid having to sit and swap between the two modes, it's easier to first set it to 1080i and confirm the setting, then go back into the settings, select 720 (first option above 1080i) and cancel as soon as the video mode changes. 95% of the time this will make it display correctly in 1080i mode. If you turn the tv off and back on, it will sometimes reset to the horizontal lines. If you restart the xbox, it will reset to horizontal lines most of the time. With the ps3, you can set it to 1080i and keep toggling it until it works, but when the game launches it can screw up again, so it's best to have the xbox on and ready with a component switch so you can fix it with the xbox then switch back to the ps3. I think the cable that comes with the tv for HD input (the component plugs don't work, they only support 480, but the vga looking input supports 1080i) - the cable is just poor quality and can barely handle the signal. I've been trying to find a better quality cable with no luck.
Hope this helps other people with this ancient beta HD input canadian tvness.
Dec 30, 2008 | RCA D52130 52" Rear Projection Television
Game mode on tv
If you have a HDTV then you need to change the resolution to 720i or 720p to support the XBox 360 HD video. If you have a standard TV (non-HD) then you'll need to change your XBox 360's video settings to non-HD. The problem sounds like your mixing up HD video signal. I really need more info about your TV. Is it HD? Or regular?
Mar 25, 2008 | Symphonic ST420FF 20" TV
360 video problem on HDTV
I need a little bit more info on the TV its an RCA what?,
In the mean time what you could try is finding someone with a HD tv and trying it out at there house so that you can single out if it is your system or the TV. This will help alot you can also try someone else's xbox 360 at your house on your tv to see if it is your AV cable / xbox360.
Dec 31, 2007 | Microsoft Xbox 360 Console
Hitachi 53SDX89BA HD settings
Problem more than likely with the xbox, as the output stream of data from the game platform is not always consistent...accordianman
Dec 29, 2007 | Hitachi 50UX57B 50" Rear Projection...
Mitsubishi WD-73734 73" Television Logo
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
