Question about HP Officejet 5610 All-In-One InkJet Printer
I can not fax anything out- i share the fax line with my phone line. recently switched from AT&T to cable phone- would this effect my fax machine?
    President:
  • 3,085 Answers
Fax machines are analog devices and will not work reliably on a digital phone line.
Posted on Nov 13, 2009
    President:
  • HP Master
  • 2,022 Answers
Not as such but make sure the phone wire which you insert in fax machine getting proper dial tone and getting out going calling facility.
I have recently purchased 4 Gigaset AL140's which are all registered to the same base, and found that, every now & then when someone calls, there's what sounds like a fax tone in the background. No -...
The sound you are hearing is radio interference, which is stated in the manual and on the base itself as having to be accepted. There are a couple of steps you can take to prevent this:
Move the base to a location away from other radio devices, including but not limited to: Microwaves, computers, dvd/cd/audio players, other phones, radio's, basically anything electronic that sends out a signal.
Moreso, cordless phone's generally have a feature allowing you to change the channel that they send/recieve signals on. Changing this may have a better effect on sound quality. The instructions on how to do so are in your manual!
Good luck
May 04, 2011 | Lands Phones
How do I ensure the fax only switches in when the
Your fax machine knows when a fax is ringing the line
Aug 06, 2009 | HP Officejet 5610 All-In-One InkJet...
How could I switch the fax, to receive
do you mean the fax line is shared with the phone line, and you want the machine to pick up faxes when necessary, and let phone calls go? If that's the case, this mahcine is designed to be on a dedicated line. In other words, there is not setting for "distinctive ring", or to set the # of rings to pick up. It will answer any call coming in. The only thing you can do is set it to "manual receive", under "user tools", "fax features", and then you could use it for sending faxes, but it will not receive unless you switch it to fax, and press the "on hook" button.
Jun 12, 2009 | Ricoh Aficio 1232C Color Copier
Setting up fax feature
get a separate telephone cable and attach it to your fax, switch line over from phone to fax manually at the phone line input on the wall, it's the ONLY way I can manage that same problem. If you forget to "switch" your lines over, unplug the fax from the wall & answer your other house phone that's plugged into the wall. Works every time. It takes a little effort, but why pay for more phone lines when all you have to do is plug/unplug an extra phone line?
May 16, 2009 | Samsung CLX-3175FN Color Laser All-in-One...
Why is my fax machine saying phone off hook when its really not. All tests passed except the fax line condition. It says its weak.
First thing to check is the condition of the phone line, if the machine has a handset make a phone call from the handset, is the line clear? Is there any static or Echos on the line?
Is the machine on a shared line with computers or an answering machine?
Call the Fax machine from a phone, is the line clear? did the machine generate its handshake burst? Did anything else try to answer the line?
Check the phone cable input, it should be going onto the LINE jack on the back of the machine.
Replace the phone line cable.
Remove the handsetn or at least unplug it.
Hope this is of some help.
ED
Apr 23, 2009 | Xerox WorkCentre Pro 555 Plain Paper Laser...
Having trouble receiving faxes, takes several times of someone sending to me to receive.
Apr 15, 2009 | Brother IntelliFax-1860C Plain Paper...
What do I buy to use 2line phone and separate fax?
You can buy a 2 line phone, but to use the fax/dsl line for voice, you will also need a line sharing device.
"The stick" is a good brand....
All it does is recognize if an incoming call is a fax or a voice call. If fax it would go to a fax port on the stick. If voice, it comes out the voice port which you can call on.
The same rules apply to this line....if something is using it, the next call will get busy......But now you could have the phone company "Hunt" your line 1 to line 2 (fax/dsl) if line 1 is busy.......hence...2 incoming lines....
Apr 14, 2009 | RCA 25201RE1 Corded Phone
Can't print from PC when a phone is in use on same line
hi i think its some short circit to ur fax boart to or telephone line. beter u check ur telephone line and fax modem card.
Jul 04, 2008 | Samsung SCX 4521F All-In-One Laser Printer
Samsung SF-335T
The load factor of the fax is too high for your phone line. These fax machines are really designed to work on a dedicated phone line and not a voice shared a line. You can have this type of effect with many types of fax machines.
Jerry G.
Apr 20, 2008 | Samsung SF-335T Plain Paper Inkjet Fax
Epson ACULASER CX11NF incoming fax problem
Try this:
Unplug line from back of printer
Set the Incoming mode to autoswitching
set DRPD to Off so that it will recognize all incoming calls
** if possible call your telephone company and set a distinctive ring pattern for phone calls
replug cable on line port at the back of printer
then ask someone to send you a fax...
Feb 05, 2008 | Epson ACULASER CX11NF All-In-One Printer
HP Officejet 5610 All-In-One InkJet Printer Logo
51 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
