Question about Canon PowerShot A95 Digital Camera
Canon A95 - Pink pictures
I took some outside pictures lately with perfect blue sky but low temperature 40 F. When I checked them, the sky was pink as well as some parts exposed directly to the sun. Insode, no problem.
Anyone has an idea why ?
  • Canon Master
  • 4,738 Answers
This sounds like it might be a defective CCD imager. If so, Canon should fix this for you for free, including free shipping both ways. This is regardless of your camera's warranty status. Please check the following two links for more info:
http://camerarepair.blogspot.com/2007/11/canon-digital-cameras-showing-black.html
http://www.usa.canon.com/consumer/controller?act=PgComSmModDisplayAct&fcategoryid=225&modelid=13390&keycode=2112&id=29819
Applicable cameras include:
A40, A60, A70, A75, A80, A85, A95, A300, A310, S1 IS, S60, S200, S230, S330, S400, S410, S500, SD100, SD110, IXUS V2/300/400/430/500, IXY Digital 200a/300a/400/450/500
Posted on Jan 08, 2008
Geek Squad broke my Television
Try these settings:
Picture Mode: Movie
Contrast: 100
Brightness: 44
Sharpness: 20
Color: 50
Tint: 50
Backlight: 7
Color Tone Warm1
Digital NR Auto
Detailed Settings
Black Adjust Low
Dynamic Contrast Low
Gamma -1
Color Space Auto
Edge Enhancement On
xvYCC Off
White Balance
R-Offset 21
G-Offset 20
B-Offset 21
R-Gain 0
G-Gain 21
B-Gain 26
My Color Control
Pink 20
Green 15
Blue 15
White 15
Auto Motion Plus 120hz: Low
Feb 28, 2014 | Samsung UN55C6500VFXZA 55in Led Hdtv 1080p...
How can i get the words to which fuse operates what part of the car in an 06 charger???
Hi, All the Info You Need Is Detailed Below:
Front Power Distribution Center Fuses
# Amp Description
1 20 Yellow Left High Beam Headlight
2 20 Yellow Right High Beam Headlight
3 15 Dk. Blue Adjustable Pedal
4 20 Yellow Horn
5 25 Clear Headlamp Washer If Equipped
6 15 Dk. Blue Front Control Module (FCM)
7 20 Yellow Fog Lamp
8 15 Dk. Blue Park Lamp
9 15 Dk. Blue Non ABS Brakes
10 5 Orange Starter
11 20 Yellow Auto Shutdown/Powertrain Control Module (PCM)
12
13
14 25 Clear Powertrain Control Module
15 20 Yellow Injectors, Ignition Coils
16 15 Dk. Blue Powertrain Control Module
17 30 Pink Antilock Brake System (ABS) Valves
18 30 Pink Windshield Wiper/Washer
19 50 Red Radiator Fan
20 20 Lt. Blue Starter
21 50 Red ABS Pump Motor
22 40 Green Radiator Fan High/Low
23 50 Red High Intensity Lighting
24
25 30 Pink Lighting Left High Beam/Right Low Beam
26 20 Lt. BlueTransmission
27 30 Pink Lighting Left Low Beam/Right High Beam
Rear Power Distribution Center Fuses
1 60 Clear Ignition Off Draw
2 40 Green Battery
4 40 Green Battery
5 30 Pink Heated Seat/Steering Column
6 20 Yellow Fuel Pump
7
8 15 Dk. Blue Ignition Start/Run - Start
9 20 Yellow Console Power Outlet
10 10 Red Rear Fog Lamp If Equipped
11 25 C/BRKR Memory Module/Door Locks
12 25 C/BRKR Passenger Power Seat
13 30 C/BRKR Door Module Run/Acc/Delay
14 10 Red Sentry Key/Remote Keyless Entry/Cluster
15 20 Yellow Brake Light (5.7L)
16 20 Yellow Power Outlet Trunk - if equipped
17
18 20 Yellow Selectable Power Outlet
19 10 Red Stop Lamp
20 20 Yellow Rear Wiper If Equipped
21
22
23
24
25
26
27 10 Red Airbag/Occupant Classification Module
28 10 Red Curtain Airbag - if equipped
29 5 Orange Sentry Key/Remote Keyless Entry/Powertrain Control Module Ignition Feed
30 10 Red Steering Column Module/Power Mirrors - if equipped
31
32
33
34
35 5 Orange Power Antenna/Garage Door Opener/Ignition Delay
