Question about Ryobi 30 Cubic Centimeter Curved Shaft Gas Trimmer
The gas hose came apart in my Ryobi trimmer Model# RY30002A. How do I put in a new gas hose and filter into the tank? There is a little hole on top of the tank that is almost inaccesable and there doesn't seem to be any way to do a replacement. By the way what is the other hose that goes into the tank for?
5 Suggested Answers
panilling9
  • 284 Answers
SOURCE: Ryobi 790r trimmer has low power and stalls
Maybe a quick fix and maybe not
check your muffler the factory puts a spark arrestor screen that tends to plug after awhile
there is a little plate on the side muffler that needs to be removed to access the screen you may need a torx bit or allen wrench to remove
you may have to remove the back half of the plastic cover to access the screws
remove screen and clean with carb. cleaner or equivalent make sure you can see through it and reverse the procedure to put it back
Posted on Jun 07, 2009
  • 969 Answers
SOURCE: ryobi 700r gas trimmer, replace old fuel lines
1-800-345-8745 US
1-800-265-6778 Canada
Posted on Aug 23, 2009
SOURCE: How do you get the fuel line connected to the fuel
You must run the fuel line through the back of the tank and out the filler hole,make your connections,i used a small amount of vaseline to make the connections.Then pull the filter into place,make sure some of the nipple of the filter pokes through,then slide the retainer ring on the hose and force it onto the filter nipple.
Posted on May 15, 2010
SOURCE: Ryobi gas trimmer model
will not pump gas into primer bulb
Posted on Sep 11, 2011
I need to know how the fuel lines are hooked up in my ryobi gas trimmer. All of the fuel lines rotted out. I took them out and I need to know the correct connection sequences (what goes where).
line runs from little filter in tank to carb.
line from carb. to primer bulb
line from primre bulb back to gas tank.
lines are 2 sizes
need to cut at angle end of lines in tank so you can get them thru holes
and grab with needle nose plyers and pull them thru.
make sure you put the little filter on end before you pull line thru and leave
enough so filter can move around the whole tank.
second line in tank is smaller and need to cut and pull it thru hole in tank to primer bulb
Jun 23, 2010 | Ryobi 30 Cubic Centimeter Curved Shaft Gas...
How do you get the fuel line connected to the fuel filter nipple on the bottom side of the gas tank on the Ryobi 725r gas trimmer?
May 09, 2010 | Ryobi 30 Cubic Centimeter Curved Shaft Gas...
Gas leaks
figure out where it's leaking from.. and fix it :/ or provide a little more detail on the issue
Aug 26, 2009 | Ryobi 15" Electric Factory Reconditioned...
Fuel line connectors pushed into fuel tank
I slice the new hose like the end of a medical needle, like a long v. A little lubricant on the hose will help as well, Cut off enough that you can thread up throught he filler hole, there should be a filter on the end of the hose. Do this obviously with the gas tank empty, when you turn upside down, the old hose should fall out or be available to grab with needle nose pliers. I hope the helps.
Jul 05, 2009 | Ryobi 30 Cubic Centimeter Curved Shaft Gas...
RYOBI 725R FUEL LINE DIAGRAM
I just rebuilt my 725r. I don't have a diagram but I can explain it. There are two lines coming out of the fuel tank. The line closest to the rear is the fuel feed and has the in-tank filter (these are available for replacement). This line goes through the lower case hole of the air filter housing and attaches to the bottom of the carburetor. The line toward the front of the tank attaches to the longer/lower fitting the primer bulb and is the return. The line coming off the shorter/upper fitting of the primer bulb goes through the upper hole of the air filter housing and attaches to the top of the carburetor.
FYI also, the forward carburetor screw is the low idle adjustment & the rear, the high-speed mixture. The original oil mixture spec called for 32:1
Jun 13, 2009 | Ryobi 15" Electric Factory Reconditioned...
Need routing of fuel lines on Ryobi string trimmer Model 725R.
The larger fuel line goes from fuel filter to carbuerator.The smaller line is the return line from the purge bulb tofuel tank. mitchjl_1692
May 27, 2009 | Ryobi 15" Electric Factory Reconditioned...
How far does the return gas line on a ryobi string trimmer extend
There is supposed to be a barb fitting with a flange on top of it that is on the end of the hose, inside the tank. If you do not have that barb in place the gas will start to leak out of the tank in a short time. Barb fitting is designed to have hose stick up about 3/16" into the tank when the hose is properly installed. You put the new hose on the fitting, thread the other end of the hose through the fill opening of the tank and out the hole in the bottom. Pull hose through until barb comes through the hole in the tank and the flange is flush with the inside bottom of the tank. There is supposed to be a plastic ring that fits over the bulge in the hose/barb at the bottom of the tank on the outside. Serves as a retainer for the fitting.
May 19, 2009 | Ryobi Garden
Ryobi 725R fuel filter; How is it re-mounted? Fuel line is soft and weak > tears easily. I am replacing the fuel lines and need to re-mount the fuel filter into the tank. It seems next to impossible to get...
after you insert the fuel line through the tank and install the filter. take some WD-40 and spray the hose. now from the bottom of tank the pull on the hose. and just keep pulling on it till it comes through all the way. then slide the little white washer back over the hose and seat in place. this should do it for you. they are a royal pain in the **** to work on. numerous brands of string trimmers have these top mount tanks. a new tank with hoses already assembled is about 45 bucks with shipping. much cheaper to fix it yourself.
Mar 11, 2009 | Ryobi 15" Electric Factory Reconditioned...
Ryobi 700r gas trimmer, replace old fuel lines
Line from tank with the filter on it is the supply line and goes to the carb inlet fitting. This is typically on the "bottom" of the carb (with the tank being up) and will usually have a fitting with barbs or a bulge on it to ensure a tight fit. The other fitting on the carb is the return line and is usually a straight tube fitting with no barbs. That line goes the suction side of the primer bulb. The third line goes from the outlet of the primer bulb to the return barb fitting in the bottom of the tank. Fittings have to be removed from tank to properly install the new hoses on them. Remove retainer ring on outide of tank and push fittings into tank, then shake out of the fill opening. More details on replacing hoses are listed in another post about Repairing Ryobi trimmer.
To leemineres, if hoses are on right and unit still stalls after starting initially you probably need to disassemble carb and clean out using spray carb cleaner. May be sticky needle valve, or partially plugged port or jet.Could also be hole in diaphragm. Gasket and diaphragm kit would be good to add when you take apart, even if diaphragm does not have a hole.
Jan 21, 2009 | Ryobi 30 Cubic Centimeter Curved Shaft Gas...
Ryobi 2 cycle gas trimmer 705r/725r
The gas nipple that come out I have...whats goes in the other hole?
Aug 28, 2008 | Ryobi Garden
Ryobi 30 Cubic Centimeter Curved Shaft Gas Trimmer Logo
135 people viewed this question
Top Ryobi Garden Experts
Jim Parker
Jim Parker
Nick Olsen
Rexter1
Are you a Ryobi Garden Expert? Answer questions, earn points and help others
