Question about Hasbro Furreal Friends Butterscotch Pony
Butterscotch pony snapped tail
Whilst playing, albeit rigorously, the tail has been snapped from its stem. Can you get spare parts which we could purchase in order to replace and return back to its full glory?
  • 3 Answers
Had the same problem and the fix is easy. Hopefully, the tail snapped off at the base of the plastic plate on the tail. If so, go to a hardware store and buy 1 ft. of CLEAR plastic tubing with 3/16" inner diameter and 5/16" outer. Cut off a piece about 1 1/2". Now, look at the base of the tail and you should see a small screw that holds in what remains of the stub that broke. Unscrew the screw and remove what is left of the stub. KEEP THE SCREW. Now drill a small hole thru the plastic tube about 1/8" from the end. This will later be inserted into the tail and the screw will go through the holes. Next, take a hair dryer and heat the undrilled end of the tube to soften it and push it on to what is left of the broken stub inside the pony. It will be a tight fit which is what you want. You will probably need to twist the tube gently while applying firm pressure on it to make it slide over the stub. The end of the tube with the holes should be about even with the outside top of the white plastic hole and the tube holes should be level, looking at it from side to side. This makes the alignment of the screw hole to the tail correct. Now slide the tail over the end of the tube and insert the screw. I just did it today and it works good as new! If the tail is too far away from the body of the pony, carefully twist and remove the tube and shorten it. Since you bought a 1 ft. tube, you can have several trys to get it right if you cut it too short! Total cost for the tube was 21 cents. Good luck! Kip V. Tryon, NC
Posted on Dec 05, 2010
  • Stacy Perez Dec 05, 2010
    This is copy of a post from Kip V. in Tryon, NC. Saw it and thought to send it your way. Not taking credit in any way. :o)
How to get into and fix tail doesnt move anymore
Here is a link to instructions for removing the fur from the FurReal Friends Butterscotch Pony. Beyond that, I have no idea how to fix a broken tail. If you can find somebody who works on robotic/animatronic toys, or a good handyman, they can probably fix it for you.
http://www.instructables.com/id/Make-a-Fire-Breathing-Animetronic-Pony-from-FurRea/?ALLSTEPS
Dec 22, 2011 | Hasbro Fur Real Friends Smores Pony
Where can I obtain a complete new tail for my butterscotch pony
Here is a printable form, from Hasbro, for replacement parts for the Butterscotch Pony: http://www.hasbro.com/customer-service/orderform.cfm?sku=76471 ...but I don't think they do replacement tails. This is their Customer Service phone number 800-255-5516.
May 04, 2011 | Hasbro Furreal Friends Butterscotch Pony
Where can i get replacement parts for butterscotch? bought at sam's 3 years ago Kids now really into horses and of course our pony needs a few things. battery pack, tail, brush, and carrot any help?
I have had similar problems with toys myself. Seems as if when I am sure that my boys are done with a toy and it is long forgotten- it resurfaces needing some tlc... Here is a link to get the battery pack and cover. I would also suggest checking auction sites, as I have been able to find elusive little plastic parts of helicopters there too :-) Best of luck, and looking at Butterscotch; I would love her too!
Mar 24, 2011 | Hasbro Furreal Friends Butterscotch Pony
The tail broke on my butterscotch pony and I would like it fixed. What can I do? Thanks
Had the same problem and the fix is easy. Hopefully, the tail snapped off at the base of the plastic plate on the tail. If so, go to a hardware store and buy 1 ft. of plastic tubing with 1/4" inner diameter and 3/8" outer. Cut off a piece about 1 1/2". Now, look at the base of the tail and you should see a small screw that holds in what remains of the stub that broke. Unscrew the screw and remove what is left of the stub. KEEP THE SCREW. Now drill a small hole thru the plastic tube about 1/8" from the end. This will later be inserted into the tail and the screw will go through the hole. Next, take a hair dryer and heat the undrilled end of the tube to soften it and push it on to what is left of the broken stub inside the pony. It will be a tight fit which is what you want. The end of the tube with the hole should be just visible. Now slide the tail over the end of the tube and insert the screw. I just did it today and it works good as new! If the tail is too far away from the body of the pony, carefully remove the tube and shorten it. Since you bought a 1 ft. tube, you can have several trys to get it right! Total cost for the tube was 21 cents. Good luck! Kip V. Tryon, NC
May 25, 2010 | Hasbro Fur Real Friends Smores Pony
Hi, Where can I buy a new tail for my daughter's Butterscotch pony Furreal Thanks Michelle
Not sure where to buy a replacement but I just fixed mine today. Hopefully, the tail snapped off at the base of the plastic plate on the tail. If so, go to a hardware store and buy 1 ft. of plastic tubing with 1/4" inner diameter and 3/8" outer. Cut off a piece about 1 1/2". Now, look at the base of the tail and you should see a small screw that holds in what remains of the stub that broke. Unscrew the screw and remove what is left of the stub. KEEP THE SCREW. Now drill a small hole thru the plastic tube about 1/8" from the end. This will later be inserted into the tail and the screw will go through the hole. Next, take a hair dryer and heat the undrilled end of the tube to soften it and push it on to what is left of the broken stub inside the pony. It will be a tight fit which is what you want. The end of the tube with the hole should be just visible. Now slide the tail over the end of the tube and insert the screw. I just did it today and it works good as new! If the tail is too far away from the body of the pony, carefully remove the tube and shorten it. Since you bought a 1 ft. tube, you can have several trys to get it right! Total cost for the tube was 21 cents. Good luck! Kip V. Tryon, NC
Apr 18, 2010 | Hasbro Fur Real Friends Smores Pony
My daughter has broken the tail off. Can we
Feb 07, 2010 | Hasbro Furreal Friends Butterscotch Pony
We bought our daughter a butterscotch pony last year for christmas but she hs now pulled the tail off. Can we can a replacement tail?
Dec 09, 2009 | Hasbro Furreal Friends Butterscotch Pony
Looking to repair the tail on Butterscotch pony
Dec 01, 2009 | Hasbro Furreal Friends Butterscotch Pony
Hasbro Furreal Friends Butterscotch Pony Logo
445 people viewed this question
Top Hasbro Toys Experts
thegtw
Antony
Are you a Hasbro Toy Expert? Answer questions, earn points and help others
