Question about VitrA Aria Toilet with Round Bowl / Backsplash Tank Lid - White
VitrA #5055 toilet why will it not stop running
  • sporydzuk Nov 13, 2009
    This toilet is something I have never seen before. There is no ball, there is no chain; that would be to easy. Found out who sells it so going there to get help. Thankx though
  • 2,237 Answers
The flapper is not closing all the way in the tank. if, when the handle is at rest, the flapper chain is too taut, the flapper is not closing all the way. so loosen the chain. if there is slack, the flapper is not making a good seal and is letting water through. or if in the tank the water is going over the standing up overflow tube, you need to adjust the float. if you have the ball float, lift it up slowly and see if the water stops running. if not, replace the ballcock (valve where the float is attached. if it does stop, unscrew the ball a little or bend the ball arm down a bit until the water stops short of the overflow. if you have the shuttle float, do the same test. if the water does shut off, adjust the shuttle accordingly.
Posted on Nov 13, 2009
I ran into the same problem with the vitra 5055. I fixed it by replacing the fill valve unit ( the thing on the left hand side with the float that is wrapped around it) you can find one of those at nearly any home store and their really easy to install/replace. The cost for one is around $10-20 and the model i found if your to look for it on the internet is a Brass Craft fill valve #BCT015.
Posted on May 18, 2010
How to tighten a vitro nupva toilet seat.
Christina, how to tighten or install hidden fasteners on your toilet seat. check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Remove Vitra Shift toilet seat
Soft Close and Quick Release Toilet Seats Installation
How to fix loose toilet seat
http://vitraglobal.com/
Jun 27, 2016 | VitrA Home
Vitra
Install wax ring around base waste pipe. Make sure that 2 bolts are sticking out of a track under the toilet.Put toilet bolts through toilet holes and tighten nut with washer on each bolt to lock down the toilet. Now attache the water line that goes into toilet and bidet.
Apr 09, 2014 | VitrA Home
I have a 4.8 lt flush vitra toilet when i flush hardly any water goes in the bowal to clean the sides of paper
These new style toilets are this way by design. It is designed to use less water, thus helping the. Ecology and your water bill. In effect what is happening is that the trap is lower in the bowl , thus not letting the level of water be as high in the bowl. Now matter if you pour a gallon of water to try to fill it up, it will run out until it reaches that level in the bowl.
Feb 25, 2013 | VitrA Aria Toilet with Elongated Bowl/...
I have A VITRA CORNER TOILET DEUL FLUSH BUTTEN BROKEN AND ITS VERY SLOW TO FILL
Your water valve must be clogged with sediment in the line. It has nearly shut the water off.
Feb 19, 2013 | VitrA Home
Hi, Just moved into an apartment with two vitra retro toilets. As soon as you start to use them you can hear water running as you add waste to the toilet bowl. Is this normal? The developer tells me it...
check the type of fill valve that you have in the tank and check with a plumbing shop or better yet check your local lumber company as
they usually carry toilet replacement parts and you can read the instructions on how to adjust the one you have
Sep 22, 2017 | VitrA Aria Toilet with Elongated Bowl/...
I am trying to find a replacement cistern lid for a Vitra, can you help?
Hello. Call your local plumbing shops. Some of them store all of the used parts for this very purpose. If they don't have a lid, they may have a source nearby. Joe
Oct 12, 2010 | VitrA Aria Toilet with Elongated Bowl/...
VitrA dual flush toilet doesn't flush enough water
maybe by shortening the chain length on the flapper valve might help
Jul 24, 2010 | VitrA Aria Toilet with Elongated Bowl/...
Replacement part for VitrA cistern
I trust you mean the "Flapper Valve". They are available and most hardware stores.
Get a Universal type as they fit most units. Take the old one with you. If you turn the water off at the wall it will stop it from running while you're away
Nov 26, 2009 | VitrA Aria Toilet with Elongated Bowl/...
VitrA Aria Toilet with Round Bowl / Backsplash Tank Lid - White Logo
1,665 people viewed this question
Top VitrA Home Experts
jasbo
jasbo
woodzowl307
mrbill99
Level 1 Expert
Are you a VitrA Home Expert? Answer questions, earn points and help others
