Question about Ranger RCI-6900F-25 CB Radio
My rci 2950 recieve cuts in and out, but
My rci 2950 recieve cuts in and out, but tr, is fine
  • 141 Answers
A tuning can in the receive section of the radio is shorted.
Posted on Jan 30, 2010
Check the ground wires
Posted on Nov 13, 2009
Where can I get a cpu board for my ranger 2950?
get hold of ranger and they should be able to help you.
Mar 18, 2013 | Radio Communications
Ranger rci 2950 will not transmit
have you tried it on all bands? still won't transmit?take it to a tech so they can fix it properly.
Sep 16, 2012 | Ranger Communications RCI-6900F-25 CB...
Rci 2950 no transmit
check your mic cord to see if you have a broken wire on the inside.You might want to get another mike for a spare but it could also be an audio transister.
Jun 30, 2012 | Radio Communications
Ranger rci 2950 no am hash and sometimes loses lsb hash and wobbles on recieve and transmit
hmmm my money is on a cold or several cold solder points,,
start checking the legs on the PLL first...
Oct 03, 2011 | Ranger Communications RCI-6900F-25 CB...
I have a RCI 2950 comes on keyed up and stays keyed untill you turn it off. I have replaced the auto amp, all voltage regulators and the black diode with yellow strip below mic plug with no change. I need...
i have the same radio rci 2950. Ive had the same problem with mine,turns out with mine the processor would lock up,turning the radio off & on repeadly would clear the problem and the radio would work fine x-mit & recieve. the solution to fixing the problem is to replace the memory backup battery this battery works similar to a computer motherboard cmos battery when this battery goes dead all sorts of strange things happen to the radio wont transmit wont recieve or like your problem transmits continiously. the problem with replacing this battery is finding out what year & model your ranger 2950 is. the internet says only first generation ranger 2950s use the battery second genration & third generation do not use the battery. but the internet could be wrong. so i suggest getting a hold of (usa ranger.com) & give them a phone call or email and ask them about the year your radio was made. they may even service it for you or if you are electronic savvy you can do it yourself. the battery is located close to the main cpu on the front panel if yours uses a battery.
Sep 07, 2011 | Ranger Communications RCI-6900F-25 CB...
My ranger 2950 wont transmit or receive sounds like a relay problem but dont no for shour can you tell me what is wrong with that radio thank you.
could be a number of different problems causing this. I would start with your microphone make sure it is working. it is responsible for transmit & recieve. next check to see if the memory battery is dead this will also cause this problem. next check the regulators in the radio to see if they are supplying voltage.next check voltages in different parts of radio to see if all stages are recieving power follow these steps and something will show up also check your switching diodes to see if they are bad the diodes responsible for x-mit & r-mit of transceiver.
Jan 04, 2011 | Ranger Communications RCI-6900F-25 CB...
No channel readout in front of radio ranger 2950
replace memory battery its a CR2032 battery Radio Shack and Walmart has them from $3.65 to $5 in price.
Jan 11, 2009 | Ranger Communications RCI-6900F-25 CB...
Rci 2950 no audio period rx or tx
Check TR38 I have seen caps in the circut
go bad more then once if you have a schematic you should be able to find it if one
is bad,a capasator meter would help but you
can check them with a ohm meter.
Good luck.
Nov 21, 2008 | Radio Communications
Rci 2950
I know the recieve adjustments are ( and make sure you adjust in this order )L9,L11,L12,L13,L14,L4,L3,L5,L6.Adjust them for highest recieve you may have to go through them a couple of times.And again do them in the order I gave you.VERY IMPORTANT!!! Good Luck
Oct 18, 2008 | Ranger Communications RCI-6900F-25 CB...
Radio Communications Logo
358 people viewed this question
Top Ranger Radio Communications Experts
AnyMHz.com
AnyMHz.com
Jon Piercy
Mike Charette
Are you a Ranger Radio Communication Expert? Answer questions, earn points and help others
