Question about All-Pro Heating & Cooling
I want to know where to buy a thermo coupler for an All Pro SPC 150.
  • campboss Nov 12, 2009
    Found out they do not have a thermal coupler, spark ignition. Thanks anyway.
    Scholar:
  • 91 Answers
Thermocouples can be purchased at most hardware stores, home depot, etc. The only difference for a thermocouple is the length. There are heavy duty types and regular. I would suggest using a heavy duty thermocouple. Also, it is recommened that thermocouples be changed every 2-3 years to prevent unnecessary failures, which usually occur when you need the unit the most.
Posted on Nov 13, 2009
  • snny1 Oct 25, 2010
    most fire places have coupler mounted on a bracket . coupler without bracket is usless
When you release start button it quits
this unit like most has a heat switch and a thermal coupler they work to gather jump the switch if it runs then its the switch if it doesn't then its the thermal coupler flame should hit the coupler and turn red loose wire on switch has happened before to
Dec 04, 2013 | All-Pro SPC-85 Utility Heater
Where to find a thermo couple for all pro spc40
It could be your thermocoupler or the thermoelectric valve. Contact the company below for your troubleshooting and parts. I am sure they can help you.
Good luck....Jim
www.theheaterguys.com
Feb 19, 2011 | All-Pro Propane Garage Shop Heaters - All...
When I push my red button in it shut off the fuel and wont stay going
this is caused by a bad thermo coupling. just to make sure that it is in fact bad - hold down the button for about 20 seconds while the heater is going and if after that amount of time the unit still shuts down when you release the fuel button - then replace the thermo coupling.
c...
Jan 03, 2011 | All-Pro Propane Garage Shop Heaters - All...
I have an All-Pro 40k Btu SPC-40a heater that won't stay lit,, is this a thermocoupler issue?
If it effecting the pilot light only, yes. If it effecting the main burner, you will need a thermo-pile or pile-generator.
Jan 19, 2010 | All-Pro Heating & Cooling
Need to know where the thermo coupler is and coil
if it is running its not your thermo i assure you
more than likely an ignitor
they are right up front once you take the front panal off
Oct 24, 2009 | Whirlpool LGN2000LWH Gas Dryer
Burner will not light, but pilot is on
Sounds like you need a new thermo coupler. this is first and foremost.
Can you light the burners by hand? and do they burn hot and clean that will let you know if you have clear intake lines for the gas.
There is a small chance the gas valve is having a problem,not at the burner control but the vavle the thermo coupler is connected to. or worse case scenario moisture in the gas line.
Feb 02, 2009 | Imperial IFS40 Deep Fryer
Thermo coupler on all the time, push in button, shuts off gas
Bad Safety valve. (valve w/red button). Thermocouple keeps the magnet open to keep pilot and so gas can flow to burner. Make sure pilot is clean and strong and hitting thermocouple. If it doesnt stay lit replace Safety Valve.
Dec 17, 2008 | Bakers Pride FC-616 Gas Single Oven
Heating & Cooling Logo
1,304 people viewed this question
Top All-Pro Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
T bone 1963
Are you an All-Pro Heating and Cooling Expert? Answer questions, earn points and help others
