Question about Maytag Neptune MAH5500B Front Load Washer
At the spin cycle it shuts dwn and has Lr on the screen when I shut it off to just use spin cycle it does a count down but not the spin then Lr comes up again
    Brigadier General:
  • 8,619 Answers
Hi
Thanks for using FixYa. Lr means locked rotor. This issue occurs due to locked rotors, you'll need to check the rotor wiring and windings. If the wiring is good and windings are not burnt then you'll need to replace your motor and motor control board. These are sold as one unit, it is a 3 phase motor and one of the phases is bad. A little power surge can damage the boards.
Please do rate the solution and revert for further assistance.
Thanks
Rylee
Posted on Nov 12, 2009
Lc-xb40n shuts dwn at start-up. fans cycle high a few times then shut-dwn with power light blinking.
Those blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices.
http://homenol.blogspot.com/
If blinks continue without any pause, the main board is faulty.
Search the site by type in the "brand name" to your device, in the "Search box at the top right of the display window of the Homepage" to get gathered related posts.
Jan 25, 2017 | Televison & Video
My Mitsubishi WD 65736 TV has a bad Fan ... according to a tech that came out . How do I tell which of the 3 fans is bad .. all 3 come on for about 15 seconds then shut down all at once ... start up again...
Hello, count the blinking light pattern. It may blink 2 to 9 times, pause and repeat the pattern again. Does it ever light the screen when it's cycling on and off? Let me know....tks
Feb 24, 2015 | Mitsubishi WD Televison & Video
My maytag washer when i start it it fills then the cycle starts the timer will count down til it get to 13 min then jumps down to 3 min then shuts off it skips the wash cycle and the rinse cycle befor
sounds like you have a problem with the main control board. you can order a new one from appliancerepair.com and if it turns out not to be the problem they allow you to return it for a full refund. great company!
May 26, 2014 | LG Washing Machines
Lr shows during spin cycle and pauses washer
you need to replace the motor and the motor control board,it comes in a kit,call your parts store give them the model number and the first two on the serial.common problem with the neptune,the wire harness that plugs into the motor is strait down,moisture runs down the harness and gets into the connectors,it's around 200 bucks for the kit
Feb 19, 2010 | Maytag Neptune MAH5500B Front Load Washer
My fridgidaire frontloader wont do a spin cycle
A lot of times it is the strainer clogged at the pump. That has happened to mine. Hope that helps.
Sep 06, 2009 | Frigidaire Affinity ATF7000E Front Load...
Spin cycle very slow
have you cleaned your pump filter? using correct detergent HE an proper atmount? all this will cause problems. IS YOUR DRAIN HOSE CLEAN?
May 15, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Sony TV shut down
Sony sets have internal diagnostics. Unless the ste is 100% dead, you should see the standby light blink in a pattern of count,pause,count... Please supply that count here and I can give you details about the problem.
Dan
May 23, 2008 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Washer mah5500b
Replace the door Wax motor & main Control Board.
Apr 13, 2008 | Maytag Neptune MAH5500B Front Load Washer
Maytag Neptune MAH5500B Front Load Washer Logo
204 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
