Question about Logitech Cordless Mouse
Click is not working (like if I click on the OK button below - I have to click from the laptop not the mouse.
    Master:
  • 956 Answers
Have recently experienced my micky doing sim, still showing led but nothing, believe it or not the batteries were the problem, rundown but not total.
Replace batts.
If that fails and your equiopt is recently purchased, back to supplier with prove of purchase.!
Hopefully rundown batts. Goodluck!
Posted on Nov 12, 2009
How can i activate my mouse sensor???
depending on your laptop this will vary
If the Fn (Function) button at the bottom left of the keyboard is pressed in conjunction with some other key on the keyboard it can result in the disabling of the mouse pad.
To enable your mouse pad on a Windows PC go to the Control Menu.
Under the Printers and Other Hardware option, click on Mouse.
Then, click on the tab on the top of the pop-up menu that says Device Settings.
The touch pad for your computer should come up as a selectable option.
Click on it and you will see the option to enable your device, then click OK
or
Right-click on a blank spot on your desktop. Scroll down, select "Personalize" and then choose "Mouse Pointer."
Click the "Device Settings" tab. Highlight your TouchPad in the "Devices" section. Hit the "Enable" button.
Click the "Apply" button and then click the "OK" button.
or
Click the "Start" button in the lower-left corner of your computer.
Type "mouse" in the field above the button. Click "Mouse" in the list of items that appear.
Click the "Device Settings" tab. Highlight the touchpad item in the "Devices" list.
Click the "Enable" button. Click the "Apply" button and then the "OK" button.
hope this helps
Sep 24, 2012 | Acer Aspire 5102WLMi PC Notebook
How do I disable touch pad from Dell Latitude E5400
You may disable the touch-pad by following the steps mentioned below:
  1. Click Start and then Control Panel
  2. In Control Panel, click on the Mouse icon. Note: If the Control Panel is in Category View, under View by, click either Large icons or Small icons.
  3. In the Mouse Properties window, click on the Device Settings tab.
  4. In the Device Settings tab, click on the Settings button.
  5. Check or uncheck the checkbox next to Enable Tapping then click OK.
  6. On the Mouse Properties window, click Apply then OK.
Hope this helps..
Feb 20, 2011 | Dell Latitude E5400 Laptop
How to unlock the mouse of hp pro book 4520
Thank you for using fixya.
Enable for you to unlock the mouse pad of your HP laptop, press FN + F7. However, there are some instances when that key won't work for some apparent reasons. But, don't worry because there are some other ways on how to make it work. I have provided a link below. This is a link to a tutorial on how to unlock your mouse/touchpad. Click on the link below:
http://www.fixya.com/support/r8113144-enable_touchpad_in_laptop
Thank you for trusting fixya.
Carloadrian
var geo_Partner = '82910b1e-9b92-42fd-b83f-fa09a0787ae7'; var geo_isCG = true;
Feb 06, 2011 | Computers & Internet
Well, my mouse on my hp laptop will not move
  • “Hi, “To “Enable” the Pointer Device using the Touch-Pad, go to, Control Panel, click (“Mouse) in the "Hardware and Sound” category; go to, “Device Settings” in the (Devices) block.
    II. “Highlight”; the item you want to (enable) this being the “Pointer Device.” Click the (Enable) button, just below. Be sure to (Click) on the “Apply” button, and click OK.
    III. You may need to “Update Drivers?” Click on “Hardware, click “Properties,” click, on Driver.” If the, Update Driver (block) is not “Grayed-out” click "Update Drivers”, click (OK), this will ensure that the applications take effect.
    Note: Restarting the computer will configure system changes in the computer applications to prevent errors, and to finalize the (Installing / Uninstalling) of programs, and or (Enabling / Disabling) of Hardware.
    "Rating the solution is your way of letting me know if it (helped or not), thanks."
May 08, 2010 | Computers & Internet
Mouse pad on laptop not working after install of new hard drive and os. usb ports also not working.... any ideas as to what is going on inside there?
    III. You may need to “Update Drivers?” Click on “Hardware, click “Properties,” click, on Driver, "Update Drivers, click Apply and (OK).
