Question about RCA R52WH73 Projection Television
Changed fuse twice for convergence what esle do i need to change?
  • john regrut May 11, 2010
    if you changed the conv. fuse 2 times then you need to either replace the conv.module or the small signal module most likely the 1rst module [conv. mod.] good luck...
    President:
  • RCA Master
  • 1,779 Answers
You need to resolder all the pins on the IFT ( HV Transformer ).
Common problem with that model. While your at it, look the entire deflection board over for other bad joints.
Posted on Nov 12, 2009
Want to change to english
Ask at some public schools or libraries for some ESL classes you can take.
ESL means "English as a Second Language".
In most cities and many towns. these classes are free.
God bless your efforts.
Jun 26, 2017 | Computers & Internet
Convergence was bad. Before kit was used no audio or video
It says Zenith here and if different let me know----if the convergence failed and took a resistor or fuse device (not a glass fuse) out the set will be dead--set detects no voltage to that area and shuts down for protection.
May 16, 2012 | Zenith R50W47 50" Rear Projection HDTV
The picture on my Toshiba 55H70 is distorted. Most of the screen is fine, but the bottom left looks bent with all three colors misaligned. I tried adjusting the convergence some but it did nothing for that...
hello am rico, you need to replace your convergence ics (stk392 or 393 something esle). check for caps,fuses, resistors, cold solder in the boards. if you need more help, feel free to call at anytime. 602-810-7149.
Jan 07, 2011 | Toshiba 55H70 55" Rear Projection...
My convergence keep going out, I replaced the convergence twice. I have a rca hd52w59 modle
When you say replaced the convergence twice, are you refering to the convergence boards or the FL231 fuse? If its the FL231 fuse unless you replaced the DL231 and CL230 plus reflowed the solder on the flyback it will continue to keep blowing untill the 3 parts are replaced together and the flyback gets resoldered. If you replaced the convergence boards then try resoldering the flyback.
Nov 27, 2009 | RCA HD52W59 HDTV Projection Television
RCA R52WH77 ITC222A chassis convergence problem - FL231 changed!
did you hear an arch before it went if so , one of your crts is arching
and sorry they are not avail anymore
Sep 20, 2009 | RCA Televison & Video
I see the convergence option in menu but nothing changed
Since you have the convergence options in your menu i would figure that you do not have the common fl231 fuse problem....Now is any part of the picture good. is the picture a bow tie. if you go into red and blue manual option will the crosshairs move up and down and left and right. If you have the bowtie or push in fromtop and bottoml then the likely problem is what is call the convergence power board. if you do have some control over the crosshairs then it may be the convergence amp board. convergence is controled by three diffrent cuicit boards. if you have to replace these boards it may just may need someone like a tech to do a serivce convergence.
Jun 02, 2009 | RCA HD52W59 HDTV Projection Television
Convergence nightmare
If this is a ITC222 chassis then you need to check the fuses that are near the flyback. I would also unsolder all the pins on the flyback and re-solder them as the factory lead free solder tends to crack and cause issues with the convergence. Re-solder it with common 60/40 solder you can pick up from Radio Shack or other places.
Jun 25, 2008 | RCA D52W19 52" Rear Projection Television
RCA R52WH77 convergence missing from menu
THis is very common on these sets. there is a special fuse thats cause this.. kinda hard to get rca part number 259213.. .4 amp. the reason this blows is there is bad solder connections on the flyback. so when you replace this fuse you have to resolder these connections. so if you know how to solder and can find this special fuse. it is a fast and easy repair
Apr 08, 2008 | RCA P52937 52" Rear Projection Television
TV wouldn't stay converged them went black
There are also fuses that goes with amps and return resistors to that need replacing. To be precise you need live chat!
Oct 04, 2007 | Panasonic PT-53WX54 53" Rear Projection...
53H71
If there is no high voltage and you changed converg. amps, then there are still fuses on converg side that could be bad. Also Horizontal output could be bad. If set is dead or just will not come on and has little sound. These could be 2 different problems.
Sep 21, 2007 | Bush 5693D 24" TV
RCA R52WH73 Projection Television Logo
154 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
