Question about Kitchen Appliances - Others
Chamberlain Liftmaster 2280-267 1/2 hp stopped suddenly
I have determined that power supply is OK. Neither of the 2 remotes, or wall mounted door control, or the keyless entry can work the unit. The safety reverse sensors have a red light on it as it normally does (I noted that it was always red and not green). When I press the learn button, I do not get a glow from the learn indicator light. Any ideas? Is it a board problem? do I need to get the board replaced then? Thanks in advance.
SOURCE: Chamberlain Liftmaster Professional 1/2 HP
Okay...upon further inspection, my left spring has broken in two. Going to call around for some quotes to replace the spring. Thanks for the suggestions.
Posted on Jul 25, 2008
  • 6 Answers
SOURCE: Chamberlain Liftmaster Pro. Garage door Problems closing
The sensor eye - or more likely, the other end, the sensor light - probably got knocked out of alignment. The eye should have an LED on it - possibly one that glows green when it's ready to close or red when it's obstructed or out of alignment. Try adjusting the light until the LED on the receiver glows green.
Posted on Dec 07, 2008
Blue Dog
  • 75 Answers
SOURCE: garage door stops and reverses either way-up or down-
If the light on the opener flashes when this happens, count the flashes (which indicate the type of problem) and consult your owners manual.  If you don't have the owners manual, you can find a digital copy online at the manufacturer's website. Also, check your manual for an adjustment that tells the opener how much resistance you want it to tolerate before reversing.
Posted on Dec 22, 2008
ltfrc
  • 227 Answers
SOURCE: New Craftsman 95320 1/2 hp chain drive only opens door ~6"
Try this link
http://www.garagedooropeners.us/helpgifs/chamberlain_troubleshooting.html
Posted on May 25, 2009
woobie dog
  • 1273 Answers
SOURCE: GDO - Do I need a new Logic Board or is it something simpler?
No, the problem is the photoelectric eyes. Check that they are properly aligned.
Posted on Aug 02, 2009
Liftmaster Model 1355 suddenly only works from remotes (3) sporadically. Changed light from led to incad. but did not help.
try leaving bulbs out a bad socket can cause range issues. also a bad ground on the wall/ceiling outlet can also cause problems.
Oct 05, 2016 | liftmaster chamberlain 1/2 hp chain drive...
I have a liftmaster formula 1 1280R opener that works fine from the wall mount but all of a sudden both remotes and the built-in remote in my car stopped working. It is not the batteries in the remotes. ...
The motor/control unit may have gotten reset. It needs to relearn the codes transmitted by the remotes.
MIne has a "learn" button on the control unit. Press and hold, then press the button on the remote. Lights will flash indicating it has received and stored the code. Release button.
Check to see if the remote works now. If so, all three should be working. If not, dig up your manuals.
Feb 28, 2013 | Sears Craftsman LiftMaster Chamberlain...
My Chamberlain Liftmaster Formula 1 garage door (2002) has stopped working. The power is on -- light turns on when I push the wall mount button. But the remotes no longer work. The door does not move. ...
The light by the learn button may be sending a diagnostic code. See if it is flashing a number of times, pausing and then repeating. Count the flashes. Is your door stuck in the open posititon?
Jun 11, 2011 | Sears Craftsman LiftMaster Chamberlain...
My Chamberlain Liftmaster Formula 1 garage door opener just started going up 2 inches then stopping. If I hit either the inside wall mount or the remote in the car it just goes back down 2 inches and back...
You need to check the door springs to see if one is broken and also remove the cover from the motor unit and check the drive gear. The gear is white nylon and will be very obvious if it is bad. The part number is 41A2817 and is available at any good door service company. It will come with instructions.
Apr 03, 2011 | Sears Craftsman LiftMaster Chamberlain...
The hand held divice stopped working and the mounted pad light flashes quickly. The mounted pad does work.
The most likely problem here is that your wall control is bad. I would disconnect the 2 wires going to it and I think you will find your remote works. Replace the wall control.
Sep 27, 2010 | Sears Craftsman LiftMaster Chamberlain...
Dec 07, 2008 | Sears Craftsman LiftMaster Chamberlain...
Kitchen Appliances - Others Logo
195 people viewed this question
Top Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
Are you a Kitchen Appliances - Other Expert? Answer questions, earn points and help others
