Question about Jabra BT2040 Bluetooth Headset
Pairing it with my new phone (rumor 2) - Jabra BT2040 Bluetooth Headset
How do i turn the bluetooth feature on for my rumor 2
  • Insert a microSD card into the slot on the right side of the phone.
  • 2 Connect the phone to your desktop with the USB cable.
  • 3 Select "Transfer Music" on the phone by pressing the "OK" key after highlighting "1 Yes" on the display.
  • 4 Go to your desktop and use Windows Explorer, which will have now opened up, and you can drag and drop files from the desktop to the phone just like another directory.
Use the Rumor Bluetooth to Connect to Your PC or Other Bluetooth Device
  • 1 Set your secondary Bluetooth device into the pairing mode.
  • 2 Open the "Tools" menu on your phone by first making sure it is in the standby mode and the slide is closed. then press the "OK" key and select "Tools."
  • 3 Select "Bluetooth" and press the "OK" key to choose "Pair with Hands-Free." If "Bluetooth Wireless Technology" is turned off follow the prompts to turn it on by pressing the "Left Soft Key."
  • 4 Highlight secondary Bluetooth device on the list of found devices and press the "OK" key.
  • 5 Enter "0000" pin code and press the "OK" key to initiate the pairing process.
  • 6 Enter the device's name and press the "Left Soft Key" for "Save."
  • 7 Connect to your device by pressing the "Left Soft Key."
Mar 01, 2012 | LG Rumor 2 Cell Phone
Cant pair phone with blue tooth
make sure your bluetooth is in Discoverable mode with BOTH devices , the try it again
Jan 02, 2010 | LG RUMOR Cellular Phone
I have a Virgin Mobile Rumor 2. and i dont know my Bluetooth Passkey. i need it to pair with other mobile phones
if you are using your virgin mobile bluetooth first time always it will be the default with zero's.
Oct 07, 2009 | LG RUMOR Cellular Phone
Difficulty pairing bluetooth to lg rumor phone
I had this problem with my LG Shine. I took the battery out, put it back in, and turned it back on. It worked!
Sep 05, 2009 | LG RUMOR Cellular Phone
I had a jabra headset that i used for my rumor. i now have a rumor 2 and i tried to pair it with my jabra, but it wont pick it up. whats wrong?
You might want to delete the Jabra headset from the Rumor first, and make sure the phone is powered off. Then put the Jabra into pairing mode (usually done by powering on the Jabra and pressing and holding until the indicator light flashes) and set the Rumor 2 to detect new devices. Once it detects the Jabra, connect and input 0000 (four zeros) and it should connect.
Aug 14, 2009 | LG Car Charger For LX150, LX260, Rumor
LG Rumor Bluetooth Music
After trying this myself with a pair of samsung headphones, I searched online and found a review that said the LG Scoop/Rumor doesn't support stereo bluetooth, so the music player probably won't connect to the headphones.
Jun 01, 2009 | LG RUMOR Cellular Phone
LG Rumor cannot bluetooth with headset
To pair your phone with another Bluetooth device, perform the following steps: 1. Press the Menu/OK key, select Settings/Tools, select Tools, select Bluetooth, select Add New, and then select Search. Your phone displays a list of discovered in-range Bluetooth devices. 2. Select a device, and press the Menu/OK key. 3. Enter the passkey, and press the Menu/OK key.
http://support.sprint.com/doc/sp10800.xml?selectedDeviceId=9207&related=y&Referring%20Related%20DocID%20List%20Index=1&navtypeid=6&pagetypeid=7&prevPageIndex=8
May 04, 2009 | LG RUMOR Cellular Phone
Motorola H715 not connecting with my LG Rumor
Do this:
Turn the headset off.
Set your rumor to find new devices, then immediately turn the headset back on. The devices should pair together. If the rumor asks for a code, the code is 0000.
Mar 12, 2009 | LG Rumor LX260 Cellular Phone
H700 wont connect to lg rumor
after pair successful highlight the headset and hit connect
Jan 07, 2009 | Motorola Mobility H700 Wireless Headset
Trying to bluetooth ring tones from motokrzr to lg rumor?
Bluetooth technology is still fairly new and it make take a few attempts to connect. Keep in mind some phones, like most Samsungs still use an older version of bluetooth software which only pairs with audio devices. So, best I can suggest is do a power cycle (remove the battery and let it sit for a few seconds and try again) to make sure there is no software loop errors that occur time to time and keep trying. If you still don't have much luck, go ahead and repost and I'll test it with some phones at the other shop and see what I can get.
Nov 16, 2008 | LG RUMOR Cellular Phone
Jabra BT2040 Bluetooth Headset Logo
Top Jabra Radio Communications Experts
TO Lady
Greg Cann
Greg Cann
Michael Vincent Cruz
Are you a Jabra Radio Communication Expert? Answer questions, earn points and help others
