Question about Jenn-Air JCD2389G Side by Side Refrigerator
Jenn Air Side by Side Refridgerator
The door Ice dispenser will not dispense ice, ice maker works fine, and it will dispense water, just not cubes. Any suggestions. Capt.BJC
  • Anonymous Mar 22, 2014
    in-door water/ice dispenser: water or ice continues to come out when button is pushed then released. About 80% of time works fine, other 20% appears button is sticking or something.
  • 27 Answers
You could have a layer of solid ice at the bottom of your icetray which is binding everything up. Remove ice tray and any ice from the bottom. Reinstall and be careful of the connection on the back of the ice tray, you may have to turn it a little to get it to mesh correctly. refill and try. Good luck.
Posted on Feb 24, 2008
Ice dispenser stopped working. How can I tell it the motor blew?
look for spare part and replace it. Several site which sell spare parts.
Dec 14, 2017 | Jenn-Air 21.6 cu. ft. Side-By-Side...
Ice maker doesn't work. changed filter. light on ice maker door still on.
You need probably to change the dispenser solenoids which swith water on dispenser
Apr 05, 2008 | Jenn-Air JCD2389G Side by Side...
I have a side by side refridgerator freezer. I have just connected the water to the ice make / water dispenser for the first time and just a short trickle of water flows into the ice cube maker - not
I would guess that you need to purge the air out of the lines and system for it to work correctly. You can hold down the water dispenser for awhile to help, but if you do nothing, it should purge itself over the next few days.
Jan 07, 2012 | GE Refrigerators
We have an ice glacier building up behind and below our ice maker inside our Jenn Aire side by side refridgerator model JRSD 2450.
WATER LEAKS ON YOUR WATER SUPPLY CONTAINER TO THE WATER DISPENSER OR CONDENSATION PROBLEM RELATED TO FRIDGE DOOR FAULTY SEAL
Nov 09, 2010 | Jenn-Air JCD2389G Side by Side...
Model JCD2389GEW - ice/water dispenser does not work. Until recently, it did not do anything on any of the settings (water, cube and crushed ice) now it crushes ice on all three settings but the door does...
We have a Jenn Air side by side, model JCD2389GEW. The ice dispensers work, the water does not. This started after I replaced the filter. I've checked and nothing is locked out. When you press the actuator pad to dispense water, you can hear a noise similar to a small pump which I assume is a solenoid attempting to open. Any ideas?
Oct 02, 2009 | Jenn-Air Refrigerators
In door ice maker not working
In some cases, living in an area with extreme humidity, the ice dispenser door can stick open ( a small flap in the chute that delivers ice into the glass). This can cause a problem. The grinder in the dispenser sounds like it is frozen. Try using a HEAT GUN (hair dryer) on a low setting to defrost the dispenser DO NOT TRY TO MELT THE PLASTIC! Or a quicker solution, Unplug the refrigerator and pour water thru the dispenser CAN BE A MESS try to catch in a bucket or pan. Remove the dispenser from the door clean and dry as necessary and reinstall.
Try using cube ice to see if this helps. The occasional cup of cubes will dislodge stuck ground ice in the dispenser.
ABOVE ALL BE CAREFULL THE GRINDER CAN CUT YOUR FINGERS OFF. ELECTRIC SHOCK IS A DANGER AS WELL.
Sep 17, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
Water dispenser on front of refrigerator door does not dispense water. Ice Cube maker continues to make ice cubes. Defrosting doesn't fix problem.
Water dispensing solenoid is bad. You need to replace the solenoid valve. This typically is independent of the ice maker.
Jun 02, 2009 | Frigidaire FRS26R4A Side by Side...
The ice maker and water dispenser does not work. There is no power to the exterior dispensing unit on the refrigerator.
I'm assuming you are saying there is no ice and water being dispensed, but that the ice maker is producing ice.
Actual ice maker operation is independent of the fountain which is for dispensing only.
The power is checked at the fountain board on wires Red/Black and White. The door must be closed when doing this check as power goes through the door switch. If no power is present, check the same wires at the connector under the upper door hinge cover.
The next check would be Red/Black to Blue while depressing the actuator pad button.
Outputs off the board are Pink to auger motor, Black to fountain water valve, other Black to fountain light, Violet to cube solenoid, the two brown wires go to the ice chute door solenoid.
The ice maker can be checked by removing the plastic cover up front. Check test points L to N for 120VAC. Short test points T and H to cycle the ice maker. Make sure it does not have ice or water in the mold already, or it will run over.
Of course last but not least, check water to the refrigerator. It is a dual valve and unlikely both solenoids could fail at the same time.
May 04, 2009 | Jenn-Air JCD2295HES Side by Side...
My Jenn Air refrigerator ice maker quit working
My Jenn-Air refrigerator (JRSD2790) quit making ice, dispensor works, water dispensor works. Do I need to replace the entire
ice maker?
bjones03@comcast.net
Mar 25, 2009 | Jenn-Air JCD2389G Side by Side...
Jenn Air JCD2389GES ice dispenser problem
You could have a layer of solid ice at the bottom of your icetray. Remove icetray. Remove any ice in bottom. Reinstall. Be careful there is a connection on the rear of the icetray, you may have to turn it to get it to mesh correctly. Fill with ice and it should work fine. Good Luck.
Feb 24, 2008 | Jenn-Air JCD2295K Stainless Steel Side by...
Jenn-Air JCD2389G Side by Side Refrigerator Logo
179 people viewed this question
Top Jenn-Air Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Jose Pino
Are you a Jenn-Air Refrigerator Expert? Answer questions, earn points and help others
