Panasonic said that I have a ballast error, do have a manual for this TV?
  • 5,138 Answers
Go to www. Encompass Parts type in model number they will have a list of all parts Lamp, ballaster board or call 1-800-638-3328 also look for parts on E-bay i got my Lamp for 85.00 and Ballast board for 55.00
Posted on Nov 12, 2009
TV shuts off by itself
I would think a ballast would be easy to change take out old put in new like for like
Nov 07, 2013 | Panasonic PT-43LC14 43" Rear Projection...
Panasonic PT-61DLX76-K TV, no picture, red lamp indicator flashes once every five seconds. Bulb looks okay visually. Panasonic says bad ballast I need confirmation and service manual.
Hello.
Lamp should be replaced in average every 2.5 years. Bad lamp could look OK but it is not.
Replace the lamp first if it is older than 2-3 years. You have to do it in any case. If new lamp will not
work, only then you can start thinking about ballast replacement.
If you are OK with the screwdriver and you have technical skills you don't need service manual to replace ballast. You will need to remove rear cover and locate it near the lamp. It is not too hard.
Regards.
Russ.
Dec 01, 2010 | Panasonic PT-61DLX76 Television
Panasonic projection TV does not turn on.
Power LED flashes orange 1 x 5 secs. = 1 of 3 fans stopped. TEMP LED flashes 1 x 5 secs, = Temperature error. Lamp LED flashes 1 x 5 secs. = lamp ballast error. (check lamp 1st.)
Hope this helps.
Apr 18, 2010 | Televison & Video
My panasonic rear projection pt-52lcx65 wont turn on replaced the bulb now what antbody ?
Sounds TV needs Ballast Supply board replacement, it is available in Part Store.
If you wish to replace above board by yourself, should have service manual copy that is available HERE for small fee.
Or call local TV tech for fix.
Thanks.
Aug 06, 2009 | Panasonic PT-47WX49 47" Rear Projection...
PT-50LC13 Lamp issue
i hope the lamp was panasonic or bought in a good place (average cost of this lamp is 250 dllrs)
if the lamp is trustfully. i would put attention in the back side when you listen the arcing that the lamp at least try flashing.
This moment of the repair where you are is critical because you arrive to conclusions according to the process you already did and suspect that what it is already done is fine (but is really true that lamp works plus is really true that the arcing is because the arcing devise arcs or is only the primary of the transformers in the ballast who holds 300 volts in the primary (really good voltage to make arcing sound too)
Now the error code is going to be 50 % good or not: i mean or gives you the error of the ballast and lamp or any voltage is missed in the power supply ( i don't have the error codes chart for you with me) because i would like to go far and the problem was in the same place where i started/
Apr 08, 2009 | Panasonic PT-50LC13 50" Rear Projection...
Where do iget a ballast for a panasonic pt50lc14? already replaced bulb, looking for a ballast. is there a spacific ballast i need?
my recomendation would be save your money, and spend it on a new tv. by the time you pay for it you could of bought yourself a new tv...even though it wouldn't be a 50" you'll be much happier in the long run.........
Mar 02, 2009 | Panasonic PT-50LC14 50" Rear Projection...
Where can i buy the ballast repair kit for the PT-50LC13 tv?
try these guys out
http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&rd=1&item=150273671347&ssPageName=STRK:MEWA:IT&ih=005
Jul 03, 2008 | Panasonic PT-50LCX63 50" Rear Projection...
Lamp will not light
At first i was thinking the ballast had gone bad but after reading a few other post i think it would be best to call pannasonic..
others forums read:
ballast had gone bad. Panasonic no longer makes these ballasts so mine needed to be rebuilt at the tune of $400.00.
With the ballast in place still nothing so now they claim that they need to order a "kit" from Panasonic which basically is all the components of my tv.
Jan 28, 2008 | Panasonic PT-40LC12 40" Rear Projection...
Televison & Video Logo
129 people viewed this question
Top Televison & Video Experts
