Question about Motorola Mobility MOTORIZR Z8 Cellular Phone
Wap setting are set on o2 network but need the ones for vodafone
Hi i have a nokia 6300 which used to be an old vodafone. i am using it on o2 and have no problem connecting to wap or sending messages. however when i try to access skype i get error message "subribe...
hi there, In this case you need to contact your network provider so they could send you the settings so you could use the service. hope this one helps.
May 18, 2011 | Nokia 6300 Cell Phone
No internet on my new sci pjone
Depending on your network and network setting especially GPRS setting, these have to be manually put into the phone. Try this Service,data account,GPRS,Scroll or put in setting depending on network. Open account o2 WAP GPRS, APN payandgo.o2.co.uk,user name payandgo, Password is password,Auth.type normal and thats it to o2 GPRS settings then Services WAP settings open sim, thenmake a new profile you might have to delete one you dont use Profile edit rename profile o2 GPRS, Homepage http://wap.o2.co.uk/, Data Account o2 WAP GPRS, Conection type WAP, User name o2wap, Password is password back than activate thats GPRS and network settings for sciphone on the o2 once all this is in the phone and you have credit you should be away serfing. you can get settings for any network online hope this will help Wm
Sep 01, 2009 | Lands Phones
Htc 3300 vodafone pay as you go
first of all call vodafone to activate GPRS, then go to start>settings>settings>connections to configure and use the internet service
Jun 07, 2009 | HTC P3300 Smartphone
CANNOT VIEW PICS SENT TO LG RENOIR KC910 PHONE.
Normally you'll need Vodafone to send you both the MMS and Internet connection settings. Then once received an save take your battery out of the handset without switching it off, remove your SIM for 10 seconds. Put it back together and send yourself a MMS and you should now be fully set up.
Alternatively here are Vodafone's settings:
Access Point Name: wap.vodafone.co.uk
Username: wap
Password: wap
Authentication: Normal
Data bearer: GPRS
Gateway IP (proxy) address: 212.183.137.12
Session mode: Permanent
Port number: 9201
MMS Message (Relay) Server URL: http://mms.vodafone.co.uk/servlets/mms/
Jun 03, 2009 | LG KC910 Renoir Cell Phone
Cect i 9 internet set up and coverage prob for vodafone australia
UK WAP gateway settings
The following table shows basic WAP gateway setup information for the main UK mobile phone operators. The menu options differ between handset manufacturers. Some of the common menu fields explained:Bearer type: There are two types: GSM or GPRS. GSM works by dialling a dedicated WAP dial-up number and should work on any WAP-enabled handset. GPRS is a newer technology, and only works on selected handsets. GPRS is an always-on service that is billed per-kilobyte, and not as GSM, which is billed per-minute. Dial-up number - The telephone number that your WAP browser needs to dial to connect. (Not required for GPRS)
  • GPRS APN - If connecting over GPRS (as opposed to dial-up), you need an Access Point Node address, so the network knows where to direct your request. See our GPRS for full UK GPRS settings
  • Username and password - Note that these are case sensitive, and should be typed in as shown
  • Gateway IP details - WAP works by routing traffic through a Gateway that handles optimising the content efficiently. The address is made up of a series numbers separated by dots. This may also be referred to as the WAP Proxy Server address.
  • Homepage - This is the main page provided by a network operator... The front-door for access to content provided via your network operator
  • Below is the numbers you will need.
  • GSM Dial up Number>+447836 900808
  • GPRS APN>wap.vodafone.co.uk (Contract) pp.vodafone.co.uk (PAYG)
  • Username>user@vodafone.net or web will post the rest
Apr 20, 2009 | Cell Phones
I cannot access the internet on my new samsung f480, how do i set up a connection?
normally you can get all the settings sent through to you from your network providers home page on the internet,
not sure if all the models have this but try this one (its how I set my phone up for other networks)
go to menu > organiser & tools > network (such as O2 or vodafone etc) > Get settings
That sets your phone up for everything (txt, mms, WAP)
Aug 30, 2008 | Samsung Tocco F480 - Pay Monthly Cellular...
How to activate vodafone live india in HTC touch P3452?
vodafone live setting for windows based mobiles version 6::::
select "start" ---->>> select "settings" ------->> select "connection"----->>> select "connections"
Now Select "Add a new modem connection"
Connection name::"Give any name"
Moden:: select "Cellular line (gprs)"
Select "Next"
Access point name:: "portalnmms"
select "Next"
Username:: (blank)
Password:: (blank)
Domain:: (blank)
Select "Finish"
Now Select "Setup/Edit my proxy server" below that "Add a new modem connection"
Select the two check boxes
1.) This network connects to the internet
2.) This network uses a proxy server to connect to the internet
Now you ll have proxy server box below that you will have "advanced"
Select "advanced"
Select "HTTP" --->> Server:: "10.10.1.100" port:: "9401" select "ok"
Select "Wap" ---->> Server:: "10.10.1.100" port:: "9201" select "ok"
Give ok to all options.
Now select "start" select "internet explorer" and try it for the connection...
When internet is connecting it ll show "Connecting to GPRS"
You ll be getting "locating" and "opening" and the webpage
Jul 29, 2008 | HTC Touch P3452 Smartphone
Wap setting for motorolla q
Wap settings are down to your network your on Not your phone
Mar 20, 2008 | Lands Phones
Motorola Mobility MOTORIZR Z8 Cellular Phone Logo
Top Motorola Mobility Cell Phones Experts
D. E. Hev
Richard Lane
Vernon Taylor
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
