Question about Miller Spectrum 375 Cutmate Plasma Cutter 903891
Miller Spectrum 375 problem
My plasma cutter just shut off and now nothing happens when I try to turn it on. It was only on for about 30 seconds when it quit and no cuts had been made so it was cold. Now when you flip the switch nothing at all happens. Its like its not even plugged in which it is and I checked the power source. Air was at 90psi so no issue there either.
    Problem Solver:
  • 17 Answers
It sounds like you have a problem in the power supply input area. Make sure your voltage select switch is in the correct location. Unplug the unit and switch back and forth between the two positions to clean the contacts. Try again. If still bad check you terminal lug connections on the input lead wires. If still bad please answer these questions.
Does the power indicator come on at all? Does the fan start?
Posted on Nov 16, 2009
  • jefrey Otieno Nov 03, 2014
    i have the same problem av tried al the above even opened it up the machine .. there is a red led flashing on the power supply board but nothing happens
Spectrum thunder plasma cutter will not cut steady, keeps stopping and have to pull trigger to cut
Check the contactor contacts for pitting. if severly pitted, replace contactor. If a death grip on the switch makes it work better then a light touch- replace the trigger switch.
Aug 17, 2012 | Miller Spectrum 375 Cutmate Plasma Cutter...
Miller 375 x-treme fires about 30 seconds then stops it doesn't stay running, no trouble lights...
Have you watched to see if the pressure light comes on right before shutdown? If so you may need to add a tank right next to the torch base to address the pressure drop assuming your air source is able to deliver adequate volume to the cutter continuously and you currently have more than 25 feet of hose between cutter and compressor. It might not hurt to check the internal filter as well.
Dec 29, 2011 | Miller Spectrum 375 X Treme Plasma Cutter...
All lights correct, no start
loosen the retainer cap and twist the consumables and retighten
Apr 24, 2010 | Miller Spectrum 375 Cutmate Plasma Cutter...
Plasma cutter no cutting
the tech is probably pretty close to the cost of board,but you may have moisture in air that still wont take out the p.c..you have a warrenty on the unit,go to your local welding store and request a new one if refussed tell them you want to talk to the miller salesman which they should have no problem to set up.if not call miller direct in appleton wisc.they are good people.
Apr 07, 2010 | Miller Spectrum 375 X Treme Plasma Cutter...
Pilot wont lite. miller spectrum 701
check the cables in the plasma torch.
If the problem continues, theres no enough power to start it.
Jan 04, 2010 | Miller SPECTRUM 375 PLASMA CUTTER 903891...
I am looking to purchacs a slightly used miller plazma spectrum 375 from a private owner is there any common problems related to this unit that I should look for?
The main thing that can hurt these things is water. If he didn't have a water filter on the line before it enters the plasma it could destroy the unit. If you buy it try it out to see if everything works. When you install it be sure to buy a filter that they sell for these and put it on before the air enters the plasma. Around $400. to $600 to replace the parts when water meets with the components. The filter that Norco Welding supplies sells for these is a toilet paper filter and you need to check it often.
Jul 29, 2009 | Miller SPECTRUM 375 PLASMA CUTTER 903891...
Miller Spectrum 375 Cutmate Plasma Cutter 903891 Logo
927 people viewed this question
Top Miller Welding Tools Experts
Robert Lee
Level 1 Expert
Kory Ronning
Robert Monigold
Robert Monigold
Are you a Miller Welding Tool Expert? Answer questions, earn points and help others
