Question about Nintendo Wii Console
Trying to run wii systems update through the new BT home hub connections fine but I get an error code of 32004 can you help. Many thanks
    Genius:
  • 1,234 Answers
Error Code: 32004Please check the following:
  1. Satellite Internet often causes this Error Code. You must have a cable or DSL internet connection. Other connection types, such as dial-up and satellite, are typically not compatible. Contact your Internet Service Provider if you are not sure what type of internet connection you have.
  2. Ours servers may be trying to handle an unusually high amount of traffic (especially if a new Wii update is available). Please wait a few hours and try the connection again later.
  3. Does your internet service provider (ISP) require that you log in whenever you wish to use the internet? If so, your ISP may not be compatible with the Wii console. Please contact your ISP for additional information.
If you are still unable to connect, and have waited a few hours, please try the following:
How are you attempting to connect your Wii console online?
    Wireless Router:
  1. Adjust the Wii's manual settings. Click here for more information.
  2. Try adjusting the "Channel" your wireless router broadcasts on. We highly recommend setting your wireless router to either channel 1 or 11. Be sure to try both channels if the first one you try does not work. This can potentially increase the download speed. For information on accessing your router's settings, click here to select the brand name and model number of your router (if available). (The "Channel" setting is typically found in the "Wireless" section of your router's setup utility.)
  3. If adjusting the "Channel" did not work, please review our "Slow Download Times or Errors Received While Connecting" troubleshooting tips by clicking here.
  4. Try temporarily disabling your router's firewall.* Are you using a Netgear brand wireless router? Our expeirence shows disabling the "SPI Firewall" of the router may help the connection. The "SPI Firewall" option is typically found under the "WAN Setup" tab of the router's settings. For information on accessing your router's settings, please click here and select the model of the Netgear router you own (if available).
Posted on Aug 27, 2010
Wii disc error
If you have the wii disc error that might be because of error code 32004. It could be possibly error code 32004. If you have internet on the Wii and if so if you Wii format it again then you'll see this problem because the Wii update asks you to update it. In the update message it said at least,"Not updating this could cause future game disk problems when playing games." Im not sure how to really fix it but this just the problem. Solution has to do with you either hacking the wii or certain cases. Buy a new Wii or see if you can fix it using Nintendos support.
Dec 02, 2012 | Nintendo Wii Console
Error code 32004
we need to start from square one... let's do this
Power on your Wii console and press the A Button on the Wii Remote to reach the Wii main menu. Use the Wii Remote to select the "Wii" button.
Now, select "Wii Settings" to access the "Wii System Settings" menu.
Using the arrow on the right side of the screen, scroll to page two and select "Internet."
Select "Connection 1: None"
(Don't see "None" in Connection 1? Click the Connection 1 button, then choose "Clear Settings.")
Click on "Wireless Connection" and then "Search for an Access Point."
(Are you using a wired Internet connection to your Wii console?
Select "OK" and the Wii will display all the wireless networks it finds.
Select the wireless network that is yours.
If you are prompted to "Enter the Password or Key," then the wireless network you are trying to connect to has wireless security turned on. You will need to type in your security key or password and select "OK."
Select "OK," "Save Settings," and then "Yes."
The Wii console will run a connection test with your wireless network when the test is completed. You should see the following screen:
As long as you see "The connection test was successful," the "Wii Support Code" does not matter and can be ignored
The connection test was successful - Then you're almost done! After your connection test, the Wii console will check if there is a new Wii System Update available. Once you select "Yes" and "I Accept," the Wii will begin to download any available updates. Click here to find out what's next!
The connection test was not successful - If the test was not successful, you will receive an error code.
Error Code 51330 or 52130: This means the security code you entered into the Wii is not the same one your router is set to. Look in your router's settings and try again.
As a last resort... 1. reset your router or 2. temporarily remove the password from your router... this way you will know where the problems lies.