    Note: Restarting the computer will configure system changes.
May 05, 2010 | Toshiba P25-S526 Notebook
My touchpad scrolling doesnt work. how can i fix it?
  • Hi, this Information apply to the same application for the "Mouse" and "Pointer Device" to function properly.
    I. “To “Enable” the "Mouse" or (Pointer Device) using the Touch-Pad, go to, Control Panel, click (“Mouse) in the “Hardware and Sound” category; go to, “Device Settings” in the (Devices) block.
    II. “Highlight”; the item you want to (enable) this being the "Mouse" or “Pointer Device.” Click the (Enable) button, just below. Be sure to (Click) on the “Apply” button, and click OK.
    III. You may need to “Update Driver” Click on “Hardware, click “Properties,” click, on Driver.” If the, Update Driver (block) is not “Grayed-out” click “Update Driver,” click (OK), this will ensure that the application take effect.
    "Rating the solution is appreciated, thanks"
Apr 12, 2010 | Acer Aspire 5335-2257 Notebook
My touch pad stopped working on my brand new Acer Aspire laptop model 5532. I have tried turning it on and off and it only works with a mouse. Any solutions?
“Hi,
I. “To “Enable” the Pointer Device using the Touch-Pad, go to, Control Panel, click (“Mouse) in the “Hardware and Sound” category; go to, “Device Settings” in the (Devices) block.
III. You may need to “Update Drivers2_bing.gif?” Click on “Hardware, click “Properties,” click, on Driver.” If the, Update Driver (block) is not “Grayed-out” click “Update Driver2_bing.gif”, click (OK), this will ensure that the application take effect.
If the solution helped, rating it is appreciated, thanks
Mar 29, 2010 | Acer Aspire One Netbook 8.9" Notebook
My touch pad or mouse stoped working
Hi, to Enable the Pointer Device; go to, Control Panel, click (Mouse) in the Hardware and Sound category. Go to; Device Settings, in the (Devices) block, click on, and Highlight; the item you want to (enable) this being the Pointer Device. Click the Enable button, just below. Be sure to (Click) on the Apply button, click OK. You may need to Update Drivers. Click on Hardware, click Properties, click, on Driver. If the, Update Driver (block) is not Grayed-out click Update Driver, click (OK), this will ensure that the application take effect. Note: Restarting the computer will configure system changes in the computer applications to prevent errors, and to finalize the (Installing / Uninstalling) of programs, and or (Enabling / Disabling) of Hardware. I hope this will fix it. paul7of9
Feb 24, 2010 | Acer Computers & Internet
Automatic scroll does not work on touchpad unless you hold down the left click button
This can be set to scroll for you as it is a simple setting in the mouse control panel.
Go to your start menu and open Control panel, select classic view in the top left corner if there are less than 20 icons(pictures) in the menu. Now double click on the mouse icon. Click on the advanced tab. then select your synaptec device in the list and click the properties button below.
There are several options on the menu, one will say "Virtual Scrolling"
Check the box beside Vertical Scrollong and then click OK on this window and the mouse window.
Close the control panel and you're on your way.
I hope this helps Fixya,
Chris
May 19, 2009 | Compaq Presario CQ60-220US PC Laptop
Keyboard
From the Dell D620 Users Manual:
You can use the Mouse Properties window to disable the touch pad and track stick or adjust their settings.
  1. Open the Control Panel and click Mouse.
  2. In the Mouse Properties window:
    • Click the Device Select tab to disable the touch pad and track stick.
    • Click the Pointer tab to adjust touch pad and track stick settings.
  3. Click OK to save the settings and close the window.
The Mouse Properties utility is found like this:
Start Button>Control Panel>Printers and Other Hardware>Mouse
or in the Classic View
Start Button->Control Panel-> Mouse
Dec 31, 2008 | Dell Latitude D620 Notebook
Logitech Cordless Mouse Logo
50 people viewed this question
Top Logitech Computers & Internet Experts
micky dee
Are you a Logitech Computer and Internet Expert? Answer questions, earn points and help others
