Mitsubishi projection
My projection tv works than it cant find any signal and its just a snow mess
I got the tv to work using rca jacks out of the cable box the other port must have a bad connection
Posted on Jan 12, 2008
  • 8,617 Answers
What model number is It?
Posted on Jan 10, 2008
6ya staff
SOURCE:
SNOW AND BLACK RECTANGLE ON BOTTOM
the black rectangle is likely "text" feature in closed caption area on---snow is another issue---need model and what and how signal is connected to the set.
Oct 22, 2012 | Toshiba Televison & Video
The sound on my 95 hitachi bis screen tv works but there is just lines and snow on the screen, there is no color to the screen.
The tuner is bad, try directingthe signal to the Video input, and put the set in Video mode, you will also have a better picture,,use RCA cables from signal box to TV.
Aug 10, 2011 | Hitachi Televison & Video
Snowy picture, device menu will not come up.
Depending on what devise, (cable box, game system, movie players) the sign of snow is no signal, there are inputs that you hook a devise up to on a TV, you have to change the input on the TV to pick up the signal of the unit, on the remote or TV itself, there with be a(n) "input", "source", "tv/video", or "video source" button that you can choose the same input you chose in the back of the TV.
Jun 28, 2011 | Mitsubishi WD-52628 52" Projection HDTV
Trying to set up my xbox to my orion tv but cant get it to work. the screen shows nothing but snow
You have to switch the TV to the proper input. If you are getting snow, the tv is on the cable input. Xbox only works on the composite or component inputs on the set. The inputs are labeled at the jacks that you have connected too. Find the input button on the tv remote and switch the tv input to the input number you are connected to. Thanks for using fixya.
Dec 13, 2009 | Televison & Video
My Panasonic DLP television suddenly lost picture, went to snow and lost audio. What is wrong?
If you have snow that means you've either lost the signal source (cable satelite antenna) or the TV tuner is bad or your not on a recievable channel. Try hooking a signal to one of the video inputs of the TV.
More info on what you have hooked to the TV would help.
Sep 27, 2009 | Panasonic Televison & Video
NO SOUND OR PICTURE JUST SNOW WAS WORKING FINE THE DAY BEFORE
Check the tv with another cable signal or another tv with that cable signal.Both check,same things happen.Ur tv digital tuner is dead.
Sep 24, 2009 | Mitsubishi VS-50603 50" Rear Projection...
TV Snow and Static Sound
Sound like its all cabled wrong So its from the source, (wall satalight Whatever ) to VCR in then VCR out to TV, Now when the VCR fires up it tunes the RF output to Chanel 4 and has a strong signal, that over rides just about every thing. Simply way to stop this is one of two ways, press the TV/VCR button on the VCR, or simply turn off the VCR to let the signal pass through.
Mar 06, 2008 | Televison & Video
Auto SAP
The problem is not a cable one, but a TV function. Pull out your user manual for your TV. My dad just had this happen, and he has a Sony WEGA TV. The auto sap is an AUTO Secondary Audio Program, you need to find the menu to back out of it.
Good luck.
Jan 06, 2008 | Sony KP-65WV700 65" Rear Projection HDTV
Just snow when using the hdmi
Ih the DVP works on the other set and not this one the proble is the snall signal board 313503711711.
Nov 05, 2007 | Philips 51PW9303 51" Rear Projection...
Rear projection snow
Bad primary tuner==can be replaced,or==by-pass by using video inputs.
Aug 26, 2007 | RCA D52W20 52" Rear Projection HDTV-Ready...
Televison & Video Logo
Top Televison & Video Experts
Marvin
Marvin
