Question about Clarion VRX935VD Car DVD Player
Lcd screen will not retract into the unit. Will
Lcd screen will not retract into the unit. Will go to the horizontal position when closed button is depressed, but just stays there will not retract. Any suggestions?
  • mryfld Nov 13, 2009
    That did it Thank You so very much.
  • 11,896 Answers
When it goes flat, give a little hand by pressing it down completely flat so i will retract
Posted on Nov 12, 2009
Convergence
LCD panels are broken. you need a new one
unit price is USD120
any questions, feel free to ask me
have a nice day!
Jerry Lampdeng Limited
Oct 01, 2013 | Eiki LC-X986 Projector
AVIC - Z1 Screen no longer retracts to allow insertion of a CD
One of the pistons that move the screen in place must be stuck. The unit must be taken apart to fix this.
You need to take the tablet at a replair shop
Jul 30, 2008 | Pioneer AVIC-Z1 Car DVD Player
Computer screen is off center, how do I fix it so it goes the full screen
LCD monitors that are connected to desktop computers have on screen adjustments. The monitor have several buttons on the monitor, press the Menu button and the select the horizontal and or vertical screen position adjust the image or there maybe an auto screen adjustment.
Oct 10, 2012 | Dell 15.4" Lcd Screen Video Flex Cable For...
I can't get my icons and taskbar to center on my monitor. The start button is off screen to the left. How do I center everything so I can access them?
Press the OSD (On Screen Display) button on the monitor.
Use the UP/DOWN and LEFT/RIGHT buttons to navigate through the menu, to get to the "horizontal position" menu.
Press the OSD button to "select" that setting.
Press the LEFT/RIGHT buttons to "move" the image LEFT/RIGHT.
Press the OSD button to "apply" the new location.
Wait a few seconds, and the OSD menu should close itself.
Oct 24, 2010 | Microtek 815C 18" Flat Panel LCD Monitor
I use an lcd screen. I've just reinstalled my Windows xp. But the desktop screen doesn't display fully. Left side & right side has some space. I set my screen resolution at 1024 by 768 pixels &...
The monitor should have some buttons on it to enter the menu system for the monitor. as part of the settings there should be options for vertical/horizontal size and position. You will need to adjust these to bring your borders to the correct position.
May 21, 2010 | Computers & Internet
Bosch 2006 SHU43E door will not lift from horizontal position to close"
the bosch is only on a hinge there is either something in the slot for it to retract into or one of the hinges is bent and won't let it up. there are springs on the sides of the dishwasher but you have to pull the unit out to get to them to make sure it isn't hung up on anything
May 30, 2009 | Dishwashers
Black at left and right of monitor
Since this is a CRT monitor, it doesn't have a native resolution like LCD monitors. You need to adjust the veritcal and horizontal sizes to fit the monitor. On the front of the monitor there are some menu buttons. You need to open the on-screen menu, then navigate to the Horizontal Size and Position menu, use the plus and minus buttons to grow and shrink the image. If it's not centered, use the Horizontal Position menu to move it around. Use this same system for the Vertical menu and you can get your image to fit your screen. By the way, you should have your operating system running with a white (or light colored screen) up when you do this so you can see all the edges of your desktop. The buttons are tricky, but they kinda make sense. Good Luck!
May 14, 2009 | Samsung SyncMaster 753S 17" CRT Monitor
Viewing mode will only go from zoom to wide!!!! please help
Hi!
Found some relevant info on how to adjust your video settings... You might want to give it a try!
Thanks! =)
4.12 PC Input Picture Adjustment
The Picture Adjust menu operates in the same
way for the PC Input as for the DTV / TV input in
section 4.2 for Backlight, Contrast, Brightness and
Color Temperature.
4.12.1 Auto Adjust
When the MENU button is pressed, the On Screen
Display (OSD) appears on the PICTURE ADJUST
page. Press the button to highlight the Auto
Adjust selection.
Press the button for the LCD HDTV to adjust to
the PC signal timing automatically.
4.12.2 H-SIZE
Press the button to highlight the H-Size selection.
Press the button to start adjusting the horizontal size of the picture. Use the or button to adjust
the horizontal size.
4.12.3 Horizontal Shift
Press the button to highlight the Horizontal Shift selection.
Press the button to start adjusting the horizontal position of the picture. Use the or button to
adjust the horizontal position.
4.12.4 Vertical Shift
Press the button to highlight the Vertical Shift selection.
Press the button to start adjusting the vertical position of the picture. Use the or button to adjust
the vertical position.
4.12.5 Fine Tune
Press the button to highlight the Fine Tune selection.
Press the button to start tuning the to the PC signal. Use the or button to adjust the tuning
4.14.1 Understanding Viewing Features
Your LCD HDTV features four viewing modes and Picture-In-Picture (PIP)/Picture-by-Picture (POP) mode.
You can switch viewing modes using the remote control.
4.14.2 Viewing Modes
Normal Mode
The original 4:3 aspect ratio (1.33:1 source) is preserved, so black bars are
added to the left and right of the display image. Standard TV broadcasts are
displayed with a 4:3 Aspect Ratio. Movies in 4:3 Aspect Ratio may be referred
to as pan-and-scan or full frame. These movies were originally filmed in 16:9
(widescreen), and then modified to fit a traditional TV screen (4:3).
Wide Mode
When watching a standard broadcast or full-frame movie in this mode,
the display image is stretched proportionately to fill the TV screen.
When watching a widescreen (1.78:1 source) program or movie, the
display image fills the TV screen. If you are watching a widescreen
(1.85:1 or 2.35:1 source) program or movie, there will still be black
bars at the top and bottom.
Zoom Mode
When watching a widescreen (1.78:1, 1.85:1, or 2.35:1 source)
program or movie, the display image is zoomed proportionally to fill the
width of the screen. The top and bottom are cut off to remove most of
the source material’s black bars. This mode is good for programs or
movies with sub-titles.
Panoramic Mode
When watching a standard broadcast or full frame movie in this mode,
the 4:3 Aspect Ratio (1.33:1 source) display image is stretched
horizontally on the left and right sides to fill the TV screen. The center
of the image is not stretched.
Note: Viewing modes are saved based on input. For example, you lasted watched a DVD in widescreen
mode and then watched TV in standard mode. When you switch back to DVD input, the viewing mode
will return to widescreen.
Jan 04, 2009 | Televison & Video
Screen retracts, then opens, and retracts, and does not stop
I had that problem too I'll I did was press the reset butoon on my unit and everything resetted but the bypass code, you have to reprogram your stations and the time thats it
Mar 20, 2008 | Jensen's VM9312 Car DVD Player
Monitor
I would check the cable and connector pins first. Then I would suspect there's a problem with the video signal board inside the monitor. It could be the LCD panel controls, too. That would make the unit beyond economical repair unless you got a used one.
Jan 18, 2007 | Dell E171FPb 17" TFT LCD Flat Panel...
Clarion VRX935VD Car DVD Player Logo
107 people viewed this question
Top Clarion Car Audio & Video Experts
xxxxxx xxx
Marco Avila
Marco Avila
Are you a Clarion Car Audio and Video Expert? Answer questions, earn points and help others