Thanks
Feb 24, 2012 | Nintendo Wii Console
Trying to connect to internet on my wii console but it comes up with error code 51420
error code 51420 means The Wii console is not able to connect to your wired router or modem.
Try to do this step hope it will help you plzz rate me tnxx...
  1. If your connection worked previously, check to see if there is a Wii System Update that you have not aquired. To get the latest Wii System Update:
    1. From the Wii's main menu, select the Wii icon along the bottom left of the screen.
    2. Select "Wii Settings".
    3. Click the left arrow to get to Wii System Settings 3
    4. Choose "Wii System Update"
    5. Choose "Yes" to connect to the internet and perform a Wii system update.
  2. Make sure that you are using the Wii LAN Adapter made by Nintendo (click here for a picture and connection steps). LAN adapters not made by Nintendo likely will not work with the Wii console.
  3. Check to make sure you are not running the Wii LAN Adapter from a USB hub (a device that connects multiple USB products through a single device), as this will likely not work. Connect the USB Connector directly to the modem or router.
  4. Ensure that the Wii LAN Adapter setup is correct, and that the Wii LAN Adapter was connected with the console turned off. For step by step connection instructions, please click here.
  5. Check to see if the ethernet cable you are using is not working properly, by connecting another ethernet cable from your router/modem to the Wii LAN Adapter. If the connection works using a different cable, then the problem was with the first cable.
  6. If possible, try another Wii LAN Adapter. If you are unable to try another Wii LAN Adapter, or are still receiving this error code, please call 1-800-255-3700 for assistance.
Jun 04, 2011 | Nintendo Wii Console
Wii will not system update error code 32004
Same problem. Other boards all say check router, connection - mostly answers from people who don't know what they are talking about.
Doesn't seem to be a solution for it from nintendo right now
Oct 03, 2010 | Nintendo Wii Console
Wii Console: error code 51420...
Error Code: 51420 The Wii console is not able to connect to your wired router or modem.
May 17, 2010 | Nintendo Wii Console
Error code 32004
Error Code: 32004 Please check the following:
    Wireless Router:
  5. If you are still receiving this error code, please click here for assistance.
    Nintendo Wi-Fi USB Connector
  1. Does your PC have any security programs (firewall, anti-virus, anti-spyware, anti-adware, etc.) installed? If you are using the Nintendo Wi-Fi USB Connector, and have a software firewall or other computer security program installed on your computer, there may be additional steps you must complete to allow a successful connection.
      "Trusted" Applications:
      If your firewall or PC security program keeps a list of trusted applications (also known as a "trusted zone"), the following programs are installed with the Nintendo Wi-Fi USB Connector, and require internet communications. If prompted by your firewall or PC security program, add these to the list of trusted applications. This information may also apply to certain computer security applications, such as anti-virus, anti-spyware, etc.:
      • Nintendo Wi-Fi Connector USB (NintendoWFCReg.exe)
      • Setup.exe (when installing the USB Connector)
      • SoftAPInstDrv.bin
      • mdriver.exe
  2. If you are using a router, you may need to temporarily disable the router's firewall to allow the Wii console to connect online and receive a system update. Once the update is received, you can turn the firewall back on. For information on locating and disabling your router's firewall, please consult the router's manual or contact the manufacturer of the router.
  3. If you are still receiving this error code, please click here for assistance.
*While Nintendo provides this information for our consumers' use, it is up to each consumer to determine what security needs they have for their own networks, and to decide how best to configure their network settings to meet those needs.
May 15, 2010 | Nintendo Wii Console
Error code 51420
Fiend your solution direct from nintendo. Here is your solution....
http://www.nintendo.com/wiiconsole/prob676ijt65/solution
oishuk13
Dec 26, 2009 | Nintendo Wii Console
Nintendo Wii Console Logo
189 people viewed this question
Top Nintendo Video Game Consoles & Games Experts
Bee Santiago
Raj Patel
phil
Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
