Question about Cooktops
Timer buzzer sounds continually, how do i disable it?
  • Michael Masters
    Michael Masters May 11, 2010
    HI. What is the model number on the unit? I will need the entire model number, please. Thanks..
    President:
  • 1,515 Answers
Hi, If you just want to eliminate it and not replace it now anyway, just raise the top, if it is elect, be sure you turn off the power or unplug it, and then mark or draw you a little diagram for future use and remove the wiring.If you need to cut the wires then do this and tape the ends before you plug it back in. Its just an annoying timer, that you can replace with a counter top. Good Luck,
Shastalaker7
Posted on Nov 12, 2009
BAUMATIC GECE6005Induction cooktop will not unlock so how do I get it off lock
Baumatic GECE6005 manual page 18
To disable the safety lock feature, you should press the safety lock button for a couple of seconds. The "L0" symbol will disappear from the timer display and you are then able to use the hob in normal operation.
Sep 08, 2016 | Baumatic Cooktops
Wha is the small red light and buzzer for on the GE JGP975SEKSS gas cook top?
Red light normally means it on. Usually also means the stove is on and the buzzer is probably to let u know when oven is ready or is part of a timer.
May 29, 2015 | GE Cooktops
I have a Frigidaire Gallery Professional Series Stove and Oven unit. The oven temperature indicator light has been fading for years and is now barely visible. Everything else on the control panel (timer,...
Hello arab125 - I understand that the timer and clock works fine, however from what you have described it sounds like the range could possibly have a wiring failure, faulty sensor, or an issue with the EOC. I would suggest contacting a professional to move forward accurately.
Oct 08, 2012 | Frigidaire FGEF3031KB Gallery 30"...
GE gas cooktop modelJGP970BEK2BB. The unit is in the unlocked position, burners will light, but "lock" light remains on and buzzer/alarm sounds the whole time?
The lock switch will need to be replaced. Lock switch, the switch has failed and causes the buzzer to run. Not a difficult repair but the top will need to be remover to fix this. This is not advisable to repair if your not knowledgeable with the installation part of this unit.
Good Luck
I’m happy to help further over the phone at https://www.6ya.com/expert/gere_bf68e6055dd61249
Jul 19, 2011 | GE Profile JGP636 Gas Cooktop
My cooktop has electric ignition that "clicks"
Take a q-tip and clean under where it clicks. Might have food or grease covering release hole.
Dec 06, 2017 | GE 36 in. JGP628 Gas Cooktop
We have a belling gas hob. Intially when we turn on the control knob it gave a ticking sound even after it got ignited. then when we were turning on one burner it gave ticking sound in all burners . but...
take out the control knobs. clean the grease and food partilcles if any using hot water and dish washing liquid .if the washer under the knob is stuck, put it properly and put the control knobs back into it carefully
Jan 11, 2010 | Stainless Cooktops
GE Profile Gas cooktop stove- buzzer won't stop
Unfortunately you have to wait until it dries out. I have tried hairdryer before but most of the time I have had to leave it off overnight. FYI if you dont shut off at the circuit breaker and the sparking continues it will short out and definitely get worse
Feb 09, 2009 | GE 36 in. Profile JP968 Electric Cooktop
Clock & Timer Malfunction
you can go to the back of the clock and clip the buzzer wire[one is allyou need] tape it up.other wise you need a new clock
Dec 31, 2008 | Cooktops
Jenn air fan comes on with rear burners (elec) can I disable?
Perhaps, but sound safety says no. This generates a lot of heat in an enclosed space; the fan may be a nuisance but it is needed to keep the unit from getting too hot. Hope this helps!
Dec 27, 2008 | Jenn-Air JED8430 Electric Cooktop
Cooktops Logo
Top Cooktops Experts
Paul Carew
Are you a Cooktop Expert? Answer questions, earn points and help others
