Question about Westinghouse Televison & Video
Need code for white-westinghouse tv model wtv 1332
  • 5 Answers
SOURCE: lost manual,cannot find code for white-westinghouse tv
http://remotefinder.rca.com/
Posted on May 03, 2008
SOURCE: wHITE-WESTINGHOUSE TV/VCR COMBO NEED CODE
HAVE A RCA SYSTEMLYNKS AV CONTROL AND NEED CODE FOR WHITE WHESTINGHOUSE TV
Posted on Aug 14, 2008
The code for the TV is 0623 but to use the TV/VCR button to change mode from line to TV the code is one of the following 0179, 0451, 0463, 0624 or 0278. The 0623 only activates the menu but doesn´t let you change Air/Cable mode without first changing the Line/TV mode by pressing the TV/VCR or Line input button on your universalk remote with one of the other codes.
Posted on Feb 03, 2009
pabloloco
  • 2335 Answers
SOURCE: codes for living solutions remote + westinghouse lcd tv
The codes for your Jumbo Universal Remote to control a Westinghouse television are 097, 100, 130, and 155.
To program your remote by entering a code, follow these steps:
  1. Turn on your TV.
  2. Press and hold the CODE SEARCH button for at least 3 seconds until the red LED lights up and stays lit.
  3. Press the TV button on the remote so that the LED blinks once and then remains solid red.
  4. Enter the first set of 3-digit codes from the list. The LED will blink once every keypress. After the 3rd digit, the red LED will turn off indicating that the code was recognized for the device. If the code was not compatible, the LED will flash several times and you need to return to step 2 to try that code again or to try the next code in the list.
  5. After the LED has turned off, aim the remote at the TV and press ON/OFF. If the device turns off, you have used the correct code and the remote was successfully programed. If the device does not power off, return to step 2 and try again with the next code in the list.
I hope that helps.
Posted on Oct 16, 2009
  • 66 Answers
SOURCE: I have a White Westinghouse TV model WTV 11901. I
look at the back or side of your television
Posted on Nov 16, 2009
I cant find the code for ld-425
Hello
Three digit universal remote setu codes for White Westinghouse Tv are:
097/ 100
Four digit codes for White Westinghouse TV are:
0100 0130 0138 0136 0227 0279 0080
Four digit codes for Wastinghouse TV are:
0143 0114
OK.
Aug 31, 2011 | Westinghouse Televison & Video
The conyrol of my tv, westinghouse model sk:19H2105 IS BROKEN AND I NEED A CODE TO USE A UNIVERSAL CONTROL PLEASE HELP ME, THANK, YOU.
Hello
WHITE WESTINGHOUSE Codes: 097/ 100
Four digit codes for white westinghouse are : 0100 0130 0138 0136 0227 0279 0080
four digit codes for wetinghouse are: 0143 0114
OK
Jul 25, 2011 | Televison & Video
What is the remote code for Westinghouse TV's
beaker60,
I would need to know the model remote to provide exact codes for that TV brand, but I can provide some general codes.
White Westinghouse TV: 500, 781, 816
You can check out this link for more information. Choose the receiver model that matchs yours and it will show you the codes!
http://www.dishnetwork.com/SupportSection/remote-setup
Tommy Faust
DISH Network
Jul 03, 2011 | DISH Network IR Remote Control
White Westinghouse Model No WTV 11901 television
It sounds like your TV is not equipped with audio/video (A/V) jacks. Many older TVs don't have these. You need to get an RF modulator that will convert the A/V output of the DVD player into a Coaxial cable that you can plug into the back of your TV. I'm including a link to one at Radio-Shack.com. This one costs $27.49. You might be able to find a cheaper one at a discount store. You can also use an old VCR if you have one to do this conversion but the connections get a little bit tricky. Plug the A/V outputs of the DVD player into the A/V inputs of the VCR. You'll have to set up the VCR so it knows to use the A/V inputs. Some VCRs have and AUX setting for this. Then connect a coaxial cable from the VCR output to the TV input. You'll have to setup the VCR to send it output to a specific TV channel, usually channel 3 or 4. Then you'll have to set your TV to that channel. I hope this helps you out.
http://www.radioshack.com/product/index.jsp?productId=2103095
Nov 16, 2009 | Televison & Video
Westinghouse model WTV-11901 shuts off by itself
That is usually a bad power board, the TV can be turned on again after a while because the capacitors inside TV will discharge after some time. The part must be tested before replacement, as overheating can cause similar problems.
Try also leaving the TV unplugged from main overnight, and test the unit on a different AC socket.
May 15, 2009 | Televison & Video
Remote code
Hi beutyful24_7,
There are two codes for your remote that work with White Westinghouse TV models: 311 and 611.
For your reference, here is a web address that includes all the codes for your remote, along with programming instructions:
http://www.universal-remote.net/philipsmagnavox.html
I hope this helps - please let me know if I can be of any further assistance.
Dec 11, 2008 | Philips Magnavox Learning Universal Remote
White westinghouse tv model wtv-1903
The display button on your remote should remove this.
Oct 22, 2008 | Televison & Video
Comcast universal remote codes don't work for zenith zhd-311 dvd/receiver/home theater
Had the hardest time finding a code for this old TV.
Posting now so that others can find this solution.
White-Westinghouse
Modle: WTV-11901
Comcast Remote Control Code 0451
Dec 22, 2007 | Zenith ZEN310 Universal Remote Control
Televison & Video Logo
201 people viewed this question
Top Westinghouse Televison & Video Experts
Jaime Hernandez
Are you a Westinghouse Televison and Video Expert? Answer questions, earn points and help others
