Question about Saniflo Sanibest macerator with multiple connections
When i flush my toilet a spray of water comes out on the hose that enters the sani flow this is held together wihh a jubalee clip there is a split on the rubber which is attached to the sani flow
  • 2,237 Answers
Replace the rubber
Posted on Nov 13, 2009
When I flush the water goes down but does not take the paper with it... Help!!! Called sani plus company and they don't know!!!
If the paper isn't flushing, that means it's got too much drag to be carried down with the water. You've got a few options here:
1) Use lower ply paper, as it will be easier to flush
2) Use less paper, or flush after each wipe
3) Improve your toilet to a high rate-of-flow toilet
Sep 02, 2015 | Home
My saniflo does not flush properly always leaves the toilet paper behind
Not enough water (Sani`s don`t suck it in)
Recycled dense paper
Old Sani needs a service
One or all of the above should cure it.
May 14, 2015 | Saniflo & Saniplus& Macerator Pump
Toilet model 386 is spraying water through the top of the water valve when tank is refilling.The water then is coming out between the lid and the tank onto the floor. email Address: milemc@yahoo.ca
there is a black hose line that goes from the flush valve to the fill valve. that black hose needs to be attached to the fill valve the one in the center. Your clip may have broken or it could of just slipped out. the hose is called the refill tube. If its broke then you will have to replace the flush valve.
Mar 14, 2011 | Summit Appliances Division Mansfield 386...
We have installed an american standard duel flush toilet that uses a fluidmaster valve. Problem! The refill tube is mounted on a float attached to the overflow pipe. When the toilet is flushed the nozzle...
The overflow pipe should be attached to a small clip that holds it in position over the over flow pipe. If it is loose or attached to the outside it will do what yours is doing.
Apr 28, 2017 | American Standard 2480.516 FloWise Dual...
How to fix fill water shooting up and over when flushing?
Hose in tank it has a clip to secure it to a fill tube in center of tank to let water fill down tube . If it is just stuck down in it or loose it has to much pressure and will spray every where.
May 11, 2010 | VitrA Aria Toilet with Elongated Bowl/...
Loud grinding noise from unit when flushed like
take the pump out and haul it outside and spray it off and check in the bottom of the pump to make sure there isn't anything stuck in there. then shop vac the bottom of the tank out to make sure there isn't anything funky in there that would get clogged in the pump. sometimes the out let line gets clogged as well you can buy a drain king ( it's a rubber deal that hooks on the end of a hose and when you turn water on it swells up and sprays water out) then stick it in the outlet pipe and let her rip and see if it lets the water through.
Jul 28, 2009 | Saniflo & Saniplus& Macerator Pump
American standard toilet running
There should be two screws on top of the assembly to control the level of the water. One increases, the other decreases. But if the bulb has a horizontal split it will have to be replaced. It simply screws of and on the arm. The water hose clips to the drain tube and the water should be directed inside the tube.
Buy a bulb, and if nothing else, bend the arm down to decrease the level of the arm and bulb and consequently the water level.
Apr 24, 2009 | American Standard Lifetime 54 1/2 In. x 54...
No water comes out of the wand
First, you must be sitting on it before it will work. Their should be a separate valve for the bidet function, be sure it is turned on. Also check that the seat is installed properly and the quick release "snaps" into place. These are the most common problems if they don't fix it let me know.
Please rate this solution-
Mar 19, 2009 | Toto MS950CG-12 Neorest 500 Elongated One...
Saniflo Sanibest macerator with multiple connections Logo
243 people viewed this question
Top Saniflo Plumbing Experts
jasbo
jasbo
Gil Shultz
Vernon Taylor
Are you a Saniflo Plumbing Expert? Answer questions, earn points and help others
