I have a Firelite Model #USBFLB40-C - Lot # MH5629 and need a power cord for it. Can you help me out?
  • Louie Caplan Nov 12, 2009
    Lee, You are absolutely correct. I don't have a clue where they came up with a Camcorder. I thank you very much for your help and assistance in this matter. It is greatly appreciated!
    louie Caplan
    The solution was very helpful and I thank Lee very much for his help and expertise!
    Louie Caplan
  • 4,806 Answers
As far as i know this not a web cam but rather an external hard drive.
Would i be correct in my assumption?
Posted on Nov 12, 2009
  • Lee Hodgson
    Lee Hodgson Nov 12, 2009
    If i am correct the you will need a 5V DC power connector.
    I'm also assuming that you are in the US so you will need a US wall plug type adapter.
    Take a look here at these adapters >>>>>>>>>>>>>>
    http://www.9mart.com/products/5-Pieces-o...
    Please post back if you need anymore help or advice.
    Regards.
Where is the USB slot
Should be on the front of machine
Apr 03, 2012 | Sony Playstation 3 (PS3) Console
I need to locate a mother board for a firelite model #USBFLB40-C any suggestion? Or where can I get a new USB power data plug soldered on the old board? Thank you.
Yes I would take the Harddrive out of the SmartDisk FireLite external harddrive, and install it into an economical external enclosure.
Looking up reviews just now I know that it's a laptop sized harddrive that's inside.
(The Harddrive inside is 2.5 inches across in width. 2-1/2 inches)
I don't know however if it is an IDE or SATA unit.
But you will know once you get the case open, and view the Harddrive inside.
One example of a 2.5 IDE external enclosure,
http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=1086960&CatId=2782
One example of a 2.5 SATA external enclosure,
http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=3195233&CatId=2783
One example of an external enclosure that will support IDE or SATA harddrives that are 2.5,
http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=7041055&CatId=2783
Regards,
joecoolvette
Jul 04, 2011 | SmartDisk FireLite 40 GB Hard Drive
I have a SmartDisk FireLite Model Number USBFLB40-C. I took it to some local data recovery specialists, but I think they said the motor was out. They said I'd have to send it into the company. However,...
After a quick check, it seems as if SmartDisk have disappeared off the face of the earth (or at least the internet). Strange. I did find the following phone number (which you may have also found in your search), it might be worth trying that if you haven't already (note I have not checked it myself, so no idea if it still works):
01252 530960
Note also this is a UK number (I can't find a US one). To be quite honest, I doubt this will work.
If that doesn't work, then I'm afraid there's not a lot you can do yourself if its the motor that has broken. The next move would be to take it back to the recovery specialists, explain your situation, and see if they can recommend anyone who might be able to replace the motor (if they won't do it themselves).
By the way, thanks for clearly wording your question, it makes life a lot easier when people do that.
May 31, 2011 | SmartDisk FireLite 40 GB Hard Drive
My external firelite model #USBFLB40, stop work today, i tried in other laptoop, and its work but after i disconnect, i want to used it again, and dosent work, ether my lap, nether the other lap... ...
1. It may be due to the electronics in the USB case.
You can purchase a new case and install the hard drive and connect to the USB port to your laptop/PC.
If the drive is not seen after this then the drive itself may be damaged.
If you disconnected the USB drive without "safely removing it in Windows it may have damaged the hard drive controller.
Mar 18, 2011 | SmartDisk FireLite 40 GB Hard Drive
How do I open a smartdisk firelite model # USBFLB40
Go ti My computer icon, right click on it and click on explore. Should be show your new drive. If this is the case, right click the new HD in click on explore to see what is in there. My PC Doctor NJ
Mar 26, 2010 | FireLite (USBFLB80) Hard Drive
I have a firelite smartdisk portable hard drive usbflb40. I need th driver for it. Where can I down load it. Thanks
http://drivers.softpedia.com/get/Other-DRIVERS-TOOLS/Others/SmartDisk-FireLite-Driver.shtml
there you go!
Feb 25, 2010 | FireLite (USBFLB80) Hard Drive
I cannot have access to my FireLite Model #USBFLB40 .I get error
Try updating Windows first.
Next update your drivers for the device from the company website.
Restart your computer without the device plugged in.
After all is loaded, try plugging it in again and see if Windows will pick it up.
Hopefully this will help.
Dec 07, 2009 | Electronics - Others
My Windows 98Se OS does not recognize the USBFLB40-C Lot No JH570s
If the Windows 98SE driver installation steps do not proceed smoothly, try the following steps to remove, then re-install the drivers:
  1. With the FireLite connected to the USB port, open My Computer, then Control Panel, then System. Click on the Device Manager tab and make sure the View devices by type option is selected.
  2. Expand the listing (click on the “+”) for Universal Serial Bus Controllers near the bottom of the list.
  3. If you see an entry with an alert icon (yellow exclamation symbol or question mark), right click on the entry and choose Remove.
  4. Repeat steps 2 and 3, expanding (if present) the listing for Other Devices.
  5. Exit all the windows opened in step 1.
  6. Disconnect the FireLite from the PC’s USB port.
  7. Reboot your computer.
  8. Again try the driver installation steps that came with the driver you downloaded.
Nov 01, 2008 | Computers & Internet
Smartdisk Firelite model USBFLB40-c - not recognising - stored data recovery
Most likely the vacuum and not the ants. The vacuum could have given it a dangerous charge or vibration. You may need to extract the drive from the enclosure. It possible ( hopefully) that the enclosures bridge board failed instead of the drive. When you extract the drive, you will see....its construction is made well, and can stand up to crittters..
keep me posted.
Oct 13, 2007 | FireLite (USBFLB80) Hard Drive
Computers & Internet Logo
David Payne
David Payne
