Question about LG VX8350 Cellular Phone
The camera will turn on for a second or two and then go to a black screen and wont allow any options to be pulled up
DSC-HX5, Lens is Stuck in Zoom out mode. Turn On works but screen stays black. Automatically turns off after 10-20 seconds.
Since there is nothing you can do to fix this at home you have 2 choices, replace the camera or send it back to the manufacturer for exchange (very expensive)
Jul 27, 2017 | Sony Cyber-Shot DSCHX5 Digital Camera
When camera turn , on screen -turn off and on again
Error: TURN THE POWER OFF AND ON AGAIN is displayed on the LCD screen when the Lens Mechanism is stuck or when affected by any malfunction. If turning the power on and off again does not resolve the error message, try doing a power reset and Initialize option.
Performing a manual power reset
Turn off the camera.
Remove the battery pack.
Press and hold the power button for 30 seconds.
Allow the camera to remain without power for 60 seconds.
Reinsert the battery pack.
Turn on the camera.
To reset the Camera back to factory default, select the INITIALIZE Option from the Main Setting Menu of the Camera to OK. This will set the user defined settings back to factory default. The images and videos will not get deleted.
If the issue persists, service may be required.
Thanks for contacting FixYa.
Aug 14, 2011 | Sony DSC-S930 Digital Camera
Yes.turn power off and on again on the screen
Turn on the camera.
To reset the Camera back to factory default, select the INITIALIZE Option from the Main Settings 1 Menu of the Camera to OK. This will set the user defined settings back to factory default. The images and videos will not get deleted.
Jul 29, 2011 | Sony Cyber-shot DSC-W130 Digital Camera
DCS T70 LCD does work properly .I mean to say if i try to use one function another function gets started instead of desired function
Based on the information you've provided, it seems that the touch screen panel is not aligned. You can try Calibrating the touch screen to resolve the issue.
Calibration option is in the Main Settings 1 Menu of the Camera. Calibration option enables you to perform calibration when the touch panel buttons do not react at the appropriate points where you touch. You can use the paint pen, touch the X mark displayed on the screen. The X mark moves on the screen. Once the calibration option is finished successfully, the touch screen should work.
The Calibration option can be done only if the Menu is accessible.
You can also perform a power reset before performing the Calibration.
Turn on the camera.
This should resolve the issue.
Thanks for using Fixya.
Jan 10, 2011 | Sony DSC-T70 Digital Camera
My sony dsc-s980 keeps telling me to turn off and on the power. There was a problem with the barrell getting stuck but its seems to be working ok now but my camera still wont work
Error: TURN THE POWER OFF AND ON AGAIN is displayed on the LCD screen of the DSCS980 Camera when the Lens Mechanism is stuck or affected by any malfunction. If turning the power on and off again does not resolve the error message, try doing a power reset and Initialize option.
Turn on the camera.
To reset the Camera back to factory default, select the INITIALIZE Option from the Main Settings 1 Menu of the Camera to OK.This will set the user defined settings back to factory default. The images and videos will not get deleted.
Good Luck
Nov 09, 2010 | Sony Cameras
When I switch on the lens goes in and out a few times but no viewing screen. It asks to be switched off and then on. I can view stored pics but it won't allow me to take any?
· Turn off the camera.
· Remove the battery pack.
· Press and hold the power button for 30 seconds.
· Allow the camera to remain without power for 60 seconds.
· Reinsert the battery pack.
· Turn on the camera.
To reset the Camera back to factory default, select the INITIALIZE Option from the SET UP1 Menu of the Camera to OK.This will set the user defined settings back to factory default. The images and videos will not get deleted.
Thanks,
KenSolutions
FixYa
Oct 21, 2010 | Sony Cyber-shot DSC-W55 Digital Camera
My pentax option A10 turned black on the screen and won't open
Since the screen went black BEFORE the lens retracted, it makes me think this is a main board problem. The only other possibility is that it is the lens assembly, but since it went black BEFORE the lens retracted, I don't think that is it. I can replace the main board for $40, or you can send it to pentax in Arizona, and they will do it for about $90.
The main board is NOT something that I would suggest anyone try to replace as a DIY project. There are too many small screws, and delicate connections to deal with.
You can contact me at: mrfixitmark at comast dot net
If you just want to sell the camera as-is, I also buy all pentax a10, a20, a30, a40 cameras, in any condition.
Mar 28, 2010 | Pentax Optio A10 Digital Camera
When I turn my camera on, the screen remains black and says turn power off and on. Upon doing so, when i turn it on again, it begins beeping and says turn power off and on. But if I go to the view pictures...
Turn on the camera.
To reset the Camera back to factory default, press the RESET button located above the PHOTO button which will change all settings back to factory default. The images and videos will not get deleted.
Jan 30, 2010 | Sony Cyber-shot DSC-M2 Digital Camera
The lcd screen remains black even when i turn on my canon powershot A620.
Did you check the display option? The camera allow you to turn OFF the screen.
Jul 30, 2009 | Canon PowerShot A620 Digital Camera
Turns on, takes pictures, blank screen
I know in most digital cameras there is an option buried in one menus to turn display OFF. Perhaps, you can have a look around in the various menus to turn screen back on. Also, there should be another button or feature that allows you to view the shots you've taken.
Apr 29, 2007 | Canon Powershot SD450 / IXUS 55 Digital...
LG VX8350 Cellular Phone Logo
Top LG Cell Phones Experts
Computer Repairing
Computer Repairing
Raphael Josiah
Are you a LG Cell Phone Expert? Answer questions, earn points and help others
