Question about Arris SURFboard SBG900 (49402201900) Modem
CITRIX not working with my cable modem. Connecting via laptop using the modem's wireless connection. i am able to connect to CITRIX just fine from the office, and from other internet connections.
Are you talking about published apps not working? If so, make sure that your cable modem has the following ports open:
TCP 1494 and 2598
These ports are used by the ICA protocol, which is what Citrix Presentation / XenApp Server software uses for running published apps.
Posted on Jul 19, 2010
Can I disable wireless and connect with ethernet cord and modem, for work do not want remove wireless cord, in the day want to be able to use my wireless.
Are you talking about direct-connecting via Ethernet to a cable or DSL modem? You shouldn't have to disable wireless to do that. If the cable modem has an open Ethernet port, you should be able to run a straight-thru Ethernet Cat-5 cable between that port and the Ethernet port on your laptop. The laptop should recognize that it is connected to the modem through the direct connection. Check the manual for the cable modem or information supplied by your ISP for connection details. You may have to do some setup on the modem to get an Internet connection, like having your ISP 'activate' the modem. Just be sure your Ethernet cable is a straight-thru, standard Ethernet cable, and not a 'cross-over' cable such as is used to transfer data between two computers.
Jul 24, 2014 | Dell Inspiron Computers & Internet
Wireless modems
Connect your computer via ethernet cable directly to your modem then power off the modem for 30 seconds that way should be able to go online if the modem and internet is working fine from your ISP.
Hope that helps...........
Jul 28, 2008 | NetGear WGR614 Wireless Router
Easytether.. connecting via cable modem after installing easytether
Surely it needs more info to may it be resolved. But seems that you have a problem with DHCP. Try rebooting your Linksys Wireless G router and the two laptops AFTER you connect the cable modem.
Sep 27, 2017 | Cell Phones
Can't establish connection by cable
Assuming you would have checked your LAN port. Try using a USB LAN port device and see if it picks up. Else you can test connecting the modem via Ethernet cable to another machine. Does it work,? If it does then its your machine.
Apr 11, 2010 | D-Link DIR-300 Wireless Router
I connect fine to it but cannot get to internet
This is not a trivial task but to start, I presume that your Wireless Router is connected to an ADSL or CABLE modem:
1) Make sure that you can connect to the Internet/Web directly from the ADSL/CABLE modem. 2) Once you have step 1 validated, connect your Wireless router to the ADSL/CABLE modem. 3) Ensure that you can communicate to the Wireless router and use Netgear supplied software - I suggest that you connect your PC/LAPTOP used for configuration directly via an ETHERNET cable attached to your router: 'NETGEAR's Smart Wizard™ makes the set-up of the RangeMax™ wireless router easy and hassle-free. Smart Wizard automatically detects your ISP's network settings, then walks you through each step of the installation proces' 4) When the installation is finish, try connecting to the internet via the ETHENET cable on your router. If it does not work, the FIREWALL on the ADSL/CABLE MODEM may be blocking the port and needs to be opened/disabled. 5) You can now concentrate in getting the WIFI working by first using an 'unsecured/no encrytion' connection by setting an appropriate SSID. 6) Once setp 5 is working, you SHOULD NOW SECURE your Wifi connection by using a selected encryption (such as WEP or better) and security key.
ps. you will get this 'limited access' message if anywhere in the device chains the IP addresses cannot be resolved.
Dec 20, 2009 | NetGear RangeMax WPN824 Router
What is the difference between connecting a computer to a DSL modem via Ethernet and connecting a computer to a DSL modem via USB?
They are just two different methods of connecting a router. I always choose using an Ethernet over USB if I have the option. USB connections are more prone to problems with drivers.
Sep 23, 2009 | HP Pavilion dv6000z Notebook
Router not connecting with adsl modem wirelessly
re-set it and re-configure it ur router then you get it
Mar 12, 2009 | Computers & Internet
Belkin Router not allowing an Internet connection
It's not unheard of for a router to fail. When you connected the computer to the Modem, did you use the same cable that was connected to the router? Does your internet connection require a username and password? If so, is that configured in your modem, or the router? If not in the modem it must be the router.
Jan 05, 2009 | Belkin (F5D7230-4) Router (587009)
Zoom aDSL modem/wireless router seen but not connecting
Here are a couple of ideas to look at first, assuming you haven't tried them already:
1) Does moving the router help? Sometimes a new DECT phone or a microwave, or even a piece of equipment at a neighbour's house, can interfere with the signal.
2) Does changing the channel on your router help at all? If there are many other networks using the same channel, this might block your own signal.
3) If this does not make any difference, it might be worth checking your security settings.
Nov 14, 2008 | Zoom (5590-00-03) Wireless Router (G66115)
Network problems connecting to internet
Hi. If Dell is correct, then yes, it would be expensive. Your other alternative is to buy a PCMCIA Ethernet Card. They range from about $20 to $40. Or, you could go with what you suggested and do wireless via a wireless router.
May 21, 2008 | Dell Inspiron E1505 Notebook
Arris SURFboard SBG900 (49402201900) Modem Logo
175 people viewed this question
Top Arris Computers & Internet Experts
Jerry
Jerry
jimmy Leo
Are you an Arris Computer and Internet Expert? Answer questions, earn points and help others