36 20 Yellow Radio/Navigation
37 15 Dk. Blue Transmission
38 5 Orange Analog Clock/Garage Door Opener
39 10 Red Heated Mirror
40 5 Orange Power Mirror
41 10 Red Climate Control Module/Headlamp Leveling if equipped/Rear Park Assist if equipped/Tire Pressure Monitoring if equipped
42 30 Pink Automatic Temperature Control (ATC) Blower Motor
43 30 Pink Rear Defroster
44 20 Lt. Blue Audio Amplifier
Sep 13, 2012 | Cars & Trucks
Panasonic Lumix DMC-TZ3 Digital Camera: The camera LCD display is extremely dark with shadows/outlines of reddish pink hues and the same image is shown when a picture is taken. I have tried transferring...
Did u check the settings of the camcorder? see the setting there you got contrast settings if its low then you'll get dark images or its exposer meter's problem U check the exposer meter's reading and see aparture also.
Mar 09, 2011 | Cameras
Pictures taken recently have a pink tinge, eg the sky is pink and skin tones are wrong.
your settings are wrong on the brightness and contrast
some of the power shots set up by using KELVINS as the method of balancing the warmth or coolness of a picture. Others have a setting for OUTSIDE Inside Halogen and fluro If its set on halogen and you are taking pics outside it will have a red tinge.
Fluro a blue tinge...
check the manual for the right selections
please rate my help++++Thanks for using FIXYA
May 08, 2010 | Canon PowerShot S400 / IXUS 400 Digital...
Samsung LE40R
try to change the stantard from the channel setting menu(bg-dk etc.)
Jun 27, 2009 | Samsung LE40R73BD 40 in. HD-Ready LCD...
Blues are pink?
either ur blue cartridge is empty or maybe the nozzle of ur blue are clogged .normally the dark blue colour is made up by mixing of blue and pink . because ur nozzles of blue are clogged or maybe the blue is empty it prints only in pink when u command for blues.replace the blue if its empty or clean the nozzles if its clogged.
Sep 15, 2008 | Kodak EASYSHARE 5300 All-In-One InkJet...
Poor quality pictures
Check your picture settings, the wrong setting for the time of day or object can definetly throw off the appearance of your pictures. Plus, you may have accidentally set it to "warm" instead of auto or black and white, etc. Warm pictures have a reddish tint to them just as the cool have a blue tint. Also I have found the "night setting" only takes really good pictures if you are close to the subject otherwise it is pretty dark!
Aug 16, 2008 | Kodak EasyShare CX7330 Digital Camera
I'm noticing all my pictures have a pink hue to it, and pink bar on top
Hello,,,
Your Canon A80 has problem of defective CCD Imager Sensor and this part need to be replaced.
Good news is that Canon will replace CCD Imager free of cost as per announced free of cost repair scheme.
Click on Canon CCD Advisory for details how to obtain free repair facility.
Good Luck....
Jul 14, 2008 | Canon PowerShot A80 Digital Camera
Discolored pictures
This is also a CCD problem- Contact Canon for a replacement
Aug 12, 2007 | Canon PowerShot A60 Digital Camera
Blue photos
You probably needed to reset the manual white balance. Lighting conditions can change considerably in 10 minutes at sunrise and sunset.
Sep 06, 2005 | Panasonic Lumix DMC-FZ10 Digital Camera
Canon PowerShot A95 Digital Camera Logo
166 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Doberman
Are you a Canon Camera Expert? Answer questions, earn points and help others
