Question about Ovens
I have a zanussi buit under double oven the main oven all the lights come on but no heat. it worked yesterday well top oven works and so does gas hob
  • Ovens Master
  • 3,463 Answers
If it is an electric oven and fan assisted, and the fan is working o/k, then you need to fit a new oven element, located behind plate at rear of oven.
Please rate my solution.
Thanks.
Posted on Nov 12, 2009
4 Suggested Answers
barkencoa
  • 3463 Answers
SOURCE: main oven wont work
It is the oven element that has failed
Remove panel at rear of oven compartment, there you will see the element, just undo any screws that you can see and pull the element towards you, carefully detach the wires, but don't loose them inside or you will have remove the oven to get the wires back on.
Fit new element and Bob's your uncle ,you've cracked it.
Plz leave feedback for this solution.
Thanks.
Posted on Dec 13, 2008
barkencoa
  • 3463 Answers
SOURCE: fan oven on zanussi electric cooker does not heat up
From symptons, I would say the fan oven element is faulty, more so if the fan is working. Remove inner rear panel of oven and see if element gets warm, let it run for a minute, switch off and feel if element is warm, if not, then replace.the element.
Plz rate this solution.
Thanks.
Posted on Dec 27, 2008
barkencoa
  • 3463 Answers
SOURCE: Faulty main oven
If the fan is working in the oven, and it is electrically heated, then it will be a faulty oven element.
This is located at the rear of the oven behind a removeable cover.
Posted on Feb 10, 2010
Why does my premier double gas oven not supply gas to main oven and heat, striker works and clicks but no gas, top oven and hob working ?
IF IT HAS A HOT SURFACE IGNITOR FOR THE OVEN THAT IS MOST LIKELY YOUR PROBLEM EVEN IF IT GLOWS IT CAN STILL BE WEAK
Nov 14, 2014 | Ovens
Hi We have a zanussi ZCE 7550 double oven cooker. The bottom oven broke (with a flash and bang), so we replaced the element at the back as it was burnt out. The top grill and hob are still...
Hello starsevern!! Did you get your cooker fixed, what was the problem?
I have a Zanussi ZCE7550, but apart from that I'm in exactly the same predicament as you in the post you made on Sep 18, 2010...
Can anyone help with a suggestion please???
Sep 18, 2010 | Zanussi ZDQ495 Electric Double Oven
Zanussi electric double oven. Top oven not working.
It sounds like a faulty thermostat, because when you turn the thermostat on it should supply the oven element and the neon light, so even if the element is faulty, the neon light should still come on regardless of the element working or not.
Hope this helps.
Feb 10, 2010 | Ovens
Faulty main oven
Feb 10, 2010 | Zanussi Ovens
Fan in main oven boken
Sounds as if your oven heating element has failed. You need to fit a new one.
Usually you have to get the back off, disconnect the old element, remove the fixxing screws and element, fit new one, reconnect and it should be fixed. Don't forget to switch the power off before starting work.
Dec 31, 2009 | Zanussi Ovens
We have a Zanussi built under oven (ZUF270). Last
You could but if you disable the timer and anything goes wrong with it could invalid your house insurance if anything went very wrong.
Jan 09, 2018 | Zanussi ZHQ575 Electric Double Oven
Fan oven on zanussi electric cooker does not heat up
Thanks.
Dec 26, 2008 | Zanussi ZHQ575 Electric Double Oven
Zanussi ZBQ 965(X) Built-in Oven
Sounds to like the oven element has gone, the red light indicates that power is going to your thermostat o/k.
Check the oven element.
Nov 16, 2007 | Zanussi ZBQ665 Electric Single Oven
Ovens Logo
172 people viewed this question
Top Ovens Experts
Sal De
Craig Butler
Craig Butler
Are you an Oven Expert? Answer questions, earn points and help others
